Old 02-26-2010, 08:14 PM   #1
EFI Logics
Vendor
Member#: 193180
Default 2010 Legacy GT - EFI Logics Stage 1 Tune
Ambient Temp: 31*
Elevation: 500
Car: 2010 Legacy GT
Tuner: EFI Logics
Dyno Info: Mustang Dyno 500SE
Peak HP at RPM: 223whp SAE
Peak Torque at RPM: 302wtq SAE
Baseline hp/tq for a stock on same dyno: 214whp 214wtq SAE
Target Boost: 17psi
Target AFR: 11.3
Fuel: 93 Octane
Engine/Power Modifications: STOCK
Driveline Modifications: STOCK
Suspension Modifications: BC Coil over suspension
Other Modifications: N/A
*Edit* - All Software issues are fixed, please read below first graphs.
One thing to keep an eye out for, the coupler that goes from the intercooler to the throttle body failed. There is a factory rubber insert that popped during the calibration process. We removed the intercooler, removed the rubber insert, and put it back together - No issues since.
*EDIT*
With an updated version of software that has the definitions properly defined, we were able to get past every limitation we were hitting in the prior software. Being able to raise the boost and torque limitations, we were able to pick up another ~30ft/lbs of torque, horsepower generally stayed the same as boost was not able to hold past ~4800pm. We were able to pick up approximately 15whp between 2800rpm to 4500rpm.
Final Stage 1 - 223whp 304ft/lbs
EFI Stage 1 vs. Stock
+63whp @ 4000rpm
+107ft/lbs @ 3200rpm
Some pictures of the new Turbo system on the 2010.
[/color]
Thanks,
EFI Logics
Cobb Tuning Solutions for: R35 GT-R / Subaru / Mitsubishi / Nissan / Infiniti / Mazda
Twitter / Facebook / YouTube Channel / Dyno Database
EFI Logics is offline   Reply With Quote
Old 02-26-2010, 08:27 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Pretty interesting! How was spool up compared to the older LGT's?
Mike
GrimmSpeed is offline   Reply With Quote
Old 02-26-2010, 09:43 PM   #3
CatfaceType-R
Member#: 81102
cheater, putting your turbo right on the manifold.....
CatfaceType-R is offline   Reply With Quote
Old 02-26-2010, 11:04 PM   #4
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
A pretty cool solution on FHI's behalf there. Going to be interesting to modify
alfriedesq is offline   Reply With Quote
Old 02-27-2010, 10:39 AM   #5
EFI Logics
Vendor
Member#: 193180
Smart design, hard to modify. Manufacturers will have to start from scratch to come up with new ways of mounting large turbochargers and intercoolers. I do like the design, this will dramatically help spool, although the right angle that the exhaust has to make to exit the rear of the car is nasty, I'm sure there are solutions that will make this car very fun to drive.
- Chris
Old 02-27-2010, 11:09 AM   #6
Boxer112
Member#: 78751
2015 Sti (SOLD)
Crystal White Pearl
Is that the Cat right next to the turbine housing and is it only one???
Boxer112 is offline   Reply With Quote
Old 02-27-2010, 11:18 AM   #7
EFI Logics
Vendor
Member#: 193180
Correct, Primary and secondary 02 Sensors are about 8 inches apart, and are accessible from the top of the engine bay.
Old 02-27-2010, 01:03 PM   #8
Bailey
Member#: 12572
2004 STi
35R is enough
Chris is a bad ass tuner.... we've noticed exactly the same issues here at surgeline.
Chris,
Please see your email for a new program with torque control tables and new boost cut definitions. I'll send you my base files as well
Regards
Tim
Bailey is offline   Reply With Quote
Old 02-27-2010, 01:21 PM   #9
EFI Logics
Vendor
Member#: 193180
Thanks Tim,
I have the car until about 3pm EST, so another 1.5 hours.. If you can get that to me before then, it would be fantastic. I have also posted my findings in the Cobb ProTuner section on the Cobb Forums.
Thanks,
Chris
Old 02-27-2010, 05:00 PM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
This is sweet, definitely my next project, wish I could afford it now. Great work guys! Any more pics of the manifold and turbo would be great.
Ben
Old 02-27-2010, 05:27 PM   #11
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
You might try seeing if anyone has all the definitions defined for romraider or ecuflash....
http://www.romraider.com/forum/forum8.html
Some of the boost limit tables are in Absolute Pressure in romraider.....maybe try upping the limits to target+14.7
The header piping, intake piping to the intercooler and the exhaust piping look pretty big.....maybe its just the pics. What size is the stock exhaust?
Old 03-03-2010, 10:15 AM   #12
EFI Logics
Vendor
Member#: 193180
The last revision from Cobb had all the definitions I should need to finish this car today, the largest issue was overcoming the torque limitations that were not defined in the original version I had.
The primaries are large, after the cat seems to be about 65mm, maybe bigger, where the exhaust really closes up is at the "Y" intersection, then it looks to be about 35-38mm.
Thanks,
Chris
Old 03-03-2010, 05:09 PM   #13
LittleBlueGT
Member#: 96204
2013 STI GR
Originally Posted by EFI Logics View Post
Am I the only one that sees 27 psi!!! Must be a mistake in the graph I assume.
LittleBlueGT is offline   Reply With Quote
Old 03-03-2010, 05:18 PM   #14
EFI Logics
Vendor
Member#: 193180
Your reading the graph wrong. Top bold red line is torque, lower thin red line is boost.
- Chris
Old 03-03-2010, 05:59 PM   #15
EFI Logics
Vendor
Member#: 193180
We have reached a finishing point with the Stage 1 tuning on this car. Thanks to Cobb Tuning and Tim Bailey @ Surgeline for getting us an updated software package that has the definitions needed to surpass the torque and boost limitations we were having.
+63whp @ 4000rpm
Thanks,
Chris
Old 03-03-2010, 06:34 PM   #16
mond12345
Member#: 174090
2007 STi
Nice TQ!
mond12345 is offline   Reply With Quote
Old 03-03-2010, 06:55 PM   #17
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Is that a twin scroll turbo?
blkscooby is offline   Reply With Quote
Old 03-03-2010, 07:08 PM   #18
roninsoldier83
Member#: 61966
2016 Golf R & 13 WRX
Sold: 06 STI & 15 WRX
How does this compare to the last gen LGT, both stock and Stage 1 tuned?
I've been very curious about the new turbo/manifold design, good to see some results. Thanks!
roninsoldier83 is offline   Reply With Quote
Old 03-03-2010, 08:50 PM   #19
LittleBlueGT
Member#: 96204
2013 STI GR
- Chris
I was subtracting 14.7 (or so) thought maybe it was absolute pressure.
Ooops.
Old 03-03-2010, 09:36 PM   #20
sutter2k
Member#: 92467
08 STI
Seems like a front mount for this car would have pretty short piping.
Also, looks like only a 15 minutes downpipe swap. (assuming you have one)
sutter2k is offline   Reply With Quote
Old 03-03-2010, 10:13 PM   #21
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Cool stuff, I wonder how big a snail you can fit in there
Just noticed the serpentine belt, interesting.
Merp is offline   Reply With Quote
Old 03-04-2010, 10:47 AM   #22
EFI Logics
Vendor
Member#: 193180
Undetermined at this time. We have not removed the turbo from the car.
Below are a few graphs comparing it to a 2008 Spec.B. This map was just an OTS Stage 1 map, so there was no custom mapping involved at all.
Old 03-04-2010, 12:02 PM   #23
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Cool. I'm sure getting around these limitations will only get harder in the future, but Cobb is on top of it. That looks like a lot more fun than stock.
Innovative Tuning is offline   Reply With Quote
2010 Legacy GT Stage 1 Maps Available Now! Cobb Tuning Vendor Announcements 0 04-20-2010 07:31 PM
2010 Legacy GT Automatic vs Manual transmission vote njchen24 General Community 23 04-09-2009 10:55 PM
1/4 times...Legacy GT with CAP Stage 1...@ LACR Driver72 Proven Power Bragging 50 05-26-2005 09:06 PM
