Old 02-27-2010, 12:51 AM   #1
Gamble_WRX
Member#: 234783
2004 STi
Default How To: Change a power steering pump on WRX/STi
if this has already been posted delete it. i looked and did'nt see one.
This is my first write up, hopefully i don't do too bad.
its been a week so i'm going off memory
Ratchet 3/8 & 1/4
Sockets 10mm 12mm 14mm
wrenches 10mm 12mm 14mm possibly a 7/8 if you strip the banjo bolt and have to replace the fitting.
may have listed too many let me know if i did.
Easiest way to swap the power steering pump is to take off the cover, there's a tensioner bolt that's part of the PS pump, and bolted to the alternator its positioned vertically loosen it enough to remove the belt.
NOTE: you may have to use some force to move your alternator down. after you remove the belt, take the two bolts that hold the alternator in out one is on the right, its a little tricky a pair of pliers may help, then remove the bolt on the tensioner to remove the alternator. not the tensioning bolt, the one that connects the tensioner to the alternator. Keep the wires connected if you want, and pick up the alternator and move it to the right. Now, youll see some vacuum lines located on the bottom leftish of the hole you just created you'll notice a bolt vertically inserted under those lines to hold in the power steering pump. After moving the lines out of the way take out that bolt. There's two more mounting bolts you will have to feel for, one is located bottom right of your power steering pulley, the other is located straight under and slightly left of the pulley center. Now remove your banjo bolt, its on the metal line i believe its a 14 mm socket
NOTE: the banjo bolt is easy to strip out and hard to find be careful when reinserting it on installation.Torque spec is 29 Ft Lbs
After the banjo bolt is out, remove the feed line, which is only held on with a hose clamp.
SUGGESTION: buy some better hose clamps as they are weak and can cause air leaks and a never ending bleeding process.
You don't have to but alot of people have problems with the pinch clamps leaking.
Your now ready to remove it, lift it out slightly right so you can miss your turbo inlet.
its out!
To install reverse this process. When your all done i suggest flushing your PS fluid as it may have metal in it which could cause damage to the rack.
FLUSH:
To do this get two friends, one to hold the return line from the rack down ( i suggest disconnecting from the resovoir) into a drain pan, and to hold a plug or finger on the resovoir. and one to
start the car. don't turn the wheel lock to lock while doing this. While this is happening (i suggest at least a gallon of PS fluid in a single container) and pour it into the open resovoir, this process is very fast and you don't want to run the pump dry as you will be replacing it again, make sure to have your friend ready to shut off the car at your command as you will burn through 3/4 of that gallon in about 15-20 seconds. Make sure to have him plug the hose as quick as possible the reduce air bubbles to a minimum. Now to bleed make sure everything is clamped and get a set of ramps or a hill, on a flat surface turn the wheel lock to lock a few times feeling for inconsistancys. Check your fluid level repeat, note if its foaming up pull it up the hill or stands, on a hill turn it lock to lock on ramps just let it run for a minute, shut it off wait until the foam is gone, it may take 10-15 times of backing it down and pulling it back up to bleed all the air out. If you still have bubbles drive it around for a while and check your fluid every time you stop somewhere. I tried to make this as detailed as possible
I personally, did not bleed out all the air, i still had some foaming when i had to take off. by the time i got home, the air bubbles were gone completely.
Just went through this last week, figured the write up may help someone, i should've taken pictures, but i was really frustrated as i had to do some custom fab, because i have an 02 WRX and the pump was off an STi (got told it was off an 03 wrx. did'nt quite fit right. if anyone has had Experience, and wants me to add something or has found an easier way to do a PS pump, let me know in a pm and ill be glad to edit. i hope this helps someone.
Last edited by Gamble_WRX; 07-09-2012 at 10:58 PM. Reason: found a spelling error, added torque spec
Gamble_WRX is offline   Reply With Quote
Old 03-02-2010, 08:37 PM   #2
MRSTI28
Member#: 163534
2005 STI
CGM
thank you sir!!!
MRSTI28 is offline   Reply With Quote
Old 03-02-2010, 09:33 PM   #3
Gamble_WRX
Member#: 234783
2004 STi
no problem, glad to help someone!
Old 03-05-2010, 11:40 AM   #4
rexworx
Member#: 103232
GTX 3071R'd 11WRX
PPG,4.44,LSD,E85,6spdx2
How is the STI pump different? Is the pulley the same size? Mounting points are the same...
Nice write up...
rexworx is offline   Reply With Quote
Old 03-05-2010, 01:34 PM   #5
carnz-pj-410
Member#: 110994
1995 Turbo Coupe
Nice write up...
fitting and pipe location are slightly different [inlet/outlet]
carnz-pj-410 is offline   Reply With Quote
Old 09-26-2010, 12:27 PM   #6
2:43AM
Member#: 190273
05 WRX evoIII-16G
Can you please edit and supply the OEM torque spec on the banjo bolt to the pump?
EDIT: iwsti.com lists power steering banjo @ 29 ft-lbs. Sounds reasonable, but I cannot confirm in the service manual.
2:43AM is offline   Reply With Quote
Old 10-17-2010, 09:22 PM   #7
ReD-DaWg-OnE
Member#: 47727
2005 SAAB 9-2x Aero
Red
I followed the directions and am having an issue...
I got the new pump on disconnected the inlet hose from the reservoir as I help my finger over the inlet so the fluid would stay in the reservoir started the car added fluid and started the car.
Once I reconnected it all my wheel is really hard to turn and it looks like there is a lot of fluid being moved around in the reservoir. Also if I turn the wheel right after I start the car it makes a squealing noise.
ReD-DaWg-OnE is offline   Reply With Quote
Old 10-18-2010, 02:29 AM   #8
ReD-DaWg-OnE
Member#: 47727
2005 SAAB 9-2x Aero
Red
So i found that their were a couple of lose lines in the pump, i don't think my pump had the crush washer and i couldn't find where it goes when you install the banjo bolt. Any help would be great!
I think i am going to have to take it all apart again and see where i messed up... I might not have the pully on their tight enough which i guess could also cause the issue.... Also the fluid is moving pretty violently in the reservoir.
Old 01-25-2012, 08:38 PM   #9
whokidd
Member#: 307986
Does this work for an 02' WRX?
whokidd is offline   Reply With Quote
Old 02-23-2012, 10:41 PM   #10
Gamble_WRX
Member#: 234783
2004 STi
it was performed on an 02 WRX... (sniffle) mine.
sorry i havnt edited, i havnt been on much in the past years. im on the lookout for a new subie, hopefully ill find something cheap. and ill edit this tommorrow, i dont have time right now.
Old 02-23-2012, 10:48 PM   #11
alexISonFIRE
Member#: 301474
2002 WRX Wagon
Good write up. Hopefully I'll never have to use it though
alexISonFIRE is offline   Reply With Quote
Old 12-22-2012, 05:55 PM   #12
jlukowski
Member#: 292477
2005 WRX STi
Did you ever figure this out?
jlukowski is offline   Reply With Quote
Old 12-23-2012, 10:25 AM   #13
SubieMonte
Member#: 264803
2005 WRX Wagon
Two crush washers are needed on the banjo bolt. The OEM is a one piece crush washer where both are attached. If that makes sense.
I must not have had mine tight enough because on startup it leaked from the banjo bolt. Gave it a quick snug and it stopped
Replacing the pump was some of the best fun I've had with my Subie in a long time and now my 103000 mile DD has butter smooth steering!
SubieMonte is offline   Reply With Quote
Old 12-24-2012, 03:54 AM   #14
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
I just did mine as well, twice!!!!
First time I was a fool to trust a rebuilt unit from autozone. I put it on, bled it, and bled it, and bled it and so on and so on for two days and the damn thing still kept foaming up and had no power steering. I finally bit the bullet and bought one from the dealer and bled it on one shot and it works perfect, "butter smooth" as you said, no foaming, no issues. When I looked at the one from autozone, it said made in China, I should have known better . At least I got my refund from autozone, but damn, those OEM ones are pricey!
Frankh21 is offline   Reply With Quote
Old 12-24-2012, 02:40 PM   #15
04reddragon
Member#: 216553
2006 wrx sti
gray
yea mine is up its leaking every where and it sucks being cold out and having to turn quick and bammm u cant cause no ps. Nice write up though may tackle this soon. So how long did this take u to do??
04reddragon is offline   Reply With Quote
Old 12-26-2012, 02:35 AM   #16
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
took me about 2 hours first time and about an 1 1/2 hours the second time.
Also I took a few pics for those that want to tackle this and don't have a vice.
I didn't have a vice so I used a socket (forgot the size but whatever fit through the hole in the pulley) and the 19mm wrench to get the pulley off.
Instead of using a swivel socket or uv joint I just pulled off a few of the connectors adjacent to the bolt and used a 3/8" wrench to get at the hard to reach bolt.
Hope this helps anyone that will be tackling this. FYI, buy the OEM pump, screw all the crap from autozone, oreily, etc. The OEM actually came with the pulley, O-rings and pressure switch connector.
Old 12-26-2012, 08:32 PM   #17
jlukowski
Member#: 292477
2005 WRX STi
The OEM double crush washer (a.k.a., "gasket") is part number 34621ac024 for a 2005 STI and runs about $3.50.
Old 12-27-2012, 04:14 PM   #18
04reddragon
Member#: 216553
2006 wrx sti
gray
yea alil too much from the dealer just getting mad every morning when its cold cause it whines and only turning right theres no ps wierd
Old 04-01-2013, 12:14 AM   #19
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
thank you.. this thread needs more pictures.
Anyone know where I can get the steering pump for my 2006 saabaru (same as wrx)? And whats the outgoing price?
Ratchet 3/8 & 1/4
its out!
FLUSH:
amdmaxx is offline   Reply With Quote
Old 04-01-2013, 04:42 AM   #20
Frankh21
Member#: 295776
2005 SAAB 9-2x Aero
The Subaru dealer. About $400 I think
Old 04-04-2013, 08:25 AM   #21
jlukowski
Member#: 292477
2005 WRX STi
I paid $545 for the STI pump at the dealer. Beware that Subaru has changed this pump model number and design 3 times. I have a STI pump that only needs rebuilding. If you are interested PM me.
Old 04-05-2013, 07:51 AM   #22
Gamble_WRX
Member#: 234783
2004 STi
sorry for the lack of pictures, it was my first write up. im impressed this thread has over 14000 views.
Old 04-05-2013, 09:05 AM   #23
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
I think most of this gets covered in the "How to rebuild an STi PS pump" thread... http://forums.nasioc.com/forums/show....php?t=2127419
Initiative is good though...
Old 04-06-2013, 09:22 AM   #24
jlukowski
Member#: 292477
2005 WRX STi
Good catch, I forgot to mention that.
How to break your power steering pump mcraewrx South East Region Forum 3 05-06-2009 09:21 AM
How to tell is power steering pump is 100%? runnah Brakes, Steering & Suspension 2 12-20-2005 01:35 AM
WTB: Power steering pump for WRX/STI 04 Rustyr6 Private 'Wanted' Classifieds 1 09-29-2005 11:30 AM
04 power steering pump on an 02? wrx_snobordr Brakes, Steering & Suspension 3 05-10-2005 01:47 PM
How many bolts hold on the power steering pump on an STi? Physics Junkie Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 01-09-2005 01:07 PM
