Old 02-27-2010, 10:03 AM   #1
RLR257
Member#: 176667
2006 AW WRX Ltd
PPG'd EWG'd & Dom3'd(XTR)
Default Car running lean or no?
The datalog of my friend's car shows his afr's (at idle) are normal, but his fuel trim is high. I read in another forum that if the FT is high then the car is running lean, but if that's the case, then why are his afr's right at or around 14.7? What could be causing this and how do u fix it?
RLR257 is offline   Reply With Quote
Old 02-27-2010, 10:27 AM   #2
Nuke209
Member#: 108089
2003 WRX
NF Performance
post logs/screenshots
Nuke209 is offline   Reply With Quote
Old 02-27-2010, 11:16 AM   #3
RLR257
Member#: 176667
2006 AW WRX Ltd
PM'd you
Old 03-01-2010, 03:31 PM   #4
Cobb Tuning
Member#: 4803
AFR at idle is fine. They typically run lean. the short term trims can be high, but you want to look at the long term trims as this is the overall fueling strategy that the car is employing. That said, at idle there is zero load, so unless the car is DUMPING fuel out the tailpipe, you should be just fine.
Travis
COBB Tuning
sti car runs lean wont stay running =( with (video!) sti3573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 28 12-16-2009 01:24 PM
What can make a car run lean on a stock ECU? Homemade WRX Subaru Conversions 20 06-06-2004 03:21 PM
Which intakes do not cause cause flat spots and make the car run lean? LqSilver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 01-01-2004 10:09 AM
my car run lean whit VF28 MATOU Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 08-27-2003 11:07 AM
Car running lean? help WRC WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-18-2002 12:05 AM
