Welcome to the North American Subaru Impreza Owners Club Monday April 27, 2015
Old 02-27-2010, 03:00 PM   #1
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Default Those Running E85 as Daily Driver
I have done a lot of research on E85 and just wanted to hear some of your thoughts on the reliability of it as a daily driver. Im currently pushing 310hp, 330tq on 93 octane. I have an E85 station a mile from my house. It seems like I have no reason not to get this fuel....but I wanted your thoughts please. A tune for it is $500 and I want to make sure im not making a waste of my money or damaging my motor.
Coop1103 is offline   Reply With Quote
Old 02-27-2010, 04:20 PM   #2
stock06sti
Member#: 190559
2006 STI
Dark Gray Metallic
http://www.camtuning.com/forums/view...php?f=20&t=887
It was good for shaving off a full second off my 1/4 mile time. The only downside yet is that my gas mileage sucks horribly now.
stock06sti is offline   Reply With Quote
Old 02-27-2010, 05:19 PM   #3
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Yea^^^I heard 20% less gas mileage. Is it worth the extra .30cents per gallon less?
Old 02-27-2010, 07:21 PM   #4
capnchunk
Member#: 79791
2007 STI
Here premium is $2.90 for 93 - but E85 is $2.16 at Meijer. I'm sure it's about even when you look at it from the price per mile standpoint. I don't think anyone here is trying to hypermile their STI though. I plan on switching over so I can safely run more boost.
capnchunk is offline   Reply With Quote
Old 02-27-2010, 07:46 PM   #5
lennybootzz
Member#: 190811
04 gt35r built
wrb sti
id wanna do the same thing! With my 35r i need 2 bosch fuel pumps thats the only thing holding me back
lennybootzz is offline   Reply With Quote
Old 02-27-2010, 08:25 PM   #6
synolimit
Member#: 225225
11 WRX
335HP, 394TQ, 93 VF52!!
that sounds like a double negative.
its worth it for the power. if you dont have an AP get a Tactrix cable and have a custom tune done for 93 and E85. OUCH $500 tune?? find a new tuner, wow
if you do the math on my car, 25.5MPG times "15 gallons"=382.5 miles. 15 gallons times $2.90=$43.5
20% less=20.4MPG times "15 gallons"=306 miles. 15 gallons times $2.16=$32.4
you save $11.10 per fill up. to equal the 382.5 miles you'll need an extra 3.75 gallons of E85 which will cost you $8.10. you still save $3.00 per fill up. YEAH E85!!!!
synolimit is offline   Reply With Quote
Old 02-27-2010, 08:48 PM   #7
06 wrx mike
Member#: 175374
2005 Sti
ya running it daily is ok cold mornings suck tho takes me a few trys to get it running but when warm its ok. but i dont have bad gas mileage like others
06 wrx mike is offline   Reply With Quote
Old 02-27-2010, 09:20 PM   #8
Nuke209
Member#: 108089
2003 WRX
NF Performance
drive light foot?
i noticed the e85 guys tend to drive it much harder plus lead foot = really less mileage per tank
have your tuner (or if you've tuned it) change the startup on it.
Nuke209 is offline   Reply With Quote
Old 02-28-2010, 10:08 AM   #9
k mier
Member#: 98000
05 sti e85@420hp
Reliability wise, there should be no difference in running e85 vs gas. Both can become contaminated. I learned my lesson buying gas at wally world. After that incident I only bought gas from a station where I knew what depot the tanker was filling from.
The cost savings is going to come up a wash. The fuel is cheaper, the mpg's are lower. It's not the savings you're after, it's the performance of race fuel w/out the cost.
Don't know what mods you have, so with some uncertainty I'll say fuel pump and larger injectors will be needed if you want to get all the power it has to offer.
lennybootzz Is the twin bosch setup in tank,do you have a link?
Cold morning starts really aren't bad.....if you have a tuner that knows e85. With that said...with temps 30-40 degrees my car is a bear to start, four or more tries, with temps of twenty or lower the car starts first try. If it's zero...first try every time. If the tuning is spot on you will have no problems, if, like me, your tuner isn't perfect you'll have problems as it seems getting the e85 mix to light off is much harder than gas.
06 wrx mike What kind of mpg's are you seeing? What are your a/f's while cruising?
I have heard e85 is harder on motor oil than gas. I've done two blackstone tests, neither showed anything to worry about due to e85.
IMO, this is the biggest, "thing", with e85...lower mpg's, small tank and scarcity of e85 stations mean you will need to carry extra fuel on long trips....can anyone say die in a fiery crash???
...and don't forget to read the e85 fact in the tuning section, yes it's longer than a steven speilberg but it's a better read. http://forums.nasioc.com/forums/showthread.php?t=803341
k mier is offline   Reply With Quote
Old 02-28-2010, 07:41 PM   #10
06 wrx mike
Member#: 175374
2005 Sti
well my mpg are from 16 to 20 mpg when i get on it its like i have to go fill up in the next two days. I have noticed that people that have diff injectors will start up better or worse than mine. i love running e85 like how the car feels but my car is far from stock so it does not feel like a stock subi. Have beatrush motor mounts and they feel solid so when it is hard to start its like the car is falling apart.
Old 02-28-2010, 07:44 PM   #11
bloodninja
Member#: 238707
Why the heck would anyone hypermile an STi? You don't get a high performance sports car for the mpgs LOL.
I can understand trying to get more HP and TQ from it, but if you want more mpgs, a different car would be in order.
bloodninja is offline   Reply With Quote
Old 02-28-2010, 07:44 PM   #12
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Less chance of blowing your motor due to detonation, thats for sure, so that puts it "more" reliable.....
while I may only get 11-14 mpg when having fun.... Its only $2.19 gallon...
Old 02-28-2010, 07:54 PM   #13
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
thats really odd.
+12345 and is a really clean fuel
Old 02-28-2010, 10:54 PM   #14
k mier
Member#: 98000
05 sti e85@420hp
Originally Posted by juanmedina View Post
thats really odd.
Odd yes, one would think it should be the other way around. Makes me think the cold start for those temps needs some adjustment.
06 wrx mike 20mpg, lucky. With slowerthanmostofyou driving I'm lucky to average 17.
Old 03-03-2010, 07:04 PM   #15
Subarosity
Member#: 221845
01 2.5rs
white
I've heard of the E85 eventually eating through fuel lines and what not that aren't made for it does anybody know if this is true or just another myth floating around?
Subarosity is offline   Reply With Quote
Old 03-03-2010, 07:15 PM   #16
oldskoolWRX
Member#: 66248
1983 turbo brat
black and white
[quote=juanmedina;29908662] thats really odd.
it is always a bear to get extreme cold start right as ethanol falls out of vapor under 34 degrees F. we have an e85 syclone that wants 4 cranks on a cold day (below 30) and spits liquid out the pipe. our high compression 2.0L wagon wants 5 or so, unless you spike the tank with a gallon or two of 87. that is with nearly maxed cold crank adjustment. block heater helped, slightly.
false, but a grain of truth like anything. automakers will tell you it will ,but that is primarily because they have only pushed development of "flex-fuel" vehicles. i have seen a certain shop actually soak fuel lines, hoses, pumps/etc for extended periods in both e85 and e98. with no noticeable problems of corrosion. that said, the grain of truth is that ethanol absorbs water over time, the longer it sits, the more it absorbs. it isn't the ethanol that is the problem at that point, but the water.
although we have had multiple walbros go out when fed a diet of 100% e85...
+1 on oil issues, we have actually seen less contamination in the oil on the truck, haven't sent a test for the wagon yet...
oldskoolWRX is offline   Reply With Quote
Old 03-03-2010, 11:04 PM   #17
k mier
Member#: 98000
05 sti e85@420hp
[quote=oldskoolWRX;29947497]
thats really odd.
When it absorbs enough water and sits long enough it turns to frog snot.
The cold start issue...tells me my start maps are off since mine starts better the colder it gets.
IIRC, the fuel systems of most cars manufactured after the mid 80's is safe for ethanol blended fuels.
It WILL kill the fuel lines of a cub cadet lawn tractor though.
Old 03-08-2010, 05:37 PM   #18
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Does anyone switch the maps often between the E85 map and the 93 octane map? Didnt know if you switched it often that it would mess with your engine?
Old 03-08-2010, 06:09 PM   #19
arghx7
Member#: 232940
The problem with the cold starts is that the Subaru ECU was not engineered for E85 so it doesn't have proper correction tables. Aftermarket implementations of E85 are vastly inferior to OEM ones. Let's talk about the cold start issue for a second. Here is the cold start control strategy on a flex fuel GM vehicle.
First is the cranking target AFR, displayed in lambda. This map is for a full E85 blend, and then it is scaled based on how much ethanol is detected in the tank:
So the cranking fuel is adjusted based on ethanol blend. But there is one more correction:
This is another cranking fuel adjustment based on coolant temperature.
arghx7 is offline   Reply With Quote
Old 03-09-2010, 07:22 PM   #20
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
I guess a really important question i have is this...if i plan a trip I will obviously not want to run E85 for the risk of no stations. Can I simply reflash to my 93octane map before going. Then upon return flash back to E85 when ready to fill up again?
Old 03-09-2010, 07:27 PM   #21
arghx7
Member#: 232940
you can do that but as you switch from one fuel to the other (normal E10 vs E85) there may be some variation in the tune because the two fuels are mixed together
Old 03-09-2010, 07:32 PM   #22
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
Right, obviously i would take my tank down to as empty as i can get it....still wouldnt help? Or am i better off buying a siphon...and draining it while at the gas station..lol
Old 03-09-2010, 09:06 PM   #23
juanmedina
Member#: 133146
07 FPgreen 7.37@95
You worry too much!
Just run the car without boosting too much and get it as empty as possible, fill it again with 2 gallons of gas or E85 run it to empty, and repeat that one more time. And then happy boosting .
Old 03-10-2010, 02:02 AM   #24
Coop1103
Member#: 162063
2007 STI FR TS 8374
UGM
^^^you just lost me...
Old 03-10-2010, 04:13 AM   #25
rexblake
Member#: 178426
2010 Audi S4
No need to drain. I switch all the time, 93 for long trips if I'm worried about gas stations or want better gas mileage. I just run it as low as possible and switch. Usually try not to go crazy with boost on the first tank of E85, wait till the second to really hit it hard. As for switching back to 90 whatever the E85 that's left in the tank is just going to up the octane, no harm with that.
rexblake is offline   Reply With Quote
Any STi owners that use their cars as daily drivers have any regrets? RUKnight Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 138 11-25-2004 02:38 PM
opinion: getting Falken AS as daily driver, is it overkill? twlai Tire & Wheel 12 04-01-2004 08:14 AM
Truck as daily drivers? UKS Southern California Impreza Club Forum -- SCIC 12 09-17-2003 11:21 AM
