Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 02-27-2010, 06:05 PM   #1
904scooby
Member#: 151518
2005 18g'd WRX
CGM
Default Street Mod.
Are fender braces legal in the street modified class in SCCA?
Read the rule book twice now and it doesn't seem that it is outlawed.
904scooby is offline   Reply With Quote
Old 02-27-2010, 06:37 PM   #2
motocooney
Member#: 176235
09 Mazdaspeed3
I was under the impression that pretty much anything goes in Street Modified. Is that not the case?
motocooney is offline   Reply With Quote
Old 02-27-2010, 06:49 PM   #3
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
I'm 99.9% it is not legal. The rules are written such that if it isn't mentioned as legal, it isn't allowed. I think 17.2B under Prepared class is where it would be legal.
Not the case at all.
Ruff is offline   Reply With Quote
Old 02-27-2010, 07:42 PM   #4
904scooby
Member#: 151518
2005 18g'd WRX
CGM
OK, yes many people are under the impression that SM is a catch all, but that is not correct.
Thanks Ruff, let me check 17.2 again...
Old 02-27-2010, 08:03 PM   #5
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
really whos going to contest something they will never see. And your really only upgrading whats already there. You have increased spring rates that you need the additional bracing 10k+ springs?
scby rex is offline   Reply With Quote
Old 02-27-2010, 08:25 PM   #6
904scooby
Member#: 151518
2005 18g'd WRX
CGM
yep 11k, 9k springs on cusco coilovers... It may not really provide that much difference but its not expensive to do...
Old 02-27-2010, 08:51 PM   #7
Ruff
Member#: 32131
2006 Nissan 350Z
Was 01 2.5 RS
Old 02-27-2010, 09:32 PM   #8
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Fender braces are illegal in SM. If you had an STI you could put on the stiffer 07 STI ones via UD/BD though
pignoseSTI is offline   Reply With Quote
Old 02-27-2010, 11:44 PM   #9
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
Today I was asked about why I didn't upgrade my fender braces while putting on my new GC/Koni suspension and my lame excuse was that it wasn't SM legal for SCCA autox.
Hey, when are we going to get an SM sticky thread? Someone start one so I don't have to rely on the ESP/BSP/DSP/FSP/Project Mccanixxx build threads for what works and blah blah blah....
fwiw, 285/30/18 v710 on 18x10 +30 worked on my WRX Wagon today. This was with camber and caster maxed on GC camber/cater plates an slightly lower than stock ride height. They do stick out from the fender a wee bit though LOL!
And how about turbo choice.?.?.? I have a vf43 and I love the fast spool but what can give me that low end with more power on a built 2.5?
See, we need a sticky thread!!!
mulva is offline   Reply With Quote
Old 02-28-2010, 12:11 AM   #10
904scooby
Member#: 151518
2005 18g'd WRX
CGM
At a local meet its not going to be challenged, at a national meet, its definitely going to be challenged. It is illegal, I've confirmed it with several people now.
Mulva, I'll pm a mod I know and see what I can get done about that. I'd like to see one too.
Old 02-28-2010, 12:29 AM   #11
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
Nice!!! I think we deserve one and I think a serious effort with the Impreza platform can make some noise nationally. Locally/Regionally, I see a lot of Impreza's in SM and a good sticky here can really help us out if we want to stay in class and be competitive.
Tom
Old 02-28-2010, 12:56 AM   #12
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
+1 for a SM thread! I would love to find out what others are doing compared to me
Old 02-28-2010, 11:17 PM   #13
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
Well, we're stickied now!!!
Here's what I'm going with this season:
2002 WRX Wagon
257 short block
205 heads
vf43
STi TMIC
STi 565cc "pink" fuel injectors
Walbro 255lpm fuel pump
Full 3" Turboback w/ HiFlow Cat
Catless Uppipe
Cobb AP1 w/ Protune @ 18psi 310tq/280hp
Samco inlet
Stock Airbox
Stock Solenoid
Ground Control Complete Coilover Kit w/Koni 8611 DA's
Eibach Springs 800 lb front/600 lb rear
Ground Control Camber Plates f/r
Hotchkis 25mm hollow sways f/r
Hotchkis solid endlinks front
Kartboy solid endlinks rear
Whiteline Rear Strut Mount Brace
Whiteline Rear Adjustable Control Arms and Lateral Links
2007 STi 6MT
ACT HD Street Clutch
ACT StreetLite Flywheel
Carbonetic Rear 1.5 way LSD
TiC Klunk Killer (race)
TiC Tranny crossmember bushings
Kartboy Shifter bushings
Cusco Engine/Transmission mounts
Whiteline Steering Rack Bushings
Centric Rotors
Hawk HP+ Pads
ATE Brake Fluid
Rota SVN-R 18x10 +30
Kumho V710 285/30/18
OZ Allegarritta 17x8
Dunlop Star Spec 245/40/17 (flood conditions )
Odyssey PC680MJ Battery
Camber: -3.3* front/-2.2* rear
Caster: 3.5*
Toe: 0
Ride height: 14.3" front/14.2" rear
Some pix can be seen here:
http://azpinstalls.com/gallery/main....c/P1080341.JPG
Tom
Old 03-01-2010, 01:12 AM   #14
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
The GC plates are great! When I first put them on with the stock camber bolts I was around -5 degrees in front hahaha. Copied over from my IWSTI journal
Engine Mods
- Custom rotated mount uppipe and downpipe
- Garrett gt3076r .63 ar turbo jethot coated
- Tial 44mm wastegate
- Tial Q BOV
- PTP turbo blanket
- Custom 4” intake
- Gruppe-S equal length header
- Turbosmart Dual Stage MBC
- Perrin FMIC with stock bumper beam
- Perrin lightweight crank pulley
- Walbro 255lph fuel pump
- 07 STI top feed fuel rails
- 07 STI tgv deletes
- Hondata intake manifold gaskets
- RC engineering 1200cc injectors
- Full 80mm Magnaflow Ti catback exhaust with Burns Stainless mufflers
- Crawford Performance air/oil separator
- Hydra Nemesis full standalone
- Tune by Mike Warfield(GST Motorsports) on E85 fuel
- Odyssey pc680 battery
Suspension
- Ground Control coilovers with Eibach and Hypercoil springs
- koni 8611 double adjustable shocks
- Ground Control camber plates front and rear
- Whiteline 27-29mm swaybar front and rear
- Kartboy rear endlinks
- Group N lateral link bushings
- Superpro trailing arm bushings
- Whiteline roll center adjusters
- Whiteline caster bushings
Driveline
- ACT hd street clutch
- ACT streetlight flywheel
- Group N motor and transmission mounts
- TIC race rear differential bushings
- TIC outrigger bushings
- Cusco type rs 1.5 way rear LSD
Exterior
- Genuine V-limited front lip
- Rolled and pulled front fenders
- Extreme pull on rear fenders
- Passenger side foglight housing
Interior
- Sparco Evo2 driver side seat
- Sparco Pro2000 passenger seat
- Buddyclub super low down seat rail(driver)
- Wedge engineering/Sparco rails/sliders with aluminum sidemounts(passenger)
- Innovate Motorsports LC-1 wideband with XD-16 gauge
- Defi BF boost and oil pressure gauges with controller
- ATI gauge pod
- Rear seat removed
Wheels/Brakes
- SSR Type C RS 18x10.5” with Hoosier A6 295/30/18 tires
- Stoptech front rotors
- Hawk HP+ pads front and rear
Karlton
Old 03-01-2010, 11:47 AM   #15
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
Yeah, my 5 year old son asked what was up with my broken wheels. With the skinny 205 all-seasons on the car right now it just looks weird.
I only took about a 20 mile ride since putting the coilovers on but the Koni DA's aren't that bad with the big spring rates. I haven't messed with the damping yet so it might be set to full soft, but still I was expecting these to be harsh from what Marc from GC was describing to me.
Your car looks very set up even for SM. Sick!!! I'm getting there, but I'm going to see how I do with my current setup before putting more $$ into it. What's your power band like with the rotated 3076 and E85? Last year I was on street tires with 1.4* camber and RCE springs so stage 2 STi power (93 octane) was plenty but with everything stiffer, more camber, and big r-comps, I may be able to use more power than I have now. My local courses are mostly asphalt though.
Old 03-01-2010, 05:34 PM   #16
904scooby
Member#: 151518
2005 18g'd WRX
CGM
stickied we are.
Lets see a couple more setups and I'll be posting mine shortly
Old 03-01-2010, 08:29 PM   #17
904scooby
Member#: 151518
2005 18g'd WRX
CGM
Default Tony's 2005 WRX SM setup
Engine Mods:
HKS hipower exhaust
ERZ downpipe(heatwrapped)
Gutted up-pipe
FP td-05 18G
2008 STI intercooler fit to work with sti scoop and splitter bellows
DW 750 Injectors
1 step colder iridium spark plugs
silencer delete
K&N drop in filter
UTEC tuned by my future father in-law via UTI (Jeff's software)
GMS aftamaf and turbo inlet
Perrin Radiator shroud
Cobb turbo heatshield
Wlabro 255
Innovate LM-1 Wideband
Currently running Hallman MBC but will be switching to grimmspeed ebcs
Suspension and Brakes :
Cusco zero 2r coilovers 11k, 9k springs
Eibach Camber bolts
Goodridge SS brake lines
04 STI Front Brembo brakes
DBA 400 series slotted rotors and EBC yellow stuff pads
Wheels and tires:
Drag DR-31 gunmetal 17x9
Yokohama Advan A032R 255/40/17
Old 03-02-2010, 11:47 PM   #18
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
I can get full spool around 3800 rpm and keeps pulling to redline. It's about as big of a turbo as I would run for autox. If e85 was available when I did all this turbo stuff, I probably woulda just stuck with my stock turbo or maybe an 18g or something. e85 is fun stuff
Old 03-03-2010, 09:56 AM   #19
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
2000 Impreza #65 SM from the Ohio Valley Region
Engine:
EJ207 from a 2002 Spec-C RA
Stock VF30 ( )
K&N Typhoon intake
APS hard inlet pipe
Grimmspeed intake manifold spacers
Catless wrapped DP
Maddad Whisper catback
Fluidyne radiator with single fan
Dual catch cans
Perrin EBCS
Walbro 255
Ecutek tune...soon to be opensource tune
Drivetrain:
JDM 6-speed non-dccd
Stock clutch FTW (will need replacing later this year most likely)
Unknown flywheel that weighed 18 lbs when I was building the car
Kartboy short shifter with all bushings
05 hub conversion
Brembos
Hawk HP+
STI Brake Booster and MC with brace
Carbonetics 1.5 way rear LSD
Factory front and center diff
Suspension/Chassis
ZZYZX Coilovers
850 lbs front springs
700 lbs rear springs
Noltec front and rear camber/caster plates
Cusco sway bars with upgraded mounts and endlinks
Front and rear strut braces
All bushings replaced by either Group-N or Poly
Whiteline RCA kit
Q-Rack 11.5:1 quick steering rack with solid mounts
Cusco engine and trans mounts
Rota Grid 18x10 +35
Kuhmo V710 285/30/18
JDM Aluminum arms with whiteline offset bushing and "free caster mod"
Storm Fuel Tank Mod (can still only run down to half a tank before it starves)
Exterior/Interior:
a bunch of bits from the Ver 6 STi (grill, aluminum hood, lip, spats)
Carbon fiber trunk painted to match the body
Fog lights removed and covered
JDM Ver 7 interior (thinking of going fixed back for this year and selling the Ver 7 stuff)
Momo competition wheel
All air bags and associated hardware removed
All air conditioning hardware removed (except the stuff behind the dash of course)
All cruise control hardware removed
Various other lightening done throughout the car.
Total current race weight wet (without me) 2910 lbs
I figure with sunroof removal and fixed back seats I can get it down to the class minimum of 2820 for a 2.0 AWD turbo car.
Here's a few pics from last year when I ran the street mod street tire local class. There's a few changes for this year, but outside of the wheels most people won't notice a difference.
subydude is offline   Reply With Quote
Old 03-03-2010, 11:46 AM   #20
mulva
Member#: 62539
2002 WRX Wagon
2009 Impreza OBS
I can get full spool around 3800 rpm and keeps pulling to redline. It's abnout as big of a turbo as I would run for autox. If e85 was available when I did all this turbo stuff, I probably woulda just stuck with my stock turbo or maybe an 18g or something. e85 is fun stuff
Sounds nuts!!! Unfortunately, NJ doesn't have any e85 stations. I am however, in the process of selling my home and moving to the Philly area where I think there are a couple e85 stations close by. When I revisit power mods I had my eye on a Blouch TD05H-18G 8cm with bigger injectors, TMIC, catless downpipe, intake, boost control, and possibly EWG. It would give me a fatter powerband with higher peak numbers but it's expensive. I'm probably going to ditch the AP v1 and do something else for EM also. I would LOVE to have GT3076r type power though so now what do I do LOL?!?
Old 03-04-2010, 02:03 AM   #21
sti4rs
Member#: 211057
2006 STI
Matte Black
Can someone confirm this is true? If so, how much of a difference would this make on an 06 STI?
sti4rs is offline   Reply With Quote
Old 03-04-2010, 04:01 AM   #22
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
which part? That they're illegal or you can ud to the 07 sti ones? If the latter yes it's true because you can ud to them in BSP and those rules carry over to SM
Old 03-04-2010, 10:13 AM   #23
subydude
Member#: 80649
Unfortunately for anyone with an 01 or down you can't update though since the cars are on different lines. Means us old car drivers get the factory flimsy ones.
Old 03-04-2010, 10:23 AM   #24
Dirty25RS
Member#: 56731
2004 STi, 00 Insight
10 Volvo C30R-d 11 F150
E. Suspension components are unrestricted as long as they use the
original attachment points. For the purposes of this rule, “suspension”
is defined as any item that is designed to move when a wheel is
deflected vertically. This includes shocks and struts, control arms,
steering knuckles, uprights, etc., but not tie rods, steering racks, and
subframes. In addition, shock absorber/strut upper mounts are to be
considered suspension components.
ALK legal or not?
Dirty25RS is offline   Reply With Quote
Old 03-04-2010, 10:27 AM   #25
Chiketkd
Member#: 71634
In hibernation...
Originally Posted by Dirty25RS View Post
ALK legal or not?
Not legal for SM as it changes the suspension geometry iirc. Bumps you to Prepared (FP and/or XP).
Chiketkd is offline   Reply With Quote
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
