Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 12-04-2012, 11:44 PM   #476
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Originally Posted by Claymra View Post
To give some background here is my current list of work done to the car. Thanks for any input on easy things I could do to improve the low end performance of my car/ exit speed out of turns.
-COBB accessport v2 (running protune from Epic Motorsports)
-Helix catless DP (3 inch)
-Helix catless up-pipe
-JNA performance catback (3 inch)
-Mishimoto aluminum radiator
-Cobb SF Intake
-STI TMIC
-COBB turbo heat shield
-Samco Intercooler hose
-Perrin turbo inlet hose
-One step colder spark plugs
-VF43 turbo
-Warlboro 255
-STI 560cc injectors
-Protune 284/274 mustang dyno
Suspension bits:
-Tockico D-Specs
-Prodrive Blue springs (pretty sure they are 175lb/inch F&R)
-JDM V7 Tophats F&R
-Whiteline steering rack bushings
-17X8 OZ Ultraleggeras
-245/40/17 Goodyear Eagle F1 Asyms
-Kartboy short shifter
-TIC shifter bushings
-22mm rear swaybar set to full stiff(has 3 adjustments so 23mm?)
24mm front swaybar set to full stiff(has 2 adjustments so 25mm?)
-Kartboy rear endlinks
-05WRX swaybar mounts (with whiteline bushings)
I currently am running 5.75 TFFS on the front and 6.25 TFFS on the rear of my Dspec shocks. I wouldn't mind switching over to RCE yellows or blacks. Just not sure which way I want to go yet...
I ran 35PSI in my tires at this past event and kept an eye to keep them between 35 and 36 PSI during my runs. Is that a good pressure for a full weight WRX on 245/40/17? I don't think they were rolling over much.
Pretty sure my alignment is -1 front and -.5 rear.
Any suggestions for a good alignment that is still daily driver friendly- or would it be best to stay the same?
Thanks for any help.
Clay
You need camber....badly. -1 up front isnt gonna cut it. Also, you need a strut mount without any rubber in it. The group N mounts are nice for street...but you want something solid (like pillowball mounts) so the car doesnt push and you can carry more speed through corners. Stiffer springs are needed...but in the form of an adjustable coilover so you can corner balance the car and set preload. You will also never survive in SM without slicks. A daily driven SM car is very hard to do.
I got railed into sm when I started to due to my mods. I feel ur pain...its a very hard place to start.
Squidz is offline   Reply With Quote
Old 12-05-2012, 09:53 AM   #477
jprice130
Member#: 288225
2013 FR-S
Hey Clay, this is Joe, the guy with the BRZ that was talking with you during our work assignment this past weekend. It was great to meet you and I thought you did awesome, given your experience, the fact that the course was not turbo friendly, and given that your tires are not the best for your class (or AutoX in general).
Like others have said in this thread, I'd focus your updates on getting your car to corner faster rather than spending a bunch of money on your engine/turbo/tune. I got the impression that you enjoyed your tune around town, so I'd just leave that stuff be and concentrate on getting better tires, stiffer springs for your D-specs, and getting some camber plates for camber adjustment. You will see a big improvement with those changes alone and it will prevent you from having to spend the same money you've already spent on your turbo upgrade and tune.
Also, if you get a chance to come to events at ZMAX, CMP, or Black Lake/Michelin Proving Grounds, you'll definitely reach higher speeds on those courses and get to stay in boost longer. I hope to see you at some events next season! Joe
jprice130 is offline   Reply With Quote
Old 12-05-2012, 05:39 PM   #478
04trailsti
Member#: 179170
Theres one in SC this saturday @ CMP.
04trailsti is offline   Reply With Quote
Old 12-05-2012, 06:22 PM   #479
Claymra
Member#: 83167
2002 Wrx
MBP
^^ I am going up to that one. Pretty excited about it as I did the Subaru showdown earlier this year and had a ton of fun.
Joe thanks and it was good meeting you too. Putting more into the suspension/tires of the car does make sense. I still dream of an e85 tdo4 running ESP though (if e85 is allowed- I have not looked into it)
Hopefully I can at least get on some RCE yellows, or ground control sleeves0- something stiffer for next season. Ill probably max out camber with what I have now and invest in camber plates for the front in the future. They seem to be pricey.
What max camber can you run on my car? I think I have read 1.5 or 2 deg total up front? I have the camber bolts for the rear. They will allow .5 total right?
As you can tell I am new to actually taking auto-x serious and any help is appreciated.
Thanks!
Clay
Claymra is offline   Reply With Quote
Old 12-05-2012, 06:55 PM   #480
polyol
Member#: 73422
04 STi
JVP
Camber bolts + camber plates up front will give you as much as you want. I run 3 degrees of camber in the front and 1.5 degrees of camber in the rear, but that is a subjective too. I would aim for 2.5 +/- 0.5 degrees up front and 1.0 +/- 0.5 in the rear.
If you are going coilovers and have a choice of springs...500 front and 400lb rear make for an OK street and creditable Autox setup.
polyol is offline   Reply With Quote
Old 12-05-2012, 10:54 PM   #481
Claymra
Member#: 83167
2002 Wrx
MBP
What max camber is capable out of my dspec shocks without camber plates do you think?
Old 12-05-2012, 10:56 PM   #482
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
-1.5ish depending on what camber bolts you run. If stock, -1.2 or so.
I was actually in the red DSP BMW at the event, so no problems with turbo lag there
subydude is offline   Reply With Quote
Old 12-05-2012, 11:10 PM   #483
Claymra
Member#: 83167
2002 Wrx
MBP
^^ That thing rocked! You going to CMP this weekend?
Clay
Old 12-06-2012, 12:03 AM   #484
Leafy
Member#: 330625
2006 WRX
Only 3* of camber with McStrut? For a car with slicks? Do subies get a lot more camber gain than most other McStrut cars? Because 3* is about what we run on the front of miatas with 275 slicks.
Leafy is online now   Reply With Quote
Old 12-06-2012, 08:04 AM   #485
subydude
Member#: 80649
-3 degrees is a good starting point. It really depends on suspension and lowering. To many variables to determine before giving a good answer. I know I run more than -3 in the front now.
Clay, I'm going to the Chump race at Road Atlanta this weekend.
Old 12-06-2012, 11:07 AM   #486
polyol
Member#: 73422
04 STi
JVP
I would hesitate to run over -3.5 in the front...could hurt braking...you can always have too much of a good thing.
Old 12-06-2012, 12:01 PM   #487
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Brakes just make you go slow.
RS_to_WRX_swap is offline   Reply With Quote
Old 12-06-2012, 02:30 PM   #488
subydude
Member#: 80649
I'd probably limit it to 3.5-3.8ish. There are points in the setup where you realize that to much of something is a band-aid for an issue elsewhere and once you've fixed the other issue you don't need as much camber.
After spending some time in an STS Miata this year, I can't agree enough
Old 12-06-2012, 02:50 PM   #489
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
That's where I was at this year. Stock front sway, too low in the front, and skinny (225/40/18) tires on skinnier wheels (7.5"). I was running 1.5 degrees on maxed out camber bolts with my camber plates centered, then for autox days, I would max the camber plates out before my runs, and set them back to center before I drove home. But I worked with what I had. There are plenty of changes happening to remedy those problems.
T-37 is offline   Reply With Quote
Old 12-06-2012, 03:58 PM   #490
Claymra
Member#: 83167
2002 Wrx
MBP
^ So it sounds like with camber plates its pretty easy to adjust them quickly for performance at an event? I assume that you just get the front of the car in the air and change settings on the plates themselves --no messing with strut bolts to wheel hubs right?
I am new to all this stuff- sorry if that was a dumb question.
Clay
Old 12-06-2012, 04:00 PM   #491
subydude
Member#: 80649
Clay
That's generally correct for how to adjust camber plates. It varies from plate to plate. Toe changes when you add camber that way as well, so finding out what your toe is at "street setting" and then at "autox setting" is important. You can also find out how many turns on the tie rod are needed to go back to 0 toe. Alternatively, some people prefer the toe out that's added. YMMV.
Old 12-06-2012, 04:01 PM   #492
Leafy
Member#: 330625
2006 WRX
My last car with McStrut I had to slot the struts for more camber because I didnt want to change the SAI and scrub radius by using the camber plates. And NO you cannot adjust camber at the bottom of the strut without being on an alignment rig, your toe goes all over the place. At least with the camber plates it changes the samish (at least the same direction in or out rather than left to right) on each side.
Old 12-06-2012, 04:18 PM   #493
subydude
Member#: 80649
Devils advocate and all, but I use a very simple camber gauge and a level when needed to set things up. Then some string and a few jackstands.....
But yes, alignment rack is probably better
Old 12-06-2012, 04:21 PM   #494
T-37
Member#: 175624
1234 RIGHT IN THE
SYRUP
I just lived with the added toe. Never bothered to measure it. It looked like a lot.
Old 12-06-2012, 05:18 PM   #495
04trailsti
Member#: 179170
Im getting a taste of SM saturday, Ill be in Evo Joe's Evo although only street tires it should be fun. Last weekend I was in the Black STR S2000 #8.
Old 12-06-2012, 05:20 PM   #496
polyol
Member#: 73422
04 STi
JVP
On the camber plates...I have mine set to 2.3 degrees camber on the street...then I slam the plates at the track to give me 3 degrees of camber. This also induces 1/4" of toe out. For my track that is fine as it does help with initial turn in. On a high speed track it would suck, but for the speeds my club runs at, its fine.
Old 12-06-2012, 05:26 PM   #497
04trailsti
Member#: 179170
We did the same thing for em99sport at NCAC on his last run it was his last ditch effort to beating a full prepped STU car. So we maxed out camber later found out it was 6+degrees of neg. camber.
Old 12-06-2012, 05:54 PM   #498
polyol
Member#: 73422
04 STi
JVP
lol...did it help?
Old 12-06-2012, 06:52 PM   #499
04trailsti
Member#: 179170
Yes after day 1 he had a .5 lead with his normal ~3* set up. Then his competition picked up over a secand on day 2. Thats when he had to go for it and with the 6* he also picked up over a second. He also said he dtove a little faster but I think camber helped a lot.
Old 12-06-2012, 09:30 PM   #500
Claymra
Member#: 83167
2002 Wrx
MBP
Just checking on something...
I have blown out the liquid filled bushing on the rear of my front control arms... I need replacements and would love to go ALK for that if it was allowed in "normal" auto-x classes...
I am thinking about getting these for replacements since it seems like I could install them myself because its a replacement of the entire unit and I would not need to press the stock bushings out of the brackets...
https://www.subarugenuineparts.com/p...roducts_id=746
Anyone used these? Also I wanted to double check they are SM legal also. From what I have seen they are.
Thanks for any input,
Clay
Will my trans swap put me automatically in Street Mod? RebelINS Autocross 6 07-22-2013 05:24 PM
I'm still legal for Street Mod right?(list inside) Davenow Motorsports 4 05-24-2003 03:21 AM
street mod tire question Jaxx Motorsports 2 02-20-2003 07:59 PM
Autocross class... Street Mod? Motohead1 South East Region Forum 11 06-26-2001 10:11 AM
Street Mod news Eric Technical Forum Archive 5 05-31-2000 02:33 PM
