Old 11-06-2010, 04:57 PM   #676
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i checked them all 3 times...def a strong 170 on the button. the 140 could have been a 145.
also the plugs were all good , i mean a light white/gray, not crazy lean, but cylinder 3 what much darker than the rest, it looked rich but still within reason.
the shortblock came from a ej255 that was used less than 5000 miles from phoenix racing.
i honed the cylined but that was the extent of it. the motor was not blown. no broken ringlands, as a matter of fact i reused the rods and crank. the only thing i could find wrong with it was the oil pressure sender on the top front of the engine was cross threadedand leaking. i repaired , retapped and lock tighted that. no leaks.
cosworth pistons, rings were new. everything was assembled to spec. i built the engine alongside jodie while he built a different engine. one step at a time , paying attention to every detail and torque setting. assembly lube and engine building oils were used...
i only have 600 miles on the motor...is it possible cylinder 3 is still breaking in, or was my break-in complete after a couple of heat cycles?
maxpowr is offline   Reply With Quote
Old 11-06-2010, 05:03 PM   #677
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
3 on left 1 on right
Old 11-06-2010, 05:10 PM   #678
69subaru360
Member#: 159682
1995 WRX
2015 F150
Could have been a few things. Honing pattern wasn't correct for the rings. Cylinder walls could be ovaled or have high/low spots. Gaps on the rings could be off. Rings could be upside down. Gaps on the rings could be lined up. Could have washed the cylinder walls with fuel during break in.
The leakdown will tell you more. But I suspect it will be leaking past the rings.
Old 11-06-2010, 06:08 PM   #679
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
I don't see how leaking rings will net him a higher number on the compression test.
RFoy91TSi is offline   Reply With Quote
Old 11-06-2010, 08:27 PM   #680
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
What cylinder # does the 170 psi correspond to?
Old 11-06-2010, 08:34 PM   #681
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Never mind, I see. I bet if you looked in that piston with a borescope you'd see a **** load of build up on that piston top. This is just a shot from the hip but I would say that's where the majority of your oil is being consumed. Probably a leaky valve seal. If you could, pull both manifolds and look for the valve stem with oil and crud built up around it. That would probably explain the color of #3 plug also.
This is not a diagnosis just what I would check
Old 11-06-2010, 11:57 PM   #682
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
also didn't realize that compression test cold and hot would yield different results...
those results were taken from an ice cold car.
600 miles and i built up oil and carbon? i have lost very little oil from the system. i'd bet the only oil i lost is what we saw on the ground.
the cylinders had crosshatching. i ground the rings with a very fine file to perfection. rings are not upside down and were staggered properly. cylinders washed with fuel during break in? i don't even fully understand that.
leakdown to follow. compression test on hot engine to follow.
i do have access to a scope. i am not too proud to learn and share from a failure, but i really think this is a lot of over reacting.
i pulled the pcv from the turbo inlet and put it in a bottle with holes in the top. i can feel air pushing out of the holes. i drove 50 miles...no oil in the bottle.
congratulations to jodie and tara ritchie
Old 11-07-2010, 03:30 AM   #683
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Dr. J racing FTW.. Congrats my dude!
Drunk in South Beach
Jr
Junior2JZ is offline   Reply With Quote
Old 11-07-2010, 06:18 AM   #684
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I think a 30 psi variance of compression and one plug of three that looks like that all from the abnormal cylinder in a car that for some reason is a pain to tune and knocks is cause for concern. Don't you? If you don't cars get really expensive fast.
Old 11-07-2010, 08:34 AM   #685
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i am concerned thats why i'm posting about it. i like logical facts not maybe's. i'm not pulling the motor and reringing a piston without more information.
Old 11-07-2010, 09:00 AM   #686
1breel
Member#: 189314
2002 GGSTi
01G
what was done with the heads? Granted for me, every low reading from a comp and or leak down test was from busted ringlands but most also had burnt exhaust valves. Smart money says pull it now because it will cost more if you scatter it.
1breel is offline   Reply With Quote
Old 11-07-2010, 11:39 AM   #687
02WRX2.5
Member#: 63192
02 wrx
161mph Trapspeeds
My experience says pull it, eitheir way you have work to do. Sounds like a couple bent exhaust valves leaking into your cylinder. If you sense something is wrong its your car you know it best. Things will get more expensive from here if furthur damage is done.
Goodluck.
02WRX2.5 is offline   Reply With Quote
Old 11-07-2010, 12:46 PM   #688
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
So bent or leaking exhaust valve is causing high compression in cylinder 3?
Old 11-07-2010, 03:06 PM   #689
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Nobody will be able to tell you for sure. Thats why you gotta pull/open the motor and go from there. It sucks but it has to be done dude. You can do more test to see where its proly coming from but at the end of the day you'll end up yanking the motor.
Old 11-07-2010, 04:49 PM   #690
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i hear you guys...nobody likes bad news. i'll get a scope and some pictures this week. if its the valve i'm gonna be swollen.
Old 11-07-2010, 06:00 PM   #691
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
had fun at the millville rally with the boys and the subaru's...
Old 11-07-2010, 08:09 PM   #692
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
I was so pissed when I was driving to Drill this morning. going 295 north I saw 15-20 subaru all headed south to millville
Old 11-07-2010, 09:56 PM   #693
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
we missed you there, ralph...i saw you when we got back! well i heard you first.
Old 11-08-2010, 10:28 AM   #694
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
No horn so I had to do the ricer rev!
Old 11-08-2010, 11:48 AM   #695
T3RMIN4L
Member#: 37434
I know the ricer rev all too well!
T3RMIN4L is offline   Reply With Quote
Old 11-08-2010, 07:41 PM   #696
karlknaupp
Member#: 60871
2004 WRB WRX
we all get the rev.. lol
karlknaupp is offline   Reply With Quote
Old 11-08-2010, 07:45 PM   #697
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
gonna work on the car over bills shop wed. standby capt. ron.
Old 11-08-2010, 07:47 PM   #698
KB'izzle
Member#: 169955
30R BUILT STI /AREA
P no limits/ALLIANCE FABn
KB'izzle is offline   Reply With Quote
Old 11-08-2010, 07:49 PM   #699
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
yea I gated your house the other day after I saw you on 70 and my car started bangin again! WTF!!!!
Old 11-08-2010, 08:14 PM   #700
karlknaupp
Member#: 60871
2004 WRB WRX
damn that sucks. yea wendy and the babysitter heard it, wendy was like what was that, babysitter was like a car.. wendy was like uh.... duh. what kind/color? she told me she heard somebody drive by i told her it was u. then she explained it to the babysitter.
