Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 11-08-2010, 09:41 PM   #701
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
Originally Posted by KB'izzle View Post
CKxx is offline   Reply With Quote
Old 11-08-2010, 09:59 PM   #702
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
12.0@115 STi Mikey Tuned
Originally Posted by karlknaupp View Post
damn that sucks. yea wendy and the babysitter heard it, wendy was like what was that, babysitter was like a car.. wendy was like uh.... duh. what kind/color? she told me she heard somebody drive by i told her it was u. then she explained it to the babysitter.
whats with all the tires btw?
RFoy91TSi is offline   Reply With Quote
Old 11-08-2010, 10:26 PM   #703
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
lol they for sale.. my dad brings them here from his job, still decent thread so i make a few bucks.
karlknaupp is offline   Reply With Quote
Old 11-09-2010, 09:21 AM   #704
T3RMIN4L
Member#: 37434
Originally Posted by GrapeSoda
we all get the rev.. lol
Yah but when you have no horn what choice do you have to get someones attention? LOL
T3RMIN4L is offline   Reply With Quote
Old 11-09-2010, 11:28 AM   #705
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Ron brought something to my attention..the valve that required a 4.48 bucket while most of the other valves were in the 4.90 range. I did quadruple check the clearances, but that one bucket was odd. I can pull the valve cover and recheck the valve lash. Big up to ron for spending the thought and helping me try and get this build sorted. I really appreciate nasiocs help!
Big up nasioc massive. I'll up date wed.
maxpowr is offline   Reply With Quote
Old 11-09-2010, 11:39 AM   #706
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
thanks for waking me up at 5am
But just like someone posted earlier its probably an exhaust valve......its pretty much the only thing thats gonna increase your compression and cause the richness to make the plug look like that.
besides that i think the only other thing would be ring(s) being upside down......
exactly how high were you when you were assembling the motor?
Old 11-09-2010, 11:45 AM   #707
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
Haha nice one ron...
Old 11-09-2010, 06:00 PM   #708
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I didnt mean to wake you up,syke yeah I did...
I am perminitely high.
Old 11-09-2010, 07:52 PM   #709
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
he wasn't high when he put that bucket in and checked the clearance maybe thats the issue?
Old 11-09-2010, 08:19 PM   #710
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
thanks ralph, i would have been but...anyway, ralph was there when we lashed the valves and for whatever reason it did call for a small bucket. i just have to think its related...
the valves springs and retainers were all new. i made sure that the springs were seated and to be honest a retainer wont lock if it is not set properly, so i dont think it is the valve install.
the bucket size is determined by the length of the valve correct? so it just so happens that one of my valves was a couple hundredths longer than the others, right?
something else i considered. the 2.0 v5 big port heads were 49cc's stock. the machine shop opened them up to 54cc's.this was done by hand. if cylider 3 is say 53cc's would that cause higher compression in that cylinder? would that cause a 12% difference from the other cylinders?
Old 11-09-2010, 08:34 PM   #711
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
They should have cc'd the chambers to ensure all are the same volume
Old 11-09-2010, 08:39 PM   #712
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
well of course they told me they did measure them to be perfect and 54cc's, but i have not been impressed by this place recently.
plus unlike ed@equalibrium these were done by hand, not on a machine. i also paid a ton more than what ed is charging but he's on the west coast and i didn't want to risk putting another 3000 shipping miles on my precious heads.
Old 11-09-2010, 08:42 PM   #713
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
how do you think they are professionally measured for cc's? big turkey baster sized eye dropper and water, then estimate level?
Old 11-09-2010, 08:54 PM   #714
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Plexiglass plate with a hole or two in it and a burrette. You can be pretty accurate down to the half cc
Old 11-09-2010, 09:04 PM   #715
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i wonder if half a cc could make up 12% difference? again i will be spending some time taking her apart tomorrow, but i would like to take some speculation with me.
big up your chest, kelly, for chiming in. i appreciate it.
Old 11-11-2010, 01:14 AM   #716
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
so the warm compression test showed the 170 cylinder come down to 167. the other cylinders were 150's.
we discovered a leak at the manifold to uppipe gasket, replaced that. we also smoked the top mount. we found air leaks. the sti top mount is not welded. its held together by tabs that are pressed on. these were not very tight. i hammered them tight and it stopped the leak. plugged the pcv valve. ran one line from the valve cover to the tee to the crank case to the valve cover to a tee to a bottle, with holes drilled in the top. this simply vents the pcv system.
the car is running much better.
maf tab and some pulls sent for you ron!
Old 11-11-2010, 02:44 AM   #717
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
compression test warm
1. 154 2. 155 3. 167 4. 150
ran an engine cleaner through the engine to try and clean the carbon out of cyl 3 but the other cylinders looked similar. valves were seated.
oil is still full. 500 miles into 2nd oil change.
Old 11-11-2010, 03:06 AM   #718
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
can we assume that cylinder 3 is less than the 54cc's. these heads were cut by hand. does it add up if cylinder 3 was actuall 53.5cc's the compression ration would be higher?
Old 11-11-2010, 05:09 AM   #719
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
Not cool. Those vents need vacuum from the intake to work properly.
IMPREZive 02 WRX is offline   Reply With Quote
Old 11-11-2010, 09:00 AM   #720
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i don't know if i agree. the crankcase and the valve covers need to vent. they don't need vaccuum. the oem subaru uses vaccuum from the turbo inlet to pull the gases and blowby from the pcv system for emissions reasons. subaru uses the catalitic converter to burn unused gas and blowby. i am drawing way more vaccuum then as oem. i am using a catch can to trap the oil instead of returning it to the intake for recycling.
i have an eye dropper full of oil in the catch can, but can feel the air surging into my bottle.
Old 11-11-2010, 09:08 AM   #721
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i don't think there is metered air lost from the crankcase and valve covers(heads). but i could be mistaken. either way the car is running much better.
please continue to consider my situation.
Old 11-11-2010, 09:25 AM   #722
T3RMIN4L
Member#: 37434
Glad you're getting things sorted out man. Did the afr's stay more stable? How's the log look from a knock perspective?
Old 11-11-2010, 09:29 AM   #723
02RexWI
Member#: 165141
I've got my lines run like yours (crankcase and both cyl. head vents T'd together and run to one spot), except I ran mine to an oil catch can and back to the turbo inlet for some "vacuum" so it works like the stock crankcase vent system under boost (where the PCV valve would have locked shut) but it doesn't have much suction at idle. Because of this lack of suction at idle I some time get a little smoke out of the exhaust (it seemed worse when on E85 for some reason too).
The pressure from blowby at idle is the only thing I'd be concerned about, since it isn't sucking out the pressure from blowby it has the potential to blow out oil seals with the pressure (Although I've seen seals similar to the ones in our engines hold over 50 psi)
The best option I see to combat this is to use an electric vacuum pump to keep a constant vacuum on the crankcase. Some people have even reported horsepower gains from such systems.
02RexWI is offline   Reply With Quote
Old 11-11-2010, 02:13 PM   #724
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
the pressure from the crank case and heads doesn't simply push through the opening and into the vented bottle? it requires vacuum to relieve the pressure?
its rigged up anyway. i am certailing looking into an aos that returns that slop to the filler neck.
this looks like the best value...but i'm up for anything that helps it work better.
http://www.importimageracing.com/p/S...7-WRX-STi.html
Old 11-11-2010, 02:23 PM   #725
kellygnsd
Member#: 32669
LINK G4 hybrid STi
I'm not gonna tell you not to get that particular AOS I will tell you from my work experience that an effective moisture seperator/AOS needs enough volume to generate good swirl inside. Usually bigger is better. I'm sure it is somewhat effective but I can't see it being as effective as a large canister style AOS.
