Old 11-11-2010, 01:59 PM   #726
02RexWI
Member#: 165141
Originally Posted by maxpowr View Post
the pressure from the crank case and heads doesn't simply push through the opening and into the vented bottle? it requires vacuum to relieve the pressure?
its rigged up anyway. i am certailing looking into an aos that returns that slop to the filler neck.
this looks like the best value...but i'm up for anything that helps it work better.
http://www.importimageracing.com/p/S...7-WRX-STi.html
The pressure will "push out" on its own, but without something sucking it out it will create a certain amount of pressure in the crankcase before it can escape through the lines into your bottle. There will always be a pressure drop from the place that creates the pressure (Crankcase blow-by) to the atmosphere. It may be minimal if you are running huge hoses from the crankcase to atmosphere, but it isn't feasible to run 2" hose from the heads, and crankcase.
02RexWI is offline   Reply With Quote
Old 11-13-2010, 12:35 PM   #727
WTRacing
Member#: 169608
03 Wrx
Psm
hey just thought of a quick cheap fix.... get you injectors flow tested take the injector with the highest flow and put it in the cylinder with highest compression.....
WTRacing is offline   Reply With Quote
Old 11-13-2010, 02:43 PM   #728
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
here let me help you with that...
RFoy91TSi is offline   Reply With Quote
Old 11-13-2010, 03:12 PM   #729
69subaru360
Member#: 159682
1995 WRX
2015 F150
No.
Old 11-13-2010, 05:31 PM   #730
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
i broke the green connector wire. i went to replace it and can't get a spice into the wire cause its so short and up in the dash. can't flash till i get this fixed. i'm just gonna put a switch in line.
maxpowr is offline   Reply With Quote
Old 11-13-2010, 11:06 PM   #731
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
SJSubyWorks can take care of this You know "those guys" know wiring pretty well and have done switch installs.
Old 11-14-2010, 05:13 AM   #732
WTRacing
Member#: 169608
03 Wrx
Psm
Old 11-14-2010, 05:13 AM   #733
WTRacing
Member#: 169608
03 Wrx
Psm
its not the correct fix however it will insure that the cylinder with higher compression will get the slightly heaver dose of fuel. the compression test results were not that bad when checked hot. there was no sign of burnt valves or anything to worry about when looking in cylinder just heavy carbon build up from catch can issue
Old 11-14-2010, 01:32 PM   #734
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
ready for new map.
Old 11-14-2010, 01:50 PM   #735
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
ready for new map.
Wait til you hit it with your knee getting in the car one day. Ask me how I know....
IMPREZive 02 WRX is offline   Reply With Quote
Old 11-14-2010, 02:03 PM   #736
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
waitin on RON to get his face off the floor.
Old 11-14-2010, 03:31 PM   #737
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
I have mine on the center console next to the parking brake with a safety cover.
Old 11-14-2010, 04:33 PM   #738
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i left enough wire to move it if necessary.
Old 11-14-2010, 04:38 PM   #739
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
umm....i sent u a map right before u pulled the connector out smarty pants.....
you were going to flash when u broke it......
so either u flashed the new map on the car and havent sent me data....or u havent flashed the map i sent....
Old 11-14-2010, 04:53 PM   #740
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
Old 11-14-2010, 07:18 PM   #741
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i don't have the last rom. i went to flash one on from thurs afternoon, but thought you were working on another one since then.
maf tab another one?
Old 11-14-2010, 07:33 PM   #742
Phatron
Member#: 36033
CEO PhatBottiTuning
that should be the last one i sent.....
Old 11-14-2010, 08:47 PM   #743
smokey07
Member#: 151683
need mas graphs
smokey07 is offline   Reply With Quote
Old 11-14-2010, 09:54 PM   #744
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
thats the map that didn't work.
Old 11-14-2010, 10:08 PM   #745
Phatron
Member#: 36033
CEO PhatBottiTuning
resent
Old 11-15-2010, 07:35 AM   #746
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
thanks ron...gonna put that sheet on there now.
Old 11-15-2010, 10:21 AM   #747
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
airboy yet?
Old 11-15-2010, 10:37 AM   #748
Phatron
Member#: 36033
CEO PhatBottiTuning
he got some kinda "incorrect voltage error" when flashing....i've never seen it before.
i have to assume that its a wiring problem or something with his car......as i've never had a rom get corrupted......but theres always a first time for everything.
Old 11-15-2010, 11:20 AM   #749
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
low voltage error i've had this before. check battery voltage / ecu voltage and ground. I replaced my battery and fuxed the issue I was rocking a 5 year old red top that sat for 2 years.
Jake hook jumper cables up to your teg and you'll be able to flash.
Old 11-15-2010, 11:30 AM   #750
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
LOL @ "fuxed"
I got those errors too. I have a beta version of the program that supposedly has a software fix for that, but I've yet to try it since I have no reason to flash my ECU.
