Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 11-20-2010, 05:53 PM   #826
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
If u can still log and pull learning views then what makes u think it's the cable?
Old 11-20-2010, 06:32 PM   #827
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Cause karls cable flashed your last phat-one on no problem. We hooked up a meter and i get 5v no problem. I assume you only need 5v to read through RR and learning view. Out of pin 6 of the obd2 which is the 12v communication to the ecm i am not getting any voltage. So its sorta not working.
Lets see if tactrix will honor a warranty.
maxpowr is offline   Reply With Quote
Old 11-20-2010, 10:30 PM   #828
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
sorry i didn't get a chance to data log ron...i'll pull on her tomorrow. popped a couple p0000 codes?!?!?! check engine flashes randomly, but goes out. lil scary to see it but it goes off. i drove home from AC, like 60 miles, and didn't occur. i changed the fuel filter and it feels more responsive.
i don't think we data logged since i repaired the leaky STi top mount.
i'm probally gonna have to BUY a new tactrix so we can get this tuned before the end of the season.
i don't even want to borrow a tactrix cause they are so crappy, i don't want to break someone else's!
i bet in the fine print TACTRIX claims the 2.0 is good for 20 flashes...JUNK!
no one else makes something that works with ROM RIADER?
Old 11-20-2010, 10:37 PM   #829
Phatron
Member#: 36033
CEO PhatBottiTuning
There's a $25 vag-com cable on eBay that people have gotten to work. I just ordered 4 of them to test em out
Cel flashing is misfires. P0000 is also something to do with misfires. I'm on my phone but if u google it im pretty sure the romraider thread will pop up
Old 11-20-2010, 10:51 PM   #830
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
cool, keep me in the loop. i'll give you a call tomorrow so we can bull****.
now that i'm done re-wiring the car maybe we can make some more progress.
Old 11-22-2010, 11:09 AM   #831
Phatron
Member#: 36033
CEO PhatBottiTuning
Take advantage of the thanksgiving sale
Originally Posted by PhatBotti Tuning TKR View Post
Im offering discounted tunes for the thanksgiving holiday.
Let me know if i can help you out
*** PhatBotti Etunes 40% Off Thanksgiving Sale ***
Old 11-22-2010, 02:29 PM   #832
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
can you put this one on my tab?
Old 12-04-2010, 03:47 PM   #833
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
ebay catch cans.
i want to remove the line to the sight glass and put a third male adapter on there. plug the bottom line. i want to run the pcv valve to one side, the other side to the crank case vent. the center male adapter to the turbo inlet. the other catch can between the valve covers to the turbo inlet.
does it matter if i use the smaller turbo inlet hose bib or the bigger bibs?
any imput on the pcv configuration is appreciated.
from what i have gathered, not putting vacuum to the crank case and valve covers leaves back pressure on the rings, seals and oiling system.
Old 12-08-2010, 01:09 PM   #834
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
installed dual catch can setup. pcv to tee at crank case vent to catch can to turbo inlet.
the other can is valve cover to tee to valve cover to catch can to turbo inlet.
works much better. no more hesistation on the pedal, although my header is still leaking...
pulling on it some more tonight.
put down 369/371 0n the airboy before i changed the pcv system.
400/400 is probally the limit for 30r 93 pump and sti top mount.
i have my scope set on the new gtx3076r wheel for my gt3076r housing.
52# to 65# in the same housing...baller!
http://www.atpturbo.com/
Old 12-08-2010, 01:13 PM   #835
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
You could have left that part out.
Everything else going smoothly now? What catch cans did you end up using?
IMPREZive 02 WRX is offline   Reply With Quote
Old 12-08-2010, 01:24 PM   #836
Phatron
Member#: 36033
CEO PhatBottiTuning
no matter how hard you pull its not gonna get longer. try hanging weights from it.
370-375 is probably where she's gonna stay on pump for several reasons.
I dont think pushing cars on pump gas is smart or beneficial.
With all the gremlins your car has had i think its wise to stay on the "conservative" side.....if you can even call a 375whp 11 second car conservative.
And most importantly.....you need to just enjoy the car for a while without having to wrench on it.
Old 12-08-2010, 01:52 PM   #837
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
its all good ron. i would have blown up and bought a honda long ago, if i had never met you!
gonna go pull "the car" in a bit.
i'm getting tired of fixing it, i'm ready to enjoy! maybe i'll make it to the track this weekend!
i still feel really anxious like it could pop at any time...
heard piston slap for the first time when we got down to 30*. i don't like that sound! goes away after a couple minutes. when i googled piston slap, all the videos sounded more like rod knock. mine sounds more like metal grinding/rubbing. it only does it ice cold and if i put a load on it while still cold. goes away after warm up, 10 minutes. doesn't do it simply at idle. gonna try and record the sound...
also after i first installed the pvc/catch can setup, when i started it , it was a hard start and i heard the bov blow off.
almost like it was stuck or something...
chris...ebay catch cans...21$ each shipped.
Old 12-08-2010, 03:27 PM   #838
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Dont do ti!! LOL, as much as they are fun to pop V-tec around town, I tuned a supercharged type r last night and was very dissapointed. Its only on 5 psi and is maybe a 14.60 car, if God is driving. I tuned an RSX with an intake and it pulled us by 2 cars... Stick with the Suby bro!
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 12-08-2010, 04:06 PM   #839
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i think you misread my post mike. i should have said, i would have been out of the big power turbo 4 cylinder game, if i had not hooked up with phatbotti tuning. lets not forget that my open source tuning began with you, mikey.
if i would have blown up last year, i would have not had a choice but to by a daily driver...most likely a fuel efficient honda.
you guys and nasioc, not to mention many others, have made all my subaru dreams come true...well so far...
Old 12-08-2010, 04:07 PM   #840
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
do we have an airboy yet ron? believe it or not my microsoft excel is not working right.
Old 12-08-2010, 04:24 PM   #841
Phatron
Member#: 36033
CEO PhatBottiTuning
i do em every pull but im not gonna take the time to save a pic and host and post everytime you send a log. i'll make one when we're done
Old 12-08-2010, 04:40 PM   #842
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
okay...thats good news then...we aren't done yet.
you should definitely change that thong out for a pair of boxers though...
Old 12-13-2010, 10:51 PM   #843
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 12-23-2010, 05:10 PM   #844
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 12-23-2010, 05:25 PM   #845
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
very good stuff... exile ftw
karlknaupp is offline   Reply With Quote
Old 01-25-2011, 06:37 PM   #846
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
airboy'd. better results from e85?
i have to re weigh the car as well. we put it down as 3500lbs. that 3RD gear pull was on a full tank of 93* with 2 10 inch subs and enclosure/amps...la-di-da.
can't wait for atco to open so i can get a number that matters...APRIL?
Old 01-25-2011, 08:15 PM   #847
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
slow!!!
Old 01-25-2011, 09:13 PM   #848
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i'm just updating the thread for my fan base.
we are far from finished.
Old 01-25-2011, 09:19 PM   #849
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Originally Posted by karlknaupp View Post
slow!!!
I think the 2010 STi should get a shot at this 30R car
Hehe,
-Mikey
STi Mikey is offline   Reply With Quote
Old 01-25-2011, 09:39 PM   #850
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i welcome it, as long as wendy is driving.
i can't wait to get to the track!
i could care less about losing a race, its so much fun!
i just hope hakt ecu holds together!
i have one of the best subaru mechanics possible, the best tuners my ecu could ask for and access to limitless knowledge here on nasioc.
my family is healthy, life is good.
