Old 02-27-2011, 10:45 PM   #1001
STi Mikey
Member#: 114631
2007 11.5 @ 118
Stock Turbo Record Holder
Its all good, we'll be battling motor noise next weekend using det cans.
I think we should do c16 in jakes car next week, turn a low 11.
-Mikey
STi Mikey is offline   Reply With Quote
Old 02-28-2011, 12:09 AM   #1002
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
Originally Posted by karlknaupp View Post
Jr I pulled 1.85 60', ran a 12.4 at 110, missed 5th so I rolled through.
Jake needs a bit more tweaking and some seat time. He should easily see 11s.
What was the 330 and 1/8th on that run?
Jr
Junior2JZ is offline   Reply With Quote
Old 02-28-2011, 08:13 AM   #1003
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
short shift linkage wouldn't hurt either.
the short ratio 04 sti tranny is a lil bit wek sauce. i'm smashin syncros, it wont last if i dont get short shifter.
def get into 5th up to like 5-6k, not like a lil short burst.
i predict, ppg 5 speed or rebuilt 6 speed in the near future. not fun.
car needs anything better than an 02 wrx open rear diff.
header needs leaks repaired...i expect better throttle response from that. it lags a lil. when i'm deep in the tree, i stab it comfortably to 5200. its not quite enough to really ride out and get a good launch. in the burnout box, 5200 breaks em loose, but not off the line. i go around the water best i can. i think 6k would geter done but that probally wont last long on the 02 rear diff.
overall, big up to karl for making it happen, on a day where no babysitter was to be had.
jr. hey i know your the big boss with the hot sauce but everyone misses a gear once in a while and if i was next to you during that incident, i would roll with it into the history books
maxpowr is offline   Reply With Quote
Old 02-28-2011, 09:48 AM   #1004
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
put pump map 22 on and popped a p032 front o2 sensor code at cruise to 7-11. car is super sensitive (16 bit i guess). cleared it, but hopefully thats not on its way out.
gonna check plugs and compression on monday. gonna run the one step colder at 26 gap...
if you guys remember one of my cylinders (#3 i believe) had 170 compression, while the others were around 150.
ronaldo mentioned he can turn down the sensitivity of the knock thresholds...gonna look into that.
Old 02-28-2011, 10:46 AM   #1005
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
E85,2007 6mt,No traction
Do you have any airboy graphs of your pump gas tune? Did you really hit 400whp airboy on 93 pump. If so nice work! That's alot of power on pump gas and a 30r! What psi did you guys run?
TDagen is offline   Reply With Quote
Old 02-28-2011, 11:57 AM   #1006
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I have data...we did 377/333 on the current build. We airboy'd 420 yesterday but obviously something was off. We are back on pump now, and ron is tightening it up.
There are a few things that can be done to help...like repairing my header...
Let me get ron to post the data...
Old 02-28-2011, 12:51 PM   #1007
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
it was just one of those fluke runs...its in the 365-375 range
we need to do some testing with race gas and/or det cans to determine if his knock is real or not.
Based on his power level....i think its real...but the timing is pretty low...like 12-14* at redline...makes me think its not real.
Old 02-28-2011, 12:57 PM   #1008
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
375 whp on pump is still no joke Wow so how much boost?
The 2.5L is noisy on the 16-bit ecu. I found most of my false knock occurred between 4800rpm and 6000rpm...
Phantom knocketh...
Old 02-28-2011, 01:03 PM   #1009
Phatron
Member#: 36033
CEO PhatBottiTuning
he's at 23-24 psi tapering to 21-22 psi iirc.
Old 02-28-2011, 01:49 PM   #1010
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Same here TD, thats why we are running such low timing, plus my compression may be higher than the average hybrid.
The thousand spent on converting fuel system to e85 may be spent wiser on EM.
Old 02-28-2011, 02:34 PM   #1011
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
I've seen WRX specific AEM boxes for less than a grand used but I'm not sure how good the knock control is on those boxes.
kellygnsd is online now   Reply With Quote
Old 02-28-2011, 04:42 PM   #1012
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
I'm not a big boss, and no hot sauce here.. I'm just breaking your balls since you called me out.
I will be ready for the weekend, but I wont be around. Get that race gas tune that will drop you into the low 11s automatically and it might be a decent race
Jr
Old 02-28-2011, 04:58 PM   #1013
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
its all good junior. when i was young an older friend told me that if i wanted to learn how to become a better skateboarder, i had to roll up on the big boys and give it all i had. this advice has propelled me through this game we call life. nothin to it but to do it.
i don't remember "calling you out" , more like an invitation. when i saw the track was open, i put the word out to all my buddies that i thought would bring out a car that would provide entertainment.
so i get there a lil late and see the track is pretty much a ghost town. well except for a maroon fxti...
i get right behind it thinkin its you...but it wasn't.
that 35r fxti had me beat with 12.0's all day anyway! big up to annointed...
Old 02-28-2011, 05:44 PM   #1014
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
That's was annointed?
karlknaupp is offline   Reply With Quote
Old 02-28-2011, 05:47 PM   #1015
Paul
Member#: 56203
00 RSTI Coupe
What was annonited trapping? He's car is sick
Paul is online now   Reply With Quote
Old 02-28-2011, 07:11 PM   #1016
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
it was actuallly his buddy shawn driving, annointed wasn't there.
his car ran 12.0 @ ??? all i gathered after finding out it wasnt Jr. was that it had a built 35r, and the track beckoned us. i didn't get to race his, but from what i could see he would have bagged me.
Old 02-28-2011, 07:23 PM   #1017
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
Sounds to me like you have a strong running motor to put that kinda power out with that little boost/timing! My compression is higher too on my hybrid. I had the heads decked twice... I swear it makes a difference in a good way. Or maybe these 2.0 heads are the stuff
Old 02-28-2011, 07:39 PM   #1018
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
you realize my heads are v5 2.0 jdm big port heads that have been opened up from 49cc to 54cc. i believe the usdm sti heads are 57cc.
i never actually measured them for myself, but after assembly i did a compression check.
came out wierd...
152 149 170 154...so #3 is really high. even the other cylinders were higher than i expected.
the heads contain, kelford 272s (rem treated), manley plus one valvetrain, 5 angle valve job, and converted to shimless buckets.
i expected much more out of the 4k$ i have in the heads, only to find out that these heads wont really come to life below 500whp...i should have just slapped on usdm 2.0 hybrid for my 30r...
its cool though, i never thought i'd say my 30r is kinda small, but it does 23#s by 4krpm
this car will def see 65#compressor wheel.
Old 02-28-2011, 07:53 PM   #1019
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
oh, started on the upgrade already, cool. thats good news.
looks like no dice tomorrow...80% chance of rain.
tracks got the schedule on line.
http://atcoraceway.com/
theres this too...
http://216.109.136.172/schedule/street_wars_1.as px
that log is my 07 ej255, cosworth piston, +1 cosworth bearings, v5 heads opened up to 54cc's, +1 manley valve train, 5 angle, kelford 272, arp head studs, rotated 3076r .82,
44 tial, spt 3 inch cat back, id1000's, aero. fpr, perrin rails, walbro, 12mm oil pump, hallman mbc,
75mm cai/maf, STi TOPMOUNT. 04 3.90 6 speed.
(02 wrx read diff) act stage 1 organic 5 speed clutch and lightweight flywheel wheel.
i'm hoping 11.7 @ 120, thats why i was callin out your xt...
put in c16, +2#s of boost and run 11.3 @ 123?
ez does it jr.
jake
Originally Posted by Junior2JZ
My Xt Just got taken apart to put the new setup on it. Wont. Be done til next weekend. Probably wont be a good race with the xtra 250whp
Maybe I will bring down my 360 and run that before I turbo it. Im out in the city, so I will see if I wake up early enough.
What did you run anyway? What's that a log of?
Were you trying to pick on my baby turbo Xt? LOL
yo bro.
atco raceway opened today and it was a ghost town. 20$ race 10$ to watch, could have easily got 30 passes. like 10 cars.
its open tomorrow 10am till 4pm...
i wanna run this.
good race for your fozzie.
ez
jake
Maybe you were drunk!!
I hear you though, but at the same time you gotta get yourself to the point were you can step up and run with the big boys before you come out and get shut down ... Besides.. I am no big boy, I am just me, doing what I do. I actually felt like you came out trying to pick on my 3500lb little turbo beater. I know when I call people out I bring a lesser machine and let my other skills do the talking.. Like when I call out AMRs "7sec" drag car with a 9 sec car Or when I call out 800+whp EVOs with 600whp subaru.. I am the under dog.. You were bringing a lighter car with more "air boy whp" to try and make my XT look bad
When I button up the XT we can go walk the walk.. I will even let you leave on me
Old 02-28-2011, 08:27 PM   #1020
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
came out wierd...
I forgot you had those sick fully done up jdm heads . Damn that's a nice setup! My cylinders all popped 150+ on the compression test too, that 170 is an oddball though!
Your motor runs strong because it's breathing so damn well!
Hta86 that bitch...
Old 02-28-2011, 08:32 PM   #1021
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
My XT compression test around 175-180.. I LOVE the off boost response!
Old 02-28-2011, 08:36 PM   #1022
TDagen
Member#: 163648
2002 Wrx,2.5L,HTA86
Originally Posted by Junior2JZ View Post
You XT compression test around 175-180.. I LOVE the off boost response!
What compression ratio did you go with?
Old 02-28-2011, 08:47 PM   #1023
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I wish I lived closer ..................
kidding
Old 02-28-2011, 08:56 PM   #1024
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
all right junior, it was a friendly invite i promise you that, but i will admit i was lookin for a race! maybe your trigger finger is gettin itchy for a day down at the track and you took me the wrong way.
i'm certainly not gunning for anyone. i'm not that kind of guy. i'd be really stoked if i could get around you in a run but it would be more like high fiving chase utley after a homerun, than an opportunity to talk smack.
respect where its due brother.
if somebody beats me in a race and won't give me an chance to match up than so be it.
can't win every race but can come back stronger next time.
good times...2011.
jr. you coming to the autox event down here next weekend?
Old 02-28-2011, 09:01 PM   #1025
Phatron
Member#: 36033
CEO PhatBottiTuning
I say put jr in jakes car and jake in the fxt
Message Board Statistics All times are GMT -4. The time now is 07:24 AM.
