Old 03-07-2011, 02:29 PM   #1151
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
i just cant believe your motor would go running 25-26 psi and 10-11* of timing at peak tq....on c16. I consider that highly conservative for that octane level.
Just to give an idea of the conservativeness.....the last gt30 i logged out here tuned by a local shop was running 29psi and 18* of timing at peak tq on 91+meth....
this sucks jake.
Old 03-07-2011, 02:44 PM   #1152
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Originally Posted by maxpowr View Post
Got rod knock...game over.
I think a rod is bent. Starts, idles, but after 3k I can hear the unhappy rod bearing
5w30 on +2 bearings may have been too thin...
WOW ....
Sorry dude
Old 03-07-2011, 02:47 PM   #1153
OppositeLock
Member#: 54060
Now: 16 FXT/04v8 207
Then:JRTuned fastest td04
This.^ I thought you guys said earlier in the thread that you were going to go conservative on C16, so a spun bearing doesn't make much sense. In my experience, pullies, timing guide and certain exhaust leaks can sound just like a bearing. Drop the oil and check it out, I really hope it is something else.
OppositeLock is offline   Reply With Quote
Old 03-07-2011, 04:38 PM   #1154
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
Im sure it has to come apart. Last minute motorsports.
Do the clutch with the motor out....as soon as I find a job.
Fortunately I can park her and rock steady in my teggy.
Hopefully not too much is wrecked...i'd hate to have to stroke it.
maxpowr is offline   Reply With Quote
Old 03-07-2011, 06:25 PM   #1155
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
we should drain the oil when we get it to jodies & check for metal in the oil before we tear it apart. i really pray its not a rod.
until then..
Get those brake lines on the teggy fixed son!
maybe do some 17 sec bracket racing.
SikSilvrSuby is offline   Reply With Quote
Old 03-07-2011, 07:52 PM   #1156
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
yea man drain the oil and if you don't see any metal right off the bat take two flat peaces of clear plastic and stick one in the oil then stick the other one to the oily one and hold it up to light give it a good inspection.
RFoy91TSi is offline   Reply With Quote
Old 03-07-2011, 08:10 PM   #1157
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Ill keep you guys on board. Maybe a mistake I made can help someone else...
Old 03-07-2011, 09:32 PM   #1158
waynoSTI
Member#: 162151
2.6L BLUE THUNDER
LOW&WIDE&SHAVED
That really sucks man. I hope it's not serious... Been down this road myself.
waynoSTI is offline   Reply With Quote
Old 03-07-2011, 11:09 PM   #1159
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
That sucks Jake, I am sorry to hear that. I was looking forward to the track this weekend with you guys.
Just wanted to point out that not having enough timing can be just as bad as having to much timing. To little timing will cause very high EGTs which can and will lead to detonation just like to much timing. Just post pics of the bearings and pistons when you get them out.
Jr
Junior2JZ is offline   Reply With Quote
Old 03-07-2011, 11:11 PM   #1160
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
If you flatten a bearing you will have a knock, but very little if any metal in the oil. Very hard to see it.
Jr
Old 03-08-2011, 01:23 AM   #1161
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Ill def share the results with our community. It would be really nice if we could discover the cause but without data from friday we will be more or less sorting through wreckage.
Def looking forward to any insight, comments, suggestions, and advice.
Maybe mikey will post up the map we ran.
Old 03-08-2011, 01:48 AM   #1162
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
Are stock sti rods good up to 400hp or 450?
If a 120mph trap speed is 400hp, and a 130mph trap is 500 horse, your car went 125mph soo isnt that 450hp which is pushing a stock sti rods limits anyway?
any views/comments/opinions of running 5wt30 with a +2 bearing size?
i thought mikey said he added 1 degree of timing on to your 93oct pump map and added 2psi.. not enough timing for c16?
Old 03-08-2011, 07:21 AM   #1163
juanmedina
Member#: 133146
I
their rating is really unknown I have heard from 400whp to 500whp. I am myself running 400whp+ Airboy and tons of timming. I know people that have gone 135mph+ in 1/4th miles with stock STi rods so their are not weak by any means
GL Jake
Old 03-08-2011, 09:20 AM   #1164
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
Originally Posted by juanmedina View Post
I
GL Jake
im assuming they were using oil thicker than 5wt30 then? i just dont get it.. this is such a bummerrr. dont worry jake we'll get er fixed. start pushin some stickers and t shirts son. gota get some loot up.
Old 03-08-2011, 09:42 AM   #1165
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i have a lil bit bigger plans that that, but stickers and t shirts will be included.
Old 03-08-2011, 09:48 AM   #1166
juanmedina
Member#: 133146
I run rotella T 5w40, I can see how it happen but is just theories. Who knows...
He was running a STi TMIC with a 30r on 93oct with a semi aggresive tune. It seems that Jake liked to drive his car hard as I do, If the TMIC head soaked there was probably a lot of knock. It probably happend overtime
To bend a rod it probably happen with detonation or a piston seizing. I don't understand the oil theory, do you guys mean not enough lubrication between the bearing and the rod?
Old 03-08-2011, 10:09 AM   #1167
adamlavender
Member#: 144938
30R'd wrb
Beyond compression test then?
adamlavender is offline   Reply With Quote
Old 03-08-2011, 10:41 AM   #1168
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
I've been pushing my stock Sti bottom end hard , no problems... Get a compression tester and test it jake! Maybe it's just something stupid? Any blue smoke or anything out the back?
TDagen is offline   Reply With Quote
Old 03-08-2011, 10:43 AM   #1169
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
On friday night jakes car was running:
12 degrees of timing at peak torque
16 degrees of timing at 7000 rpm
26 psi
11.4 AFR's
It was 37 degrees, IC never got hot.
;ake, before I left for florida and you flashed back to pump, I told you to turn the boost back down to 23-24. Did you ever do that?
STi Mikey is offline   Reply With Quote
Old 03-09-2011, 05:07 PM   #1170
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
jodie came by and we could barely reproduce the noise. We drove it around and pulled on the throttle body, but I couldnt make it reproduce the noise.
Gonna check the oil tomorrow.
I heard it very slightly here and there but jo thought it was wierd that it wasnt all the time like a spun bearing.
Maybe its not broke?
Old 03-09-2011, 05:33 PM   #1171
juanmedina
Member#: 133146
I really hope so
Old 03-09-2011, 06:55 PM   #1172
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Clutch is def uckt though.
Old 03-09-2011, 07:15 PM   #1173
Phatron
Member#: 36033
CEO PhatBottiTuning
bumps
Old 03-09-2011, 07:36 PM   #1174
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
26 psi
11.4 AFR's
Sounds pretty close to the setup i'm running right now, minus a few psi.
Subian is offline   Reply With Quote
Old 03-10-2011, 12:51 AM   #1175
SikSilvrSuby
Member#: 193569
2005 too many cars
Rallispec LTD
hopefully it was just the urkle playin tricks on you
hopefully. id hate to rip it apart for nothing. but i cant wait to find out whats really going on with it.
along with everyone else.
