Old 03-12-2011, 07:29 PM   #1201
tramix
Member#: 148317
1998 Subaru Impreza
Brilliant Red
Originally Posted by maxpowr View Post
And caging it too!
No metallics in the oil at all. It was somehow a quart low within 100 miles, 4 of which was at atco. Compression test next.
If you flatten a bearing you will not see metal in the oil, you can pull the pan and not even find a shred of metal but still have a flat bearing. If you keep driving it you will find out the hard way when a rod locks up and flys out the block. Knocking noises are never good, the simple fact that by running thicker oil it got quieter would make me pull it out and inspect it before you are stuck buying a lot of stuff you didn't need, IE Crank, Rods, Oil pump etc.
tramix is offline   Reply With Quote
Old 03-13-2011, 08:56 AM   #1202
MattPersman
Member#: 139385
hope all is well Jake, and it's nothing too terrible. perhaps its in the timing belt area?
MattPersman is offline   Reply With Quote
Old 03-13-2011, 02:26 PM   #1203
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
^^^Thats possible I have seen tensioner get weak and make a smacking noise in the front of the motor especially after getting out of the throttle.First things first tho he needs to pull the pan and check out the bottom end.
john 1badSTI is offline   Reply With Quote
Old 03-13-2011, 04:16 PM   #1204
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
my $8 paint job so far
Old 03-13-2011, 04:24 PM   #1205
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Sweet....
more pics
Old 03-13-2011, 06:05 PM   #1206
Phatron
Member#: 36033
CEO PhatBottiTuning
1 more.....this should cause some
Old 03-13-2011, 06:08 PM   #1207
juanmedina
Member#: 133146
a removable tube frame front end so you can remove all the future blown engine easily?
Sick Ron, I can't wait to see what she weight when you finish with her? There is no way my car will be as light as yours
Old 03-13-2011, 06:19 PM   #1208
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
just...huh?
new front clip? bye-bye bugeye? i smell weight loss, skinnyron
weighed my car last night on my way to senecas. 3300 with me in it.
please post an air boy.
maxpowr is offline   Reply With Quote
Old 03-13-2011, 08:26 PM   #1209
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Damn Ron you are done playing this year...
TDagen is offline   Reply With Quote
Old 03-15-2011, 02:32 PM   #1210
06njsti
Member#: 150986
06 #001 LSB STi
any update's jake?! Im bringing my car to the body shop if you wanna take a ride on thursday...brembo's come off today
-Gary
06njsti is offline   Reply With Quote
Old 03-15-2011, 08:08 PM   #1211
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
are you getting new brakes? i like brembos...but not as much as 4pot/2pots!
Old 03-16-2011, 12:24 AM   #1212
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Whats the point of that? You probably lost 35-50lbs.. but turned your car into a race car. I have done that mod before and it honestly ends up being a waste of time.. especially when it comes time to install the body parts back on.
Jr
Junior2JZ is offline   Reply With Quote
Old 03-16-2011, 12:34 AM   #1213
Phatron
Member#: 36033
CEO PhatBottiTuning
i dont know....kenny had 50 rockstars and a cutting wheel and thats what happened
Old 03-16-2011, 01:08 AM   #1214
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
2400# gdb, gtx35r and then some...
Old 03-16-2011, 09:50 AM   #1215
06njsti
Member#: 150986
06 #001 LSB STi
no just powder coating my brembo's. I cant justify 4k on a set of 6 pistons for the front. **** that! ill be lucky to drive this car 2x a week when its finished and it stopped perfectly fine the way it is now.
Old 03-16-2011, 10:23 AM   #1216
02RexWI
Member#: 165141
I can set u up with a set of wilwood 6 piston calipers, pads, 2 piece rotors, and all the mounting hardware for well under $2k. Pm me if interested.
02RexWI is offline   Reply With Quote
Old 03-16-2011, 12:01 PM   #1217
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Dont get gary started...hes got enough problems.
Getter done gary!
Old 03-16-2011, 12:03 PM   #1218
02RexWI
Member#: 165141
Getter done gary!
Don't u mean git r dun'?
Old 03-16-2011, 12:16 PM   #1219
Phatron
Member#: 36033
CEO PhatBottiTuning
yeah my setup i posted earlier (brakeman rotors and wilwood calipers & pads) was had for under $1k.....its amazing how cheap it is when you dont buy someones pre-made kit. i was shocked.
Old 03-16-2011, 12:35 PM   #1220
02RexWI
Member#: 165141
Yeah, the company I work for buys a lot of wilwood brakes so I was able to get them at wholesale. It sucked trying to get them to make a rotor hat for 5x114, their Rep just told me: there is no way our 6 piston Wrx kit will work on a 2005 STI. I ended up just buying that kit and machining holes of 5x114 between the 5x100 holes, and the kit works awesome!
Old 03-16-2011, 12:44 PM   #1221
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i want rons brakes...but money is uckin tight.
Old 03-16-2011, 12:50 PM   #1222
06njsti
Member#: 150986
06 #001 LSB STi
Thats not the 6 piston brembo kit I "WANT"...so im gonna pass.
Getter done gary!
and yea tell me about it, ive got so much **** going on right now. No motor, no brakes or anything on the car. I need to finish up what i got going on now.
-Gary
Old 03-16-2011, 01:34 PM   #1223
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Haha.. Right on the money Ron. I am doing 16" front 15.5" rear 2 piece rotors with 6 piston mono calipers all around right now on my other car and I could not believe the difference in price when I had [email protected] just source everything separately and make me brackets. Basically for the price of just 1 front kit I did all 4 corners with bigger and better hardware.
What weight are you shooting for in the WRX?
Jr
Old 03-16-2011, 01:46 PM   #1224
Phatron
Member#: 36033
CEO PhatBottiTuning
there really isnt a plan. Kenny, kelly and i are just having fun. 1 month ago there wasnt a plan to do the brakes this way....i wasnt planning on dropping the fuel tank....wasnt planning on chopping the front off....wasnt planning on a cage...wasnt planning on pulling the whole wiring harness.
Basically the only thing that was supposed to be done from the beginning was the turbo kit and some aero panels.....and it turned into this.
Old 03-16-2011, 03:12 PM   #1225
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
gtfo and make your own build thread phagot.
