Old 04-06-2011, 01:43 PM   #1276
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
hey jake...find someone to buy my tranny
http://forums.nasioc.com/forums/show....php?t=2162316
Old 04-06-2011, 04:57 PM   #1277
06njsti
Member#: 150986
06 #001 LSB STi
Originally Posted by maxpowr View Post
so this is what i need right guys?
http://www.extremepsi.com/store/prod...cat=980&page=1
ron sent me an act 6 speed hd pressure plate, not sure what flywheel yet.
thats the disc im going to be running, not looking forward with it and the loss in driveability either.
I might have a friend willing to sell a stock flywheel, I know he is going to do a clutch in his pretty stock 06 sti. If your curious about it text me and ill find out. When I went to a lightweight flywheel I lost alot of driveability in the clutch and really regret it, ive been debating on picking his up for my own personal use but cant have a stock flywheel in my car haha.
-Gary
06njsti is offline   Reply With Quote
Old 04-06-2011, 08:13 PM   #1278
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
big up to ron for the act 6 speed hd pressure plate and 6 speed oem flywheel. heavy as hell!
maxpowr is offline   Reply With Quote
Old 04-06-2011, 08:21 PM   #1279
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
-Gary
I run this disc with the extreme pr plate and stock flywheel and driveability is fine for me.I would definitely put a stock flywheel back in it if you do any drag racing.Now the unsprung hub 6-puck takes a little bit to get used to but I prefer the sprung disc,it absorbs a little more shock when you are launching the car.
john 1badSTI is offline   Reply With Quote
Old 04-06-2011, 08:24 PM   #1280
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 04-06-2011, 08:55 PM   #1281
Phatron
Member#: 36033
CEO PhatBottiTuning
you've posted a picture up of that clutch like 5 times...just buy it already
Old 04-08-2011, 10:36 PM   #1282
Member#: 277007
02 6spd bugsti 30r
v5 heads 272 hakt ecu
35 years later...
maxpowr@phatbotti is offline   Reply With Quote
Old 04-10-2011, 11:17 AM   #1283
wrxmonster
Member#: 206388
Yo Jake! You're tuning now?
wrxmonster is offline   Reply With Quote
Old 04-10-2011, 11:44 AM   #1284
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
no. i remotely tune for mikey and ron. i am also heading up the retail end of phatbotti tuning.
Old 04-10-2011, 06:54 PM   #1285
wrxmonster
Member#: 206388
nice!!!
Old 04-13-2011, 08:11 AM   #1286
JRizzy24
Member#: 215468
2013 STi
Crystal Black Silica
Jake, when's the next Atco run for you?
JRizzy24 is offline   Reply With Quote
Old 04-13-2011, 09:02 AM   #1287
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
headed out to get my clutch today. Installed by friday?
Street wars on sunday.
Old 04-13-2011, 03:37 PM   #1288
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
got the ACT 6 puck clutch disc, installing at last minute motorsports on friday.
i have the act hd pressure plate used (thanks ron) and also a sti 6 speed pressure plate, new.
anybody know the clamping tq of the sti pressure plate?
i think the act hd is like up to 550tq.
Old 04-19-2011, 04:11 PM   #1289
06njsti
Member#: 150986
06 #001 LSB STi
is your bucket running again with this clutch in it? my pos gets picked up from the body shop thursday and can hopefully have it running by the end of the month.
Old 04-19-2011, 04:29 PM   #1290
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
cut rons oem 6 speed flywheel today. gonna use the act pressure plate. interchangeable with any act disc. the sti pressure plate does not have the clamping force of the HD and it calls or an organic disc.
im trying to get on a lift so i dont have to drop the tranny on my chest. probally end up over last minute cause jodie just gets it done.
bit of a delay with the kids home on spring break.
Old 04-21-2011, 04:25 PM   #1291
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
If the piston skirt is worn down and slapping on cyl. 2 can I simply replace the piston alone?
The sleeve should be intact if the aluminum piston wore down before the steel sleeve correct?
Old 04-21-2011, 04:33 PM   #1292
Phatron
Member#: 36033
CEO PhatBottiTuning
jake....if you're really that worried then you have to pull the motor.
you can theorize all day about whats wrong and what the fix is....but you wont know for sure until you pull the motor and figure out whats wrong.
bass up, boost down and enjoy the car for a while
Old 04-21-2011, 04:39 PM   #1293
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Leak down test asap.
Is there any reason I cant change out one piston with a new one to remove the piston that has worn down...
Old 04-21-2011, 05:07 PM   #1294
langsbr
Member#: 209630
2002 WRX / V7 STI
3.9USM6 / PSM
I dont see why you couldn't. Some of my buddies with mustangs would replace pistons at the track if they blew a hole in one on the gas at an event. Swap, go, and pray! Granted the drag strip isnt the best place to do motor work, but you should be fine doing just one.
langsbr is offline   Reply With Quote
Old 04-22-2011, 11:13 AM   #1295
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Leak down
Cyl 2 = less than 3% @ 100psi.
Cyl 4 = 0% @ 100psi.
I considered pulling the pan to inspect the rods but doubt I would be able to visually see a very slightly bent rod.
Compression is good (125 in #2, 150 in #4) but not within 10%.
Leak down is good...
Buggin?
Old 04-22-2011, 03:27 PM   #1296
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Jake,
You can physically change the one piston. However, you have to take into consideration balance as well as the fact that if the skirt is worn, it had to be rubbing on something.
If your going to drop one piston, you will want to ball hone the wall. It should take off .0001-.0003. But now, that material has to go somewhere. And its looking like its home could be the crankcase and bearings.
Please be cautious, and do not make decisions because they accommodate financial situation. Its better to save and do things the proper way, especially when it comes to suby motor's. Ill see you next weekend, big suby meet down there. Ill bring your cable and we can all shoot the ish
STi Mikey is offline   Reply With Quote
Old 04-22-2011, 06:21 PM   #1297
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Buggin?
how is that good? what are 1 and 3?
Old 04-22-2011, 06:34 PM   #1298
Phatron
Member#: 36033
CEO PhatBottiTuning
they're all 150, except #2 @ 125
and #2 used to be 170 IIRC
its been out of whack since he first tested it....
Old 04-22-2011, 07:41 PM   #1299
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Ron speaks truth as usual.
Old 04-22-2011, 09:05 PM   #1300
john 1badSTI
Member#: 77470
that leakdown sounds a little funny I have leaked down a lot of motors and have never seen one leak down 0% --you need to recheck those #'s and if a piston is in question all the leakdown tells you is that the rings and valves are sealed up good.
