Welcome to the North American Subaru Impreza Owners Club Thursday July 24, 2014
Old 09-04-2011, 01:25 AM   #1376
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Im interested to see if it still runs.
Phatron is online now   Reply With Quote
Old 09-04-2011, 01:32 AM   #1377
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
why wouldnt it?
google plus wendy?
maxpowr is offline   Reply With Quote
Old 09-04-2011, 01:42 AM   #1378
Phatron
Member#: 36033
CEO PhatBottiTuning
Cause it's been rotting in a shed by the ocean
Old 09-04-2011, 01:43 AM   #1379
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
it hasnt gotten any cleaner...
Old 09-04-2011, 11:16 AM   #1380
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 09-04-2011, 11:51 AM   #1381
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
is that going in - or just coming out?
Visconti is online now   Reply With Quote
Old 09-04-2011, 12:04 PM   #1382
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
coming out....waiting for our one engine stand to get free'd up.
Old 09-04-2011, 12:13 PM   #1383
Visconti
Member#: 156247
14' Flex Fuel FXT
15' Flex Fuel WRX
you putting it together ?
your self !?
Old 09-04-2011, 12:54 PM   #1384
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
yeah...and? jodie from last minute motorsports will be helping me and karl...
i built the last one and the 6 speed. i put my hand on everybolt on this car...
this time im gonna built it a lil more stout. turbo tuff rods instead of stock.
probabaly gonna need a new single cosworth piston. hopefully i dont need a new case.
i'd replace the case before buying 4 new pistons. i was hoping i could just replace a case half, but later discovered that wouldnt work due to the line hone for the crank...
i wanna get it up and running for tues, but rushing sheet never works out well and depending on what subbie of cherry hill and extereme psi have in stock determines how fast it will go back together.
pre-teardown parts list
oem gasket kit
cosworth head gasket...considering a thin one...believe my cr is super low. really want to figure that calcualtion out...stock bore stock compression cosworth piston, 54cc combustion chamber turbo tuff rod, standard sized cosworth head gasket. i wanna raise the CR and run less boost...like 24#s max.
acl rod and main bearings...gonna do stock main and plus one rod bearing with 12mm pump.
intake manifold gasket x2 for 10mm phenolic spacer
clean cai air filter
install 2nd walbro
crank fuel pressure to 60psi for e85
remove and reinstall rom raider to try and sort out why my computer crashes while logging...
replace broken wheel stud
upgrade calipers rotors and pads
install act 6 puck with hd pressure plate and oem 6 speed flywheel
weld up rotated throttle body, rotated turbo turbo xs front mount
so...dont see having this done for tuesday considering everywhere is closed for labor day tomorrow...
Old 09-04-2011, 01:15 PM   #1385
Junior2JZ
Member#: 64908
10.8 XT+10.0@143 GR+
9.0@170mph GTR
crank boost pressure to 60psi for e85
I like this revision better
Junior2JZ is offline   Reply With Quote
Old 09-04-2011, 01:21 PM   #1386
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
your a wild man. my 30rs efficency range is what 24-28#'s?
back in the holster dr. J.
i need parts dood!
Old 09-04-2011, 08:30 PM   #1387
Junior2JZ
Member#: 64908
9.0@170mph GTR
i need parts dood!
Fyck that lil ghey turbo. I showed you the truth. Wouldn't you rather wait 200rpm more for an extra 50whp across the board at the same boost??
What 30r kit do you have anyway?
Old 09-04-2011, 08:38 PM   #1388
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
perrin 3076r 63 hotside with tial 44 ewg rerouted to 3 inch 4 bolt downpipe...still in greta condition.
why can you help me get a 35?
i have no illegiance. id sell it for a 35r...not interested in stock location though.
no doubt you showed me truth, but im just workin with what i got.
Old 09-04-2011, 10:16 PM   #1389
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
but a damn pain in the ass to remove...
karlknaupp is offline   Reply With Quote
Old 09-04-2011, 10:41 PM   #1390
wrspeed
Member#: 40110
04 STI
131 MPH 4th gear Madness
don't listen to JR he's just jealous of my n/a 1999 single cam forester...22.2@ 45mph on e85.
wrspeed is offline   Reply With Quote
Old 09-04-2011, 10:43 PM   #1391
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
for you...not so much.
your the man for hosting and helping though.
i bet junior wants to hook me up with daggers kit.
dr. j...my kit plus cash?
Old 09-04-2011, 11:22 PM   #1392
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
ill give you a couple hundro for it...
Old 09-04-2011, 11:29 PM   #1393
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 09-04-2011, 11:41 PM   #1394
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
You thinking of selling the whole kit or just the turbo?
I might be in the market for a whole 3076 kit.
I need that, a 2.5 shortblock, new clutch and a standalone before october. I want to get the green car in the 10's.
69subaru360 is online now   Reply With Quote
Old 09-04-2011, 11:47 PM   #1395
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
yeah the whole kit. its in great shape. your welcome to inspect it, no hard feelings. i know you know what your talking about...
make me an offer, and i'll tell you if we are in the same zip code.
also...jodie just build a 257 shortblock, dont know if he posted it yet. i can get you a good price on that either way.
i'll let my id1000s go as well.
Old 09-05-2011, 12:17 AM   #1396
wrspeed
Member#: 40110
04 STI
MAX
the 30-76 will get it done we ran 10.8 with it but if you want to play it safe and run deep into the 10s than hell yeah on the 35-82 all day...perfect street turbo.
Old 09-05-2011, 12:47 AM   #1397
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i hear ya cleo...seems like dr. j is gunning for me to run with the big boys.
but i dont have big boy coinz! unless you can convince rich to give me a job...
maybe you guys didnt hear me the first time...I WANNA WORK AT PRECISION!
hire me rich!
Old 09-05-2011, 01:26 AM   #1398
karlknaupp
Member#: 60871
2004 WRB WRX
'10 WRB STI SE stg2
ha so it sounds like you should hook somebody up with that kit...
ha i cnt afford it..
Old 09-06-2011, 11:59 AM   #1399
bugeyesubby
Member#: 220401
02 Home built WRX
35rcam'd2.5 CleoTuned@PTM
Jake...I have a 3582 on my car right now I will sell you BUT its the .63 hot side. Spools fast and not to bad on max HP as cleo will tell you or if you want something slightly bigger I have a turbo that ive been debating if I wanted to use or not. Also as for that job at percision, my app. was in before yours lmao. You have my number hit me up
bugeyesubby is offline   Reply With Quote
Old 09-06-2011, 12:16 PM   #1400
06njsti
Member#: 150986
06 #001 LSB STi
Motors out. Karls/rons stroker in tomorrow for start up. Hakt ecu to last minute for rods. Dont let me down jo-d...running tues night if extreme psi/cherry hill subaru is stocked.
you know I stock **** like its my job! Dont give me any excuses get that **** in tonight!
I know someone selling a engine stand and engine hoist for $250 if you boys are looking for another one.
-Gary
06njsti is offline   Reply With Quote
