Old 05-14-2010, 10:14 PM   #151
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
jodie thinks i will most likely break a rear axle first. i have yet to break all four tires loose on a launch like i have seen jaime and junior do...
i guess i have yet to fully commit!
maxpowr is offline   Reply With Quote
Old 05-15-2010, 02:35 AM   #152
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by maxpowr View Post
i've been practicing lauching but am either boggin or burnin. if i don't figure it out soon i'll probally just roll into a 2.0 60ft.
i stab the gas to 5k. as i push the gas in i dump the clutch about 3/4's out then full throttle clutch all the way out. i believe have not been dumping the clutch enough to hook up and not burn the clutch up. i guess i should have more confidence in the 6 speed.
i have an act stage one organic clutch with streetlight flywheel on my 04 six speed.
You're going to need to launch it higher than 5k with a lw flywheel, gt30 and a little 2.0, especially on a sticky track. Don't even try to slip that clutch with that kind of power, once it starts slipping it will keep slipping all the way through 1st gear. One good clutch burning run and it's done for the night, it'll slip on the rest of the runs, that's how organics are. Sometimes they recover with lots of driving around.
Can't somebody put LC on it for you?
If not try reving it between 5k and 6k work the gas as fast as you can on and off to build boost. Once you see the boost come up a little, as the gas pedal is going down, sidestep the clutch. You might need even more rpm to get it to 60 foot, seriously.
It should go 115-120 if the motor stays together. Even with a good tune that saves the pistons, the rod bolts in a 2.0 like to break with that kind of power.
I think you'll spin the tires you're running before you break an axle.
GL, maybe I will try to make it out to atco to see it run someday.
Old 05-15-2010, 02:44 AM   #153
ramair18954
Member#: 28308
03 td-06 wrx ra-c
Platinum
yeah, agreed with the launch method. With my act 6puck I have lag off the line. I really have to get into the 6500-7000 side step, otherwise I get a bog. Gl I hope you break 11's.
ramair18954 is offline   Reply With Quote
Old 05-15-2010, 08:44 AM   #154
06njsti
Member#: 150986
06 #001 LSB STi
I light all 4 up on a pretty often basis and havent broken anything.....yet. Anyway i found out that my new sweet spot launching with the new wheels is right around 4.5-5k.
06njsti is offline   Reply With Quote
Old 05-15-2010, 09:24 AM   #155
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
your 2.5l helps...
i'll get ron to send me a launch control...5500?
din din din din din din din ...drop clutch, go for broke! wait that didn't sound right.
Old 05-15-2010, 09:54 AM   #156
IMPREZive 02 WRX
Member#: 11436
1999 Impreza RS
eBay racing edition!
Default maxpowr phatbotti tuned 2.0 gt3076r
your 2.5l helps...
It's really different for every car, but with lc, you generally wouldn't need to launch as high as you would without it since you're leaving the line under boost. It's more or less trial and error with setting lc and it'll be different on the track vs where you'll be testin it. Doing that via email will be a huge pain in the ass.
Sent from my iPhone using Tapatalk
IMPREZive 02 WRX is offline   Reply With Quote
Old 05-15-2010, 10:17 AM   #157
69subaru360
Member#: 159682
1995 WRX
2015 F150
It takes 2 seconds to change the LC rpm with ecu flash once the LC patch is installed. Anyone can do it, just punch in the number.
Old 05-15-2010, 11:04 AM   #158
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
i just went out and did some pulls...
im surprised how quick i can shift this tranny. its so nice.
Old 05-15-2010, 11:05 AM   #159
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
rear axles almost never break, is usually the front ones
juanmedina is online now   Reply With Quote
Old 05-15-2010, 11:57 AM   #160
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
your 2.5l helps...
your proly goin want it alil higher. Like everyonne else said if you were goin launch it without LC youd want to rev it around 6.5k
Old 05-15-2010, 02:28 PM   #161
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Originally Posted by Phatron View Post
Well I guess I'm proven wrong again.
Jake you should pull that 30r off and upgrade to an 18g. You'll only have 15 hp less and a better powerband.
I hope you weren't being sarcastic.. It will def be a faster car on 93.
Originally Posted by STi Mikey View Post
Very Ironic,
Jakes car would make 380-385whp on a dynojet. Its good for 115-116 on pump, but is almost impossible to get out the hole from what he has told me and from what i have seen him do at the track.
That is what I said 370-380
This is exactly my point to Ron.. This 380 may trap around 115-116 due to the peaky power band, while the 330-340 whp car has already trapped 116-117 because of its nice power band. It will usually ET better because of the TQ curve.
Rear axles always break, the fronts hardly ever let go. Newb
Junior2JZ is offline   Reply With Quote
Old 05-15-2010, 02:35 PM   #162
SVT_WRX
Member#: 164830
G61 III OVE 58e
Hmmm.....nice power band huh? I'd like to see what that looks like. Got a link?
SVT_WRX is offline   Reply With Quote
Old 05-15-2010, 03:06 PM   #163
Junior2JZ
Member#: 64908
9.1/157mph 2015 STI
Here is one recent one. I did a strong 30r car 2 weeks back I will see if I can get the file to do a compare with when I get home from vaca.. out in SoCal right now
Dyno RPM is about 300-400rpms slow BTW
Old 05-16-2010, 01:01 PM   #164
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Since when does jakes car have a peaky powerband? He's hitting 20 psi by 4k
And since when is it hard to stay in any powerband on a short geared 6 speed?
Old 05-16-2010, 01:12 PM   #165
69subaru360
Member#: 159682
1995 WRX
2015 F150
What year 6 speed is it? The shift to 5th is going to suck with a little stock 2.0 if it's the older one, it'll have a hard time recovering from that rpm drop.
I still think it can go high 11's at 115+ if the motor doesn't pop.
Old 05-16-2010, 01:18 PM   #166
Phatron
Member#: 36033
CEO PhatBottiTuning
It's a short geared 6 speed.....so 04-06.....I believe it is an 06.
Old 05-16-2010, 08:08 PM   #167
Paul
Member#: 56203
00 RSTI Coupe
in what gear does it hit 20psi by 4k?....can you post logs?
Old 05-16-2010, 08:16 PM   #168
Phatron
Member#: 36033
CEO PhatBottiTuning
i think i lied. been looking at too many logs lately.
he's supposed to send some logs shortly.
Old 05-16-2010, 08:31 PM   #169
Paul
Member#: 56203
00 RSTI Coupe
yea unless your talking about 6th gear...
and his powerband is def peaky compared to a 18g setup....proly peaky in just general
Old 05-16-2010, 09:26 PM   #170
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
its an 04 6 speed for those who don't know. rem treated stock. all new sycros, bulk rings, and shift forks.
ron-you have data.
Old 05-16-2010, 10:15 PM   #171
Phatron
Member#: 36033
CEO PhatBottiTuning
um no....i wasnt that far off 4300rpm in 4th gear....
Old 05-16-2010, 10:48 PM   #172
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
the manual boost controller needs replace. no offense karl...thank you for that.
i chirpt third for the first time.
Old 05-16-2010, 10:51 PM   #173
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
welcome to phatbotti tuning.
open 24hrs a day
"we never close"
"got internet"
Old 05-16-2010, 11:09 PM   #174
Phatron
Member#: 36033
CEO PhatBottiTuning
stop slacking and send me more logs
Old 05-16-2010, 11:56 PM   #175
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
3rd and 4th gear pull coming up.
