Old 05-09-2012, 03:43 PM   #1926
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
I'm a little confused on waste gate spring selection...what determines spring size?
maxpowr is offline   Reply With Quote
Old 05-09-2012, 04:15 PM   #1927
karlknaupp
Member#: 60871
2004 WRB WRX
waste gate? thought you were talking bov?
karlknaupp is offline   Reply With Quote
Old 05-09-2012, 04:55 PM   #1928
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Something wrong with the setup you've been running?
Old 05-09-2012, 05:06 PM   #1929
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Wg spring size u basically determine by what kind of fidelity u want in the boost control and how much of a failsafe of boost drop u want.
If u run a 20psi spring then 20psi is the lowest you can cut boost to. And it would only take you 1-2% wgdc to run 21-22psi.
If u run a 14psi spring u can cut boost to 14 and you will have way more leeway in the wgdc. IE running 40% to hit 22psi.
I just went over most of this in the FAQ
Old 05-09-2012, 06:46 PM   #1930
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
I see the light...this is separate from your over boost prevention in the ROM?
Old 05-09-2012, 07:15 PM   #1931
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
shes ready to go in.
ron do you remember what your torqued your pressure plate bolts to?
Old 05-09-2012, 08:04 PM   #1932
Phatron
Member#: 36033
CEO PhatBottiTuning
german torque specs
gooden tight
Old 05-09-2012, 08:24 PM   #1933
karlknaupp
Member#: 60871
2004 WRB WRX
haha best torque
Old 05-10-2012, 03:05 PM   #1934
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
its in there like ragu...
Old 05-10-2012, 03:49 PM   #1935
karlknaupp
Member#: 60871
2004 WRB WRX
its in backwards...
Old 05-12-2012, 02:13 AM   #1936
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
Originally Posted by Phatron View Post
german torque specs
gooden tight
Surprisingly never heard that before.
VladiWrX is offline   Reply With Quote
Old 05-15-2012, 02:50 AM   #1937
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
installed header, turbo and some fuel lines...
guess a quick disconnect or push on wont work here...
3076r .63 installed.
Old 05-15-2012, 09:05 AM   #1938
CatfaceType-R
Member#: 81102
looking good dude, do that hybrid boost control too(I think you were already going to, no?)
praying to the subi gods for many hard miles and good power.
CatfaceType-R is offline   Reply With Quote
Old 05-15-2012, 11:10 AM   #1939
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
german torque specs
gooden tight
I thought that was german for virgin...
mccanixx is offline   Reply With Quote
Old 05-15-2012, 12:49 PM   #1940
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Soon-- I'm just gonna run a hallman and have over boost protection in the rom. Gonna work on installing the walbro 400 direct to battery tonight.
Anybody have a link or detailed instructions on how to hook up the pump direct while still using the fuel pump controller? Juniors explained it to me many times but a diagram would be really helpful.
Old 05-17-2012, 03:06 PM   #1941
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 05-17-2012, 04:32 PM   #1942
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
so been working with phil...big up brother. looks like we are gonna run a -6an quick disconnect from the feed on the stock tank cover to a -6an 90 to a -6an fuel filter to feed the -6an Y that splits to -6an to both rails. then -6an from each rail to the FPR. out of the FPR -6an to an AN compression fitting to stock 5/16 return to the tank. so the return will stay stock, but looks like i will have to drop the tank to run the feed.
the lines in my 02 wrx run up the drivers side, not the center...
Old 05-19-2012, 11:46 AM   #1943
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
and for my next act...i will remove oil from my take system!
Old 05-19-2012, 01:17 PM   #1944
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 05-20-2012, 11:21 AM   #1945
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 05-24-2012, 09:00 PM   #1946
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Old 05-24-2012, 10:18 PM   #1947
karlknaupp
Member#: 60871
2004 WRB WRX
that looks familiar..
Old 05-24-2012, 10:30 PM   #1948
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
big up karl. i think its gonna work.
Old 05-27-2012, 01:46 PM   #1949
RFoy91TSi
Member#: 57488
1998 GC8 EJ205 VF34
[email protected] STi Mikey Tuned
is that pipe JB welded?
RFoy91TSi is offline   Reply With Quote
Old 05-27-2012, 04:10 PM   #1950
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
what pipe? no jb weld here...
worked on my jdm headlights...
