South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 03-01-2010, 03:47 PM   #1
shemoves
Member#: 80663
2005 STi
Default Any issues with smog test and e85?
I have to get the test done soon. I usually run about 17% e85 and am wondering if I should keep the e85 in there when I have the smog test done. Also, are there any little things I should do to the map that will help? I am catted, so it should not be an issue, but I'd rather have it pass on the first try.
shemoves is offline   Reply With Quote
Old 03-01-2010, 03:48 PM   #2
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
E85 burns cleaner than gasoline. But AZ doesn't do a sniffer test right, so they are only checking for CELs?
blkscooby is offline   Reply With Quote
Old 03-01-2010, 04:56 PM   #3
Erik
Member#: 168774
Are you obdII? If so they just to a readiness monitor check, check for cels, and a gas cap check. E85 shouldn't cause any problems with that.
Erik is offline   Reply With Quote
Old 03-02-2010, 12:21 AM   #4
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
This^
v8eaterWRX is offline   Reply With Quote
Old 03-03-2010, 01:59 PM   #5
shemoves
Member#: 80663
2005 STi
Car is a 2005 (thus OBDII). I've got a cat and dont have any CELs so I will pass the inspections there. My understanding is that they still do an idle sniff test though (can't run it on the dyno), is this incorrect?
Old 03-03-2010, 02:30 PM   #6
Erik
Member#: 168774
No sniffer test. I've passed fully catless before.
Old 03-03-2010, 10:59 PM   #7
ChandlerWRX06
Member#: 184206
2013 X1 sDrive 28i
gray
short answer.
No.
Youll be fine.
ChandlerWRX06 is offline   Reply With Quote
Any one have any issues with a TurboXS TBE in PA? Soulofdarkness Mid Atlantic Impreza Club -- MAIC 18 05-02-2006 04:59 PM
Any issues with Borla Hush and trailer hitch clearance? whtlegacy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-08-2004 04:27 PM
Any issues with stock turbo/injectors with Walbro pump? wagon-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 01-27-2004 03:07 PM
Guys running a catless down-pipe and cel fix.Any probs with OBDII testing? Camperguy New England Impreza Club Forum -- NESIC 7 08-11-2003 07:51 PM
Any issues with Eibach springs? B-Kerr Brakes, Steering & Suspension 2 05-29-2003 03:09 AM
