Old 03-01-2010, 04:03 PM   #1
surfsubaru
Member#: 239435
Default bypass rear cat o2 sensor, is mechanic worng?
I have a 01 impreza rs. I installed 1 spark plug anti fouler (didnt seem to have enough clearance for two) reset the brain by leaving power disconnected. Started up, no code for about a minute then it poped back on!!!
Im thinking that I may need a new o2 sensor because its old.
does anyone know out there is when it throws a rear o2 cel does it actually change anything in the operation of engine performance?? because i swear when it would would come on along time ago I would notice a difference (very slight) and a mechanic told me that if the rear goes out, the car will run richer? and that you can actually tank your cat all because of not replacing the sensor??
is this true?
surfsubaru is offline   Reply With Quote
Old 03-01-2010, 04:28 PM   #2
bigfishs
Member#: 114848
2004 STI
The rear is only used for emissions and does not effect fuel trim so you will be fine engine wise. I think on newer cars with higher bit ECUs it may be used for more IIRC.
There was a big thread on this recently if you are up for some reading hit up the search function
bigfishs is offline   Reply With Quote
Old 03-01-2010, 04:44 PM   #3
van_dutch
Member#: 198633
2004 WRX
What code are you throwing?
van_dutch is offline   Reply With Quote
Old 03-05-2010, 03:36 PM   #4
surfsubaru
Member#: 239435
Im not sure, its been so long but I will be checking it
Old 03-05-2010, 03:43 PM   #5
EastCoast02
Member#: 71116
2002 ej257 WRX
The code will prob tell you if it's a bad sensor or not. If it's not bad you'll prob just get a cat efficiency code. The spark plug anti-fouler worked for my emissions one time (still feel like I kind of got lucky with that one), used a MIL eliminator one time (wire it into the o2 sensor wires), but now I just use a tactrix cable and romraider
EastCoast02 is offline   Reply With Quote
Where is the Pre cat O2 sensor? 95 avus blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-14-2005 10:28 AM
Where is the Pre cat O2 sensor? 95 avus blue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 09-12-2005 10:57 PM
Which o2 sensor is the front, and which is the rear? jamesfacts Normally Aspirated Powertrain 4 07-06-2005 11:09 AM
Best price Cat O2 sensor rbehny Mid Atlantic Impreza Club -- MAIC 3 06-01-2005 11:15 AM
Post Cat O2 Sensor Blaspherian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 12-05-2002 01:11 PM
