Old 03-01-2010, 06:05 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default Exciting New Head Option for EJ20/EJ25 Hybrid Builds!
We are excited to announce that we have a great new option for the 2.0/2.5 hybrid folks! As most people know, when you run a 2.5l shortblock with 2.0l heads, the compression ratio is too high to run safely and efficiently. The common approach to resolve this is to use a thicker head gasket to try to bring the compression ratio down. While this can bring the overall compression ratio down, it is by no means ideal. The resulting combustion chamber shape remains inefficient since you're leaving the 2.0l chamber in the heads untouched. You are in essence reducing the effectiveness of the quench area and introducing several sharp edges to the combustion chamber that can build up heat and cause knock. This makes the engine less efficient than a full EJ257 with EJ257 heads.
Instead of using a thicker head gasket, we decided to try something a bit different. We worked closely with our machine shop to actually map out the combustion chamber of the EJ257 STI head and create a CNC program to replicate the exact same chamber every time. Using this program, we then set up the 2.0l head castings in the CNC and machine out an exact copy of the 2.5l combustion chamber into each 2.0l head casting. We are then able to use a quality OEM head gasket and maintain the exact compression ratio of a complete STI engine. This improves the effectiveness of the quench area and the overall efficiency of the engine because you now have the exact same combustion chamber as a full EJ257.
We have done several hybrid builds with this approach now and have seen great results not only in overall power output, but especially in terms of crisp, smooth off-boost drivability and torque. We've also seen a significant increase in fuel economy as compared to a standard hybrid build. From a tuning standpoint, the difference is so significant that we had to spend quite a bit of time building new base maps for these builds. Under low load conditions, these setups can run as much as 15-20 degrees more timing advance than a hybrid build with a thicker head gasket. This was a great thing to see as we end up with a timing curve much more similar to an STI rather than a 2.0l WRX.
This service is available for any EJ205 and EJ207 heads and its $500 for a set of heads.
Please download and fill out this order form when placing an order or sending in heads: http://eqtuning.com/forms/EQ-HEAD-FORM.pdf
Here are some pictures of the process:
And final product:
*** UPDATE: We can now perform the same service for EJ207 heads! ***
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-01-2010, 06:07 PM   #2
rmkcent
Member#: 185290
2003 Wrx Wagon
Sedona Red
Congrats ed!
rmkcent is offline   Reply With Quote
Old 03-01-2010, 06:21 PM   #3
25rsti
Member#: 166324
< wow! nice. keep the hybrid ideas coming :-)
Old 03-01-2010, 06:52 PM   #4
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
congrats on the cnc program but I know Dominic from maxwell power as well as myself have always bore matched the combustion chambers on the hybrids we have built.Once again good job on making a cnc program.
john 1badSTI is offline   Reply With Quote
Old 03-01-2010, 07:42 PM   #5
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep I definitely know that modifying the combustion chamber is not a new idea, but the CNC program is really helping to keep things consistent and precise. Its also nice to know that the result is an exact copy of the STI CC. I'll have to take some pictures of the process next time we're doing one.
Thanks
-- Ed
Old 03-01-2010, 07:56 PM   #6
hobbesnapoli
Member#: 221436
02 WRX vf39
Does this require new valve seats or any other parts?
hobbesnapoli is offline   Reply With Quote
Old 03-01-2010, 08:18 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Nope... most of the material that's removed is on the outer perimeter of the combustion chamber and the valve seats are untouched.
Thanks
-- Ed
Old 03-01-2010, 08:18 PM   #8
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is a good option for those who want to run the same compression ratio as the STi.
Congrats!
FuJi K is online now   Reply With Quote
Old 03-01-2010, 08:27 PM   #9
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Pretty fair price also!
Token-Negro is offline   Reply With Quote
Old 03-01-2010, 09:09 PM   #10
john 1badSTI
Member#: 77470
Thanks
-- Ed
hey ed it would be even cooler to make a short video to watch it being down in action.+1 most guys on here have never seen a cnc machine at work.
Old 03-01-2010, 10:42 PM   #11
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Hey Ed Im glad you posted this over here, theres quite a few hybrids over here.
rexworx is offline   Reply With Quote
Old 03-02-2010, 12:25 PM   #12
Concillian
Member#: 4414
2002 WRX Sedan
Midnight Black
Ed --
People seem to favor the D25 chamber shape over the STi B25 / V25 chamber shape. I can't find the comment, but I thought you also noted something to the extent of 2.5L WRXes tending to make slightly more power than the STis with similar mods.
I know it's a small difference, but I'm just curious why you chose to replicate the STi chamber instead of the D25 casting chamber?
Concillian is offline   Reply With Quote
Old 03-02-2010, 12:31 PM   #13
rexworx
Member#: 103232
^^^+1000
Old 03-02-2010, 02:28 PM   #14
sidewayz
Member#: 5810
2001 S366 2.5RS
Ed, how would you like the heads to arrive? Empty? Or with valves and springs?
sidewayz is offline   Reply With Quote
Old 03-02-2010, 03:09 PM   #15
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by Concillian View Post
Ed --
I haven't seen 2.5l WRX's make any more power than a similarly set up STI. Actually I usually see the 2.5l WRX's taper off peak power more severely up top as compared to the STI. I think that has to do with the higher CR and the resulting drop in timing up top.
I think you might be thinking about using the EJ255 shortblock for hybrid builds. Since the EJ255 pistons are dished more than the EJ257 pistons, this would bring the CR down as compared to using an EJ257 shortblock. Using the D25 chamber with EJ257 pistons would actually create a very high CR which is counter productive .
Thanks
-- Ed
Old 03-02-2010, 03:15 PM   #16
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
If you want to save some money, they should come in empty. We're always happy to disassemble and re-assemble them for you, but we do have to charge for that service.
Thanks
-- Ed
Old 03-02-2010, 04:24 PM   #17
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
I have set of new, undressed ej205 heads. When I get the money I'm totally doing this!!!
PSolbergfan is offline   Reply With Quote
Old 03-02-2010, 10:14 PM   #18
prometheum
Member#: 92003
04 bicycle!
Ed --
correct me if i'm wrong, but d25 is the ej255 head right? i assume you simply couldn't do it because according to this thread the ej205 and ej255 have roughly the same volume.
prometheum is offline   Reply With Quote
Old 03-02-2010, 10:55 PM   #19
bettyblue
Member#: 90920
2005 2.0FPGREEN 6SPD
2002 bugeye Vf39
a little off topic, but what would be an ideal head gasket to use after performing this?
bettyblue is offline   Reply With Quote
Old 03-02-2010, 10:56 PM   #20
Merp
Member#: 199106
PMme 4 Speed Density
Patches on OEM ECU
Well, I wouldn't call it a "very high" CR at 8.78:1. However, the D25 will only knock off 1 point compared to the WRX S20 heads (8.88:1).
D25 chamber machining, if possible, would be a good option for meth/E85, and some pump applications.
Merp is offline   Reply With Quote
Old 03-02-2010, 11:05 PM   #21
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Good price, but this isnt anything new.
scby rex is offline   Reply With Quote
Old 03-02-2010, 11:05 PM   #22
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
What is the disassembly/assembly cost?
CKxx is offline   Reply With Quote
Old 03-03-2010, 01:30 AM   #23
deezel_d
Member#: 195272
i am a noob here but trying to do a hybrid i have a built 257 and a complete ej20k that i was gonna use the heads off of.....do i have to do same thing with these heads..
deezel_d is offline   Reply With Quote
Old 03-03-2010, 02:44 AM   #24
j255c
Member#: 89554
2006 EVO SE
Black E85 30PSI dd
Why not design the machining process to mimic the ej207 heads? Those are after all the most efficient best flowing heads Subaru produces no?
j255c is offline   Reply With Quote
Old 03-03-2010, 08:34 AM   #25
rexworx
Member#: 103232
^^^ Its the bore, and volume thats is oppened up...
Oil Leak on Driver's Side after EJ257 Hybrid Build lancelucas Service & Maintenance 13 11-25-2014 04:42 PM
ej257 hybrid build imc343 Newbies & FAQs 3 05-06-2010 01:58 PM
FS: 2002 WRX 2.5 EJ257 Hybrid Build 02WRXmoddedrex Private Vehicle 'For Sale' Classifieds 3 04-14-2010 09:25 PM
new Sti options for the New Impreza Reiflex General Forum Archive 9 12-22-2000 12:27 AM
