Old 12-23-2010, 05:17 PM   #276
Sparcomx
Member#: 1791
will you offer a xmas sale on this service ???
Sparcomx is offline   Reply With Quote
Old 12-23-2010, 05:44 PM   #277
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Sorry, but we're way too swamped with work to be running sales .
That said, we're not building much margin into our pricing on these services, so a sale wouldn't make sense anyway.
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 12-28-2010, 02:36 PM   #278
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 12-30-2010, 03:49 PM   #279
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 01-01-2011, 11:11 PM   #280
mewantsubie
Member#: 161890
2003 Impreza WRX Wag
96 Impreza OBS
Sorry if this has been asked, but I was wondering about opening the heads up even more for bored blocks. If it makes that big of a difference to open a 2.0 head to a 2.5 then I would think that 2.0, 2.2 and 2.5 would see benefits for the head being properly sized to the bore. Have you tried this? If you have, does it make a difference? I'm sure that a formula could be figured out. Seems like this could be a nice deal for people who bore their 2.0 2.2 and 2.5 blocks to over sized pistons.
Example, I have a 2.5 Sti block that I am building for a hybrid set up and I have a set of Cp 100mm pistons to go in. Instead of opening the heads up to a 2.5 could you opening them up an additional .5mm to match the bore of my block?
mewantsubie is offline   Reply With Quote
Old 01-03-2011, 01:26 PM   #281
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That extra .5mm I very small and I doubt it would make much of a difference. We use 100mm pistons in most of our builds and they work very well with the 2.5l chamber.
-- Ed
Old 01-03-2011, 07:16 PM   #282
roof_rack
Member#: 257866
What is the average turn around time?
roof_rack is offline   Reply With Quote
Old 01-04-2011, 04:02 PM   #283
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
We're getting these turned around in 2 weeks consistently.
Thanks
-- Ed
Old 01-05-2011, 02:40 PM   #284
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 01-12-2011, 01:24 PM   #285
mhoerath
Member#: 131379
2003 354 [email protected] rpm
justablue hatch
should the heads be decked and valve seat grind completed, then send the empty heads for cnc?
I'm having a shop rebuild my 2.0 into a 2.5 bottom, 2.0 heads. I prefer they perform all head work except the cnc. Part of the issue is down time to outsource the cnc...how can the 2 weeks be shortened?
mhoerath is offline   Reply With Quote
Old 01-12-2011, 03:36 PM   #286
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I would do the CNC first, then have your shop do the valve job, deck, cleaning and final assembly.
Sometimes we can get them turned around quicker, but can't promise it.
-- Ed
Old 01-12-2011, 03:49 PM   #287
mhoerath
Member#: 131379
justablue hatch
and payment is up front or billed after?
Old 01-13-2011, 02:44 PM   #288
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Payment is taken when we receive the heads from the customer.
Thanks
-- Ed
Old 01-18-2011, 08:31 PM   #289
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 01-19-2011, 02:08 PM   #290
trev2eagles
Member#: 216281
2003 WRX Forged 2.5
-- Ed
what level of boost could you run safely without linering, I understood 25psi/1.72bar.
thanks
Trev
trev2eagles is offline   Reply With Quote
Old 01-20-2011, 06:13 PM   #291
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I've run up to 30psi on the stock sleeves, but I wouldn't expect that to be reliable indefinitely. 25-27psi should be nice and safe assuming everything else is in good shape.
-- Ed
Old 01-21-2011, 04:02 PM   #292
ogboot
Member#: 170906
psm
/subscribed.
ogboot is offline   Reply With Quote
Old 01-22-2011, 03:07 PM   #293
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 01-26-2011, 10:19 AM   #294
Ender81
Member#: 104211
Any chance of you guys starting a purchase/core return service? Being in PA I don't get a warm fuzzy feeling sending my heads out to cali and then waiting but if I could just purchase the already machined heads and send in mine as a core that would be great. Understanding of course my heads would have to be in a condition equal to those being purchased etc....
Ender81 is offline   Reply With Quote
Old 01-26-2011, 10:34 AM   #295
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'm guessing there would have to be around a $1K core charge. Would you be cool with that?
Old 01-26-2011, 11:54 AM   #296
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Exactly correct. We would have to be able to replace the cores in case yours were no good and it's not easy to find good used cores. The other problem is that a lot of the 2.0 heads develop small cracks around the spark plug port, so I doubt we could keep cores in stock. The other part is that different people choose different services to go along with the CNC work so things could get complicated. We're always happy to provide brand new castings if you'd like, but obviously you have to pay for them.
Thanks
-- Ed
Old 01-26-2011, 06:13 PM   #297
driftingrotary
Member#: 234715
2003 wrx
charcoal
hey i had a quick question for you guys, will the $400 service with the grind match the chamber match the ej257 shortblock's so that the little edge's heat on the heads does disappated properly? the major flaw in hybrids and why they're so unreliable and ringlands tend to blow.
driftingrotary is offline   Reply With Quote
Old 01-26-2011, 08:42 PM   #298
paintbing
Member#: 59388
2003 WRX - Hybrid
I do my own stunts
^ I think that is the primary purpose of the combustion chamber shaping... it removes the lip/edge from heating up. They also shape it to the 257 heads at the same time to match/mate correctly with the ej257 block.
paintbing is offline   Reply With Quote
Old 01-26-2011, 09:45 PM   #299
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Correct... the main reason is to get rid of those sharp edges. The secondary reason is to bring the compression ratio back into factory spec for an EJ257 longblock.
Thanks
-- Ed
Old 01-28-2011, 06:45 PM   #300
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Oil Leak on Driver's Side after EJ257 Hybrid Build lancelucas Service & Maintenance 13 11-25-2014 04:42 PM
ej257 hybrid build imc343 Newbies & FAQs 3 05-06-2010 01:58 PM
FS: 2002 WRX 2.5 EJ257 Hybrid Build 02WRXmoddedrex Private Vehicle 'For Sale' Classifieds 3 04-14-2010 09:25 PM
new Sti options for the New Impreza Reiflex General Forum Archive 9 12-22-2000 12:27 AM
