Old 01-29-2011, 01:52 AM   #301
Bugeye_Josh
Member#: 242354
02 WRX
Sedona Red Pearl
If i were to send my new valves/seal/springs etc all standard size would you install them along with the service? Or do you need the heads sent to you bare?
Bugeye_Josh is offline   Reply With Quote
Old 01-29-2011, 03:15 AM   #302
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
We can install the valve train, but you would have to pay for the assembly. The $400 price is assuming we receive and ship out completely bare castings.
Thanks
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 01-30-2011, 12:21 AM   #303
Bugeye_Josh
Member#: 242354
02 WRX
Sedona Red Pearl
What would the price be if i send you bare heads with my new valve train?
Old 01-31-2011, 05:06 PM   #304
Wagun
Member#: 106433
2004 WRX wagon
This would seem like the perfect use for a PM.
Wagun is offline   Reply With Quote
Old 02-01-2011, 04:32 PM   #305
Ender81
Member#: 104211
Originally Posted by kellygnsd View Post
I'm guessing there would have to be around a $1K core charge. Would you be cool with that?
Actually yeah that would be fine, building a motor is not the time to be cheap
Originally Posted by Equilibrium Tuning View Post
Exactly correct. We would have to be able to replace the cores in case yours were no good and it's not easy to find good used cores. The other problem is that a lot of the 2.0 heads develop small cracks around the spark plug port, so I doubt we could keep cores in stock. -- Ed
Taking a deposit, some pictures of my heads I'd be sending as a core etc... YYou don't know until you try
Ender81 is offline   Reply With Quote
Old 02-04-2011, 11:38 AM   #306
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Bump!
Old 02-08-2011, 04:13 PM   #307
Ender81
Member#: 104211
Ok Ed I'll bite and take a chance here. You still looking at a two week turn around?
Old 02-08-2011, 06:19 PM   #308
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yes sir, we're getting them turned around consistently in 2 weeks. We've been doing A LOT of these lately!
-- Ed
Old 02-08-2011, 08:06 PM   #309
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
Any chance of you guys doing a CNC program for less cc's volume, maybe like the shape of the 06'-07' wrx chambers? That way it would match the 2.5 bore and not be quite so much volume.
I don't know if it would be possible, but that would allow the De-stroker guys a way to get their compression up a bit more with the shelf pistons available.
Just another option to offer your customers.
morrocco88 is offline   Reply With Quote
Old 02-08-2011, 10:44 PM   #310
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Its something we may consider in the future, but a lot of time went into creating the current CNC program and I doubt my machine shop is going to want to go through it again any time soon .
-- Ed
Old 02-09-2011, 10:35 AM   #311
Ryan314
Member#: 82989
Hybrid EJ257
Why would their be a difference in volume between the 06-07 WRX chambers and the STI?
Ryan314 is offline   Reply With Quote
Old 02-09-2011, 11:33 AM   #312
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Slight difference in CR.
Old 02-09-2011, 11:50 AM   #313
Ryan314
Member#: 82989
Hybrid EJ257
Learn something new every day
Old 02-09-2011, 02:01 PM   #314
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yep, the 06-07 WRX has a different combustion chamber and piston design which overall raises the compression a bit. We actually worked with CP to develop an EJ255 specific piston to use in WRX's.
Thanks
-- Ed
Old 02-09-2011, 03:11 PM   #315
DatDude
Member#: 96157
2000 Impreza RS-T
Silverthorn Metalic
I read a few pages back about people getting specific JE pistons for their hybrid setup, now if I send my heads in to get the CNC work done, will I require different pistons or off the shelf weisco's/cp's/etc will work without any issues?
DatDude is offline   Reply With Quote
Old 02-10-2011, 11:07 AM   #316
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
With the CNC work, you want to just get standard off the shelf pistons designed for an EJ257.
Thanks
-- Ed
Old 02-10-2011, 09:14 PM   #317
DatDude
Member#: 96157
2000 Impreza RS-T
Silverthorn Metalic
Ok thanks Ed, now some thinking to do...
Old 02-12-2011, 07:44 PM   #318
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 02-16-2011, 05:24 PM   #319
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 02-18-2011, 12:41 AM   #320
smileyou
Member#: 152045
2003 PIA wrx
wrb..future ppg/fggreen
How much would it cost for this service and also a p&P of the heads?
smileyou is offline   Reply With Quote
Old 02-23-2011, 07:37 PM   #321
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
It depends on the P&P you want. A bowl blend is $250 and will get you a large percentage of the gains of a full P&P. The complete P&P with gasket matching is $1000.
Thanks
-- Ed
Old 02-24-2011, 01:49 AM   #322
prometheum
Member#: 92003
04 bicycle!
do you have the equipment to/can you line hone heads?
prometheum is offline   Reply With Quote
Old 02-24-2011, 06:00 PM   #323
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Yes, we can line hone heads, but usually don't like to do it if there's significant damage. The problem is that you end up with a bit of a squish on the cam seals if you have to take off too much.
-- Ed
Old 03-12-2011, 08:27 PM   #324
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Old 03-16-2011, 02:55 PM   #325
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
bump!
Oil Leak on Driver's Side after EJ257 Hybrid Build lancelucas Service & Maintenance 13 11-25-2014 04:42 PM
ej257 hybrid build imc343 Newbies & FAQs 3 05-06-2010 01:58 PM
FS: 2002 WRX 2.5 EJ257 Hybrid Build 02WRXmoddedrex Private Vehicle 'For Sale' Classifieds 3 04-14-2010 09:25 PM
new Sti options for the New Impreza Reiflex General Forum Archive 9 12-22-2000 12:27 AM
