#1 |
Member#: 146863
SWIC
Vehicle:2004 STI jbp 98 fozzy |
looking to go coilovers on my 04 sti. the stock struts have about had it
looking to spend around a g. mostly street use but i would like to start doing some autocross. any suggestions. any places to get some good deals.
#2 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
Go to the Suspension Technical Forum. Awesome advice in there... too bad no one ever reads it.
![]() EDIT: Copied from my post below after the thread went off-topic. OP, here are some options you have at your disposal and the approximate pricing: OPTIONS: 1) BC Coilovers - Dampening/Rebound, spring rate (?) and height adjustable - ~$1000 2) Pair a dampener with a spring setup - Dampening/Rebound and height adjustable 2.1) Struts/Dampener - For this you have a few options, but the only two that really stand out are Tokico D-spec Struts or Koni Yellow Inserts. Both have adjustable Dampening/Rebound and both have superior valving to many cheaper coilover setups. The Koni's are the better option of the two with valving comparable to coilovers in excess of $18xx.xx. The D-specs run $540 and the Koni's run $620-700 2.2) Springs - For this you really have two options as well: Springs or a Ground Control Sleeve setup. With the springs you have a TON of options to choose both rates and height. You can get progressive or linear. Personally, I really prefer the RCE Yellows if you go this route. The Ground Control setup is even more versatile as it gives you a huge variety of spring rates and lengths and the system allows for height adjustment as well. The advantage to the GC setup is that springs are cheap and easily changed to suit your needs. This is an insanely popular autocross setup. Springs run $200-350 (buy em used for maximum saving) and the GC setup runs ~$400 Those are your options. I've personally worked on a variety of setups, but have extensively used Tokico D-specs with RCE springs. They are a great bang for your buck. I've gotten many compliments on how they perform as well as their refined comfortable nature. No bumps or rattles at all. My new setup I'm building will utilize Koni Yellow Inserts in STi housings with a Ground Control Sleeve system. I just need to select my rates now. Good luck and send me a PM if you have any more questions. Last edited by kpluiten; 03-03-2010 at 05:25 PM. |
#3 |
Member#: 14732
SWIC
Vehicle:+ 08 SG6 & 13 B8 Built not bought #0002 |
I can get you BC or megans, i personally like the BCs a little better
#4 |
Member#: 165886
SWIC
Vehicle:2008 Impreza WRX Blue Mica |
Megans FTW
#5 |
Member#: 80736
SWIC
Vehicle:1999 FXT White E85 is for girls |
BC>>>>>Megan, i just got the bc ram models, they are very sweet. the br series will be sweet for street use and fully adjustable as well. pm evil he will take care of you, he is a good guy
#6 |
Member#: 98838
SWIC
Vehicle:2005 STi CGM |
BC makes Megan coilovers... If I were you I would save up a little more and try to find a slightly used set of rce tarmac zeros. They are the best coilover set up for DD IMO.
#7 | |
Member#: 174780
Vehicle:2005 Impreza WRX STi WR Blue |
Why do you need coilovers anyway? Height adjustment is overrated for most applications, the exceptions being if you want to push the limits of slamming your car, you need to adjust for different seasons (shouldn't be an issue in most of the southwest) or if you need the adjustability for the track (corner balancing comes to mind). Tarmac 0s, and KW V1s are the cheapest I would personally go. I've had good experiences with H&R on a lot of other cars and they make an 04 setup which I also might give a shot (it should be a little cheaper than the other two and it still uses bilstein dampers). If you can spend more money, I can't recommend Tarmac 2s or ohlins DFVs enough (I have the latter)...but they're stepping into the $2-3K arena. |
#8 | |
Member#: 120273
SWIC
#9 |
Member#: 120273
SWIC
For you (OP) you can run the Tokico D-spec struts and RCE yellows and it will handle VERY VERY well. That's an excellent setup for sure. The D-specs are adjustable to meet your needs and they handle higher spring rates very well.
#10 |
Member#: 14732
SWIC
#11 |
Member#: 14732
SWIC
GAY double post
#12 |
Member#: 98838
SWIC
I never said they were the same. All I'm saying is if hes willing to spend a little more he could get a way better coilover setup for his car. I think if people were to drive a set of fully dialed in bc coilovers compared to a set of higher end coilovers like the rce's they would clearly see what the better coilover is. Unfortunately, most enthusiasts now days only care about how slammed there car is and too often don't bother to think about the functionally of them.
#13 |
Member#: 14732
SWIC
Maybe someone should tell Phil from element tuning that his BC coilovers suck
#14 |
Member#: 98838
SWIC
Hmm last time i heard he was running the JIC Custom valved FLT-RS. Regardless, if he happened to change his setup, AND IS RUNNING THE BC stuff im almost positive there not some off the shelf coilovers that a regular customer would buy for there dd sti.
#15 | |
Member#: 120273
SWIC
Also, is he using the $900 BC's or one of their more expensive sets? Again, I'm not looking to start fights here, just a discussion. |
#16 |
Member#: 14732
SWIC
http://forums.nasioc.com/forums/show...6&postcount=73
Quote from the link, that someone from BC said, also in that thread Phil also posts "The coilovers that Element Tuning and Topspeed use are the SAME EXACT coilovers that customers can buy and have bought. I know. I provided them personally. Call them up. Ask them yourself. They asked for slightly different spring rates, that's it. Valving is OTS. We provide that same service to our customers, as we always have since the beginning." |
#17 | |
Member#: 14732
SWIC
#18 | |
Member#: 120273
SWIC
Because "Phil from Element Tuning uses them" is not justification on whether or not they are a good coilover for the OP. Phil is also using them on a time attack car right? That's a far cry from what is needed on a street car. Just saying. ![]() |
#19 |
Member#: 14732
SWIC
I am making the point, because people come in and say BCs suck (in other words) and i am saying if they do suck, i don't think one of the fastest guys in a subaru would be using them.
My wagon doesn't ride harsh at all, very smooth and is a DD with BCs on it, so is i put RCE zeros on it, my car will ride smoother and handle better as a DD for only $900-1000 more???? thats pretty much what everyone is saying so i just want to make sure i am getting it right |
#20 | |
Member#: 98838
SWIC
#21 |
Member#: 66959
SCIC
Vehicle:VF Engineer'd e46 M3 & vip'd 2GS GS300 |
Money for Phil probably isnt an issue by the looks of how well put together his car looks. He could've bought Ohlins instead of those CF doors he's got.
#22 |
Member#: 120273
SWIC
My main contention with the BC's (and most coilovers in that range) is the lack of bump travel and droop. Both of these are qualities I value a lot in a strut/sprint or coilover setup. This is why I'm taking a different approach. Not everyone agrees though and that's cool.
#23 |
Member#: 14732
SWIC
#24 | |
Member#: 14732
SWIC
I think that a nice sturt/spring combo is nice for the street, but i don't think my BCs are bad for the steet, My car isn't riding coilovers so i can "slam" it like alot of people, I don't feel anything is wrong with my coilovers, as they aren't Harsh on the steet like most people who has never had them will say. and to even say the road out here aren't good for these coilovers are crazy, living in NJ with pothole and some VERY bad roads, i still didn't think they were harsh like people make them out to be. |
#25 | |
Member#: 98838
SWIC
| Thread Tools | |
| Display Modes | |
| Stance coilover setup ? need help ASAP! | racer555 | Brakes, Steering & Suspension | 0 | 12-20-2008 01:22 PM |
| 05 STI need Budget Coilover setup, any suggestion? | Liam | Brakes, Steering & Suspension | 7 | 08-29-2007 12:26 PM |
| i Need Help For Coilover Setup | wanna ride in a sti | Newbies & FAQs | 5 | 02-05-2002 07:48 PM |
| Anyone have the TAS/Bilstein coilover setup (or know about it)? | rB5 | Brakes, Steering & Suspension | 2 | 07-10-2001 01:37 AM |
| Anybody know anything about the Tein RA Coilover setup? | SilverSuby | Brakes, Steering & Suspension | 2 | 05-24-2001 07:18 AM |
