Old 03-02-2010, 05:39 AM   #1
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Default Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP
Build thread: http://forums.nasioc.com/forums/show....php?t=1936152
Basically a home built block with 2.5L off the shelf parts and a Dom Tune.
Event: Dyno Tune
Ambient Temp: 51F 68% Humidity
Elevation: 200ft
Weather: Seattle Weather
Car: 2007 STi
Tuner: Dominic Acia of Maxwell Power Services (DomTune)
Dyno Info: DynoCom
Peak HP at RPM: 574 WHP @ 6300 RPM SAE Corrected / 596 WHP Uncorrected
Peak Torque at RPM: 502 WTQ @ 5750 RPM SAE Corrected / 522 WTQ Uncorrected
Baseline hp/tq for a stock on same dyno: 245 WHP
Target Boost: 29psi
Target AFR: 11
Fuel: 94 octane + 70/30 meth
Method: Vi-Pec V88
Engine/Power Modifications:
EJ257
CP Pistons 99.75mm w/ Ceramic Crown and Molybdenum Disulfide Skirt Coating
Carrillo Forged H-Beam Rods
Engine Fully Balanced
Stock STI Crank – Lightened a little bit
Calico Coated ACL Race Bearings
OEM Head Gaskets
ARP Head studs
11mm Oil Pump w/2 shims
B25 Heads
Kelford 276/272 AVCS Cams
5-Angle Intake Valve Job
3-Angle & Radiused Exhaust Valve Job
Supertech +1mm IN/EX Valves
Valves Lapped
Supertech Dual Valve Springs
Titanium Retainers
Other stuff:
Gates Racing Timing Belt
TGV Port and Delete
Ported Intake Manifold
BW S300sx 83-75 0.91AR
Custom TS-T4 header/up-pipe
Dual Tial 38mm MV-S WG’s
Mocal 25 Row Oil Cooler
Mocal Sandwich Adapter w/ Thermostat
MAC 3 Port Boost Solenoid
AEM/Zeitronix 3.5Bar MAP Sensor
APS DR725 FMIC with Custom Upper Pipes
GrimmSpeed 8mm Phenolic Spacers
Walbro 255LPH Fuel Pump Intank
Bosch 044 External Fuel Pump
Canton Racing 8 micron Fuel Filter
Covert Performance Fuel Surge tank
-8AN Feed and -6AN Return Fuel Lines
Injector Dynamics Bosch 1000cc Injectors
Aeromotive Top Feed Fuel Rails
Aeromotive A1000-6 FPR
Aquamist HFS-5 Meth Injection System 2x 1.0mm nozzles
Spec C STI 12L Intercooler Spray Tank
Vi-Pec V88 Standalone ECU
alcoolaid is offline   Reply With Quote
Old 03-02-2010, 08:30 AM   #2
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
that turbo sounds sweet...you have a very nice setup
Cbgrandtheftauto is offline   Reply With Quote
Old 03-02-2010, 09:11 AM   #3
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
Very nice Borg Warners do sound sick.... Looks solid!
TDagen is offline   Reply With Quote
Old 03-02-2010, 09:17 AM   #4
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Congratulations on the new-found power. Sounds evil!
Now for some videos on it in action
jigga is offline   Reply With Quote
Old 03-02-2010, 09:33 AM   #5
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
How was tuning the vi pec? The 83-75 really holds the power well!
Old 03-02-2010, 10:10 AM   #6
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Did you balance the rotating assembly yourself?
Old 03-02-2010, 10:46 AM   #7
CatfaceType-R
Member#: 81102
that headwork sure did a decent amount eh? area under the curve is siiick!
CatfaceType-R is offline   Reply With Quote
Old 03-02-2010, 11:51 AM   #8
berdugo
Member#: 163108
07 EuroDM STi 2.5L
very nice power
berdugo is offline   Reply With Quote
Old 03-02-2010, 04:28 PM   #9
moosecakes
Member#: 136098
07 35r WRX
Maxwell Power
Some very nasty stuff coming out of that shop lately.
moosecakes is offline   Reply With Quote
Old 03-02-2010, 04:41 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Lookin good Dom. Did you try to add a bit of fuel in the 4-5k RPM range to see if you could bring in a bit more boost there? Looks like if boost levels came up a bit in that range, you could shift the torque peak down bellow 5k RPM. That would be a very nice power band!
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-02-2010, 04:41 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
-- Ed
Old 03-02-2010, 05:13 PM   #12
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
I agree sickess year ever from what I have seen in the PPB section
Old 03-02-2010, 05:19 PM   #13
alcoolaid
Member#: 134949
'07 SWP STi
I'm sure I'll have some for you in a bit
Getting it set up initially took quite some time. Once it was all setup things went quite smoothly actually.
Local machine shop balanced it for me then I assembled it all.
No kidding. I gained a crazy amount of power over the last setup with less boost. Holds it all the way to redline too.
I have to agree!
Old 03-07-2010, 12:07 AM   #14
Maxwell Power
Member#: 190729
-- Ed
Arthur spends a lot of time on the track. I put a little extra fuel in around peak boost just to help ward off knock when the heat soak sets in and to help keep egt's under control. With as much power as that car was making, the few hp sacrificed was well worth the added safety margin.
That turbo setup is amazing, btw.
Maxwell Power is offline   Reply With Quote
Old 03-07-2010, 12:11 AM   #15
Maxwell Power
Member#: 190729
after spending more time with it, overall I like the ViPec. There are a handful of things that drive me crazy like not being able to change the units to PSI and the DBW calibration procedure. However, they claim that they are fixing most of it in the next revision.... hope so. This is a VERY powerful unit with a lot of customization and user definable options.
Right now the AEM and ViPec are my two favorite systems for the Subaru that are mostly "plug and play" for DBW.
Old 03-07-2010, 12:35 AM   #16
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
Cool , Yeah I have DBC so not worried about that, reading psi in bar would get annoying though lol! I am going to be tuning my Borg warner 91-79 twin scroll (40r) on the grp n rom and see what I can do.... If I run into problems (resolution ect) I will probably go AEM it sounds like... Did you like the way these borg warners scream when they boost dom?
Old 03-07-2010, 01:50 AM   #17
alcoolaid
Member#: 134949
'07 SWP STi
Old 03-07-2010, 02:30 PM   #18
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
can you post here dyno with stock heads and build heads? how much was gained?
Bariga is offline   Reply With Quote
Old 03-07-2010, 02:37 PM   #19
im2ninja4u
Member#: 183389
The turbo sounds so sick lol!
im2ninja4u is offline   Reply With Quote
Old 03-07-2010, 05:19 PM   #20
erikos
Member#: 148432
2006 TR VF39, alky
ID1000's
I think I just figured out what I want...... Awesome looking graph...
erikos is offline   Reply With Quote
Old 03-07-2010, 06:04 PM   #21
juanmedina
Member#: 133146
TS FTW
Dom should overlay your car VS this single scroll 2.6L just for fun
http://forums.nasioc.com/forums/show....php?t=1946247
Old 03-07-2010, 06:07 PM   #22
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Originally Posted by juanmedina View Post
TS FTW
I am waiting to receive the same TS kit he has, but I will be running a TS HTA-GT35106R. That map needs to be overlay-ed
leonbmx is offline   Reply With Quote
Old 03-07-2010, 06:11 PM   #23
juanmedina
Member#: 133146
who makes the TS header? by looking at your graph and this car's graph; TS makes a huge difference.
Can't wait!
Old 03-07-2010, 06:11 PM   #24
leonbmx
Member#: 82864
Covert Performance
Old 03-07-2010, 06:18 PM   #25
alcoolaid
Member#: 134949
'07 SWP STi
TS FTW
That's some nice peak power. Only if it held out better
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
Maxwell Power Tuned, 2.6L Crawford HTA-GT3582R, 587 AWHP leonbmx Proven Power Bragging 75 08-27-2015 03:59 PM
Dyno'd: Garage Tuning tuned 2.5L vf-39 91+Meth - 348awhp/419awtq @21psi STidub Proven Power Bragging 20 01-04-2010 07:49 PM
Cobb Tuning 2.5L NA Build - Dyno Results [LONG] Trey Normally Aspirated Powertrain 99 04-03-2007 03:06 PM
harmon tuned 2.5L vf22 bugeye spooln407 Proven Power Bragging 31 01-22-2007 11:56 PM
