Old 03-02-2010, 12:22 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default Rough idle - cold start up
Yes, I did search, but couldn't find anything useful. Here is a list of things I have done, but did not help.
1. IACV - disassembled completely and thoroughly cleaned
2. MAF sensor - cleaned
3. Checked vacuum lines and hoses
Other than checking for plugs, coil packs (will check tonight), what else are there to check? This is very strange as rough idle is confined to cold start up. Once warmed up, car drives perfectly normal.
Any other suggestion?
Old 03-02-2010, 12:52 PM   #2
NoHandsNurse
Member#: 200960
2005 WRX
SR Red
I have a similar problem and responded in the same ways you did. On some of these rough idles after first starting my car I notice that the ecu retards timing till after the idle smoothes out. It is not a common occurance but it has happened more than once. I think the idle could possibly be related to timing tensioner or belt as I have read of some rough start/idle issues related to a tensioner going out. Probably going to take of the cover and check for play in the tensioner/belt to see if it could be the culprit.
NoHandsNurse is offline   Reply With Quote
Old 03-02-2010, 01:31 PM   #3
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I recently had timing belt work done where everything including pulleys and tensioner got replaced. Plugs were recently replaced as well prior to getting a tune a month ago.
Old 03-02-2010, 04:15 PM   #4
Haelan
Member#: 151045
2013 Subaru STI
CBP
Pressure test the air intake and rule out any leaks. Visual inspection is great if the leak is obvious, but more commonly the leak is hidden out of view.
Haelan is offline   Reply With Quote
Old 03-02-2010, 05:02 PM   #5
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Leak check was OK when I got my car tuned unless new leak developed in the last 3-4 weeks. Since problem is seen only when car is COLD (start up), I highly doubt there is leak in the air intake. At any rate, I will double check again.
Old 03-02-2010, 06:23 PM   #6
ocelot21
Member#: 188550
2004 WRX
WRB vf22'd
i had a tgv motor go out on me. It caused the car to act like it had tgv deletes, and had a really odd idle. I don't know if this is similar to what youre experiencing, but its something to think about.
Grimmspeed sells em for dirt cheap.
ocelot21 is offline   Reply With Quote
Old 03-03-2010, 04:03 PM   #7
ride4life00
Member#: 240090
i had a similar issue where as my 05 wrx wagon would idle rough either on a cold start, or seldom @ a red light, i had recently replaced the belts, flushed my power steering line/res (just because it was time & the smoother it runs the less it pulls from your engine), re-adjusted belts, checked timing, & haven't had a problem since....
Good luck
ride4life00 is offline   Reply With Quote
Old 03-03-2010, 04:41 PM   #8
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Your valves may need to be adjusted. The lash that is. I saw you have a 02 WRX, tuned with a VF34. I'd suspect the valve lash.
PSolbergfan is offline   Reply With Quote
Old 03-03-2010, 07:51 PM   #9
Tut4u2
Member#: 40424
05 STi
Fatten up the fuel trim at cold start and see if that fixes it. What are your trims like?
Tut4u2 is offline   Reply With Quote
Old 03-03-2010, 08:04 PM   #10
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
If you post a log of the rough idle we might be able to help better
Andy
elevenpoint7five is offline   Reply With Quote
Old 03-03-2010, 11:09 PM   #11
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Here is an update.
Cleaned the MAF sensor again using MAF cleaner (2nd time). This time, I spent more time and soaked the sensor in the cleaner for 20 min.
Problem fixed....
engine idle rough on cold start tank32184 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-04-2010 09:44 PM
engine light on and bad idle at start up wrx2sti1114 Texas Impreza Club Forum -- TXIC 33 10-01-2008 10:08 PM
Idling vs. Start-up wear and tear... shemoves Service & Maintenance 5 05-24-2007 11:28 PM
engine has high idle on start up Call_me_Tom Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-28-2005 05:55 PM
weird idle when starting up....Please HELP... Michael Normally Aspirated Powertrain 7 02-16-2001 10:10 AM
