Old 03-02-2010, 04:54 PM   #1
Studmike02
Member#: 220095
'95 MX-5
Default DRL High Beams
Yeah I know theres other forums similar to this but this one is about independent high beams, I am wondering if it got the same idea of the independent fogs where you just pull the relay out and bend one of the leg and add it to the add-a-circuit.
I am wondering if one of those relay in the fuse box area is for the high beams and would it have a similar idea of doing it.
Studmike02 is offline   Reply With Quote
Old 03-02-2010, 05:28 PM   #2
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
I converted my highbeams to work as the DRL's.
This conversion is for non-HID headlamp systems. I will look into what would need to be done if you want to convert an STI w/OEM HID's so that the same can be done (using the high-beams as DRL's).
It's a matter of swapping two wires from the highbeam relay with two wires from the lowbeam relay. Both relays are located behind the lower right-hand side of the glovebox. One relay is colored black and the other is colored blue.
You want to swap the following terminals:
#1 of the HB relay with #1 of the LB relay
#4 of the HB relay with #5 of the LB relay
I also installed a 2008 DRL resistor to drop the output to 50% instead of 85% so I don't blind oncoming drivers. This is your choice.
NOTE: You may not have to cut any wires to perform this modification. I say 'may' because two of the wires may or may not reach the other relay when performing this swap.
If you do not want to cut any wire, you can make a pair of extensions. You would need two male-blade terminals that you can get from say Radio Shack, two lengths of 16-gauge wire about 2" long and the other two terminals you can source from Hella. Why? The ones that are fitted into the connector have special locking tabs on them.
The part-number for the Hella terminal (same for either) is: HL87272 (6.3mm (1/4") Receptacle) and you can get them from Susquehanna Motorsports: http://www.rallylights.com/detail.aspx?ID=436
High-beam relay:
X 1 X
2 X 3
X 4 X
1 = Red
4 = Red w/green stripe
Low-beam relay:
X 1 X
2 3 4
X 5 X
1 = Yellow w/red stripe
5 = Black
I checked and the above is true for 2004 and 2006. Presumptively, the same is true for 2002, 2003, 2005, and 2007.
**Do at your own risk and have fun**
Old 03-02-2010, 06:12 PM   #3
Studmike02
Member#: 220095
'95 MX-5
Well I would like to be able to control if I want the Highbeams to be on, I would like to create a switch or something next to the fog switch and then be able to make the highbeams go on itself by pressing the switch.
Old 03-03-2010, 11:34 AM   #4
Studmike02
Member#: 220095
'95 MX-5
Bump, dying to do the mod today.
Old 03-06-2010, 08:41 PM   #5
blame
Member#: 226359
2006 WRX
obp
Do at your own risk and have fun.
just to let everyone know, i did this today and it worked beautifully. a couple tips, since there are two yellow/red wires going to the black low beam relay, and the relay itself isn't labeled with numbers, the #1 yellow/red wire that you want to switch into the high beam relay is the top one, not the centre one. also getting a 2008 drl resistor is highly recommended, i haven't gotten mine yet, but those drl's are bright when they're pumping out 85%. i'll be driving with my hid low beams on until monday when i can pick up the new resistor to save fellow motorists some blindness.
other than that, everything works like stock, except the drl's come out of the high beam bulbs instead of low beam projectors.
lights off, e-brake up = no lights
lights off, e-brake down = drl's
lights 1 click = drl's, corner lights, tail lights (and fogs via switch, i did the foglight mod)
lights 2 clicks = low beams, no drl's, corner lights, tail lights (fogs via switch)
and high beams work fine both pulling the stick to flash and pushing for constant.
thanks big E for figuring this out, saved me a whole bunch of time with wiring diagrams, i really hate trying to figure out wiring.
can't wait to get my 50% resistor
-sean
blame is offline   Reply With Quote
Old 03-08-2010, 02:59 AM   #6
I <3 PiNkY
Member#: 211924
2004 wrx
wr blue
would this work on a 04 wrx??? i really hope it would
I <3 PiNkY is offline   Reply With Quote
Old 03-08-2010, 02:14 PM   #7
I <3 PiNkY
Member#: 211924
2004 wrx
wr blue
^^^ bump for my question
Old 03-08-2010, 04:51 PM   #8
Big-E
Member#: 123843
2016 STI LTD CWP
Blame, you are welcome. FYI: fill-out your profile so if you need help in the future we'll know what you drive and so-on.
With respect to the 2008+ DRL resistor I recommend the following:
The original resistor can be removed from the mounting bracket. Remove the bracket with the resistor attached and service the assembly out of the car - this will make working on it much, much easier. The new resistor can be mounted to the existing bracket but, you will need to modify it so the new one will fit.
The new resistor is slightly physically bigger so it will be closer to vacuum hoses and wires. Get hi-temperature wire-loom and cover any hoses and wires, essentially shielding it from the heat that is given off while its in use. Also tie back any hoses and wires using zip-ties.
I have not yet taken any pictures of the car, but expect to do so soon.
Happy Motoring!
Old 03-08-2010, 04:56 PM   #9
I <3 PiNkY
Member#: 211924
2004 wrx
wr blue
^^^ but i was wondering about if the headlight relays where in the same spot on a 04 wrx and if one of the relays were still blue in color and if the wires that i have to interchange where in the same location
Old 03-10-2010, 11:43 PM   #10
I <3 PiNkY
Member#: 211924
2004 wrx
wr blue
Question
quick question is the #5 wire on the LB relay colored black ??? and is it a ground wire ??? please some one respond
Old 03-12-2010, 11:27 PM   #11
I <3 PiNkY
Member#: 211924
2004 wrx
wr blue
^^^ bump for question any one please !!!
Old 03-14-2010, 08:48 PM   #12
blame
Member#: 226359
2006 WRX
obp
as far as the wiring on my 06, yes the #5 wire in the low beam relay is a black ground wire, it is intersected by the ground from the drl resistor according to my wiring diagrams
-sean
Old 04-21-2010, 06:40 PM   #13
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
subscribed. Just did a TSX retro, and dont like the idea of no drls. I pulled the connector, and like this solution better. Anyone have a part number on the 2008 resistor?
I am going to look for some pics of these two relays to make sure I know what I am doing. Big-E, can you post pics of the relays?
phoenix_wrx is offline   Reply With Quote
Old 04-22-2010, 03:02 PM   #14
Big-E
Member#: 123843
2016 STI LTD CWP
I'll see what I can do this weekend.
Old 04-23-2010, 06:17 PM   #15
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
thx- i think I found them, but I am curious how you actually accomplished the wire swap - did you pull the wires out of the connectors? or just cut and solder? The part number on the resistor would be wicked too.
I will PM you one internetz. thx
Old 04-25-2010, 10:34 AM   #16
Big-E
Member#: 123843
2016 STI LTD CWP
Sorry, no pics yet - I've been very busy. I hope to take some this week.
OEM DRL resistor @ 50% output (under hood): 84057FG000
With the turbo models, you will have to get wireloom both in 1/2" and 1" or thereabouts to effectively cover the turbo boost controller hoses and wires. These items are effectively located over the DRL resistor and it puts out a lot of heat. By covering things with the wireloom, you can add protection to these items from the heat.
You will also have to remove the OEM DRL resistor while it's attached to the mounting bracket. You will have to modify the bracket and/or the new bracket for the new resistor to have it attach to the original mounting bracket.
No cutting or soldering. I used crimp connectors, some wire and electrical tape.
From the LH relay, you can release the two wire terminals from the connector and plug them into the RH connector.
You cannot plug the two wire terminals from the RH relay into the LH connector because they are too short. A solution is to make two 'extensions'.
For the extensions, you will need two 3" lengths of 16-18GA wire. For the ends that will plug into the existing wire terminals, you can use shielded crimp-on connectors from Radio Shack. For the terminals that will plug into the connector, you will need to get Hella crimp-on self-locking terminals PN: HL87272
You will also need electrical tape and I recommend 3m brand of electrical tape that Radio Shack also sells. It has the best hold and has a wide temperature range for useage, meaning it can get real cold outside and it won't shrink and the glue won't fail, for example.
Old 04-25-2010, 03:58 PM   #17
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
wow. Thanks. That should be enough to go by. I am surprised that that resistor is going to run almost 75 bucks. I wonder if there is something else that might work?
Old 04-25-2010, 10:56 PM   #18
Big-E
Member#: 123843
2016 STI LTD CWP
Chaplin's Subaru Genuine Parts sells it for just under $50. https://www.chaplinssubarugenuinepar...parts_cat.html
Put the PN into their "search by part number or keyword" and you'll see both the list price and the over-the-counter price.
Old 04-27-2010, 02:35 AM   #19
soju1
Member#: 139529
will this work on a 07 also?
Also are there any photos available yet?
Thanks
soju1 is offline   Reply With Quote
Old 04-27-2010, 05:12 PM   #20
Big-E
Member#: 123843
2016 STI LTD CWP
Thanks
By rights it should.
No photos yet. I've been busy.
Old 04-27-2010, 09:35 PM   #21
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
Thanks, thats the only place I get OEM parts. My point was that I have to pay extra shipping and duties to get them to Canada, but I guess I didnt type that. I am going to try it without first, and see how bad it is.
Old 05-05-2010, 09:29 PM   #22
soju1
Member#: 139529
anyone have pictures yet? or better yet does it work on the 07 wrx?
Old 05-07-2010, 06:48 PM   #23
phoenix_wrx
Member#: 98532
na B-Wing
rebel red
I havnt bothered to try yet. I wired my fog lights so that I can turn them on whenever there is IGN power, so I have been using them as DRLs. I am torn on whether to just keep it like this and sell my fog covers, or go the high DRL route.
Old 05-13-2010, 10:00 PM   #24
soju1
Member#: 139529
Is it relay B103 and relay B102?
Old 05-13-2010, 10:24 PM   #25
Big-E
Member#: 123843
2016 STI LTD CWP
Yes, this is correct.
Switching DRL from low beam to high beam bulb ringe Electrical & Lighting 2 09-11-2007 03:57 PM
half-power high-beam as DRL? Naito Electrical & Lighting 4 07-06-2007 02:32 PM
HIgh beams are ok but one of the DRLs is not working? CyberVlad Electrical & Lighting 1 02-25-2006 02:48 PM
DRL, High Beam & Morette problem Impreza2003 Electrical & Lighting 2 03-18-2005 12:18 AM
how to re-wire DRL to power high beam instead? MrZone Electrical & Lighting 11 05-15-2004 03:47 PM
