Old 05-17-2010, 01:41 AM   #26
soju1
Member#: 139529
Default done!
wow it was easy. i ordered the 08 resistor last week and got it on wednesday. i removed the 07 resistor. installed the 08 resistor. It wasnt that much bigger where i thought i had to protect wires and stuff so i left it as it is. got a wiring diagram that i found on here to make sure i was pulling the correct wires.
installed according what was on this thread. Tested it out and BAM! it worked. Its freaking awesome. now im gonna go look for some yellow high beam bulbs to use.
Also, did you guys that did this notice that the high beam indicator light is on in the instrument cluster? I hope this is normal. I kind of like it because it tells me that they are on. Then when i switch the light switches it turns off.
anyways, i should have taken pictures but it was really easy, just grab wiring diagram. behind the glove box its the blue (HB) and black (LB) relays.
thanks for your help Big-E
soju1 is offline   Reply With Quote
Old 05-17-2010, 10:05 AM   #27
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
You're welcome!
The HB indicator being dimly illuminated is normal (and yes is a good way to tell you the DRL's are working).
Old 06-11-2010, 08:58 AM   #28
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
anyone have any pics of the finished product and/or of the relays that have to be changed.
CC4nj is offline   Reply With Quote
Old 08-21-2010, 11:38 PM   #29
bzbuzz
Member#: 116052
2011 STI ( Sold )
very interesting mod.. i saw old SWRT cars have highbeam on...
bump for pictures..=)
bzbuzz is offline   Reply With Quote
Old 08-26-2010, 08:13 PM   #30
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Default Now showing: pictures of the lamps in use
You wanted pics!
EDIT: the hood is popped open in every picture and not the result of damage/misalignment.
Old 08-26-2010, 10:12 PM   #31
bzbuzz
Member#: 116052
2011 STI ( Sold )
nice looking car!!!
what's the highbeam bumb?
did you happend to measure the resistor?
thanks for sharing!!
Old 08-27-2010, 08:13 AM   #32
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Originally Posted by bzbuzz View Post
nice looking car!!!
Thank you!
Hella 9005 Optilux Extreme XY Yellow Bulb
Not yet.
Anytime.
Old 09-21-2010, 07:21 PM   #33
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Default 2008+ DRL Resistor Specs
The 2008 resistor is:
70w; 1.13 Ohms
It is approximately 4" tall, 2.5" wide, and 1" thick.
Old 11-04-2010, 04:18 PM   #34
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Last weekend I did a little "tweaking" to the DRL's.
I have added a switched ground wire so that now if I turn on the parking lights, the DRL's shut-off.
So my set up is now:
No lights = DRL highbeams
Parking lights and/or headlights = no DRL's.
I have amber high-output bulbs as City Lights and I liked the way the light filled the headlamp capsule. With the DRL's on with the parking lights on, you could no longer see this.
I was provided the answer back in February 2007 from a post I long forgot about: http://www.scoobymods.com/drls-off-p...53.html?t=2353
Old 01-22-2011, 09:30 AM   #35
waynlewis
Member#: 219948
07 Sti
Hey Big-E, what tow hooks are those and how are they installed? Thanks
waynlewis is offline   Reply With Quote
Old 01-22-2011, 02:29 PM   #36
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
The front tow hooks are a part of the Oswald Peformance lightweight bumper beam that I installed. Mickey typically sets up his bumper beam to include one hook on the passenger's side. I opted to have a second mounting plate installed to have of course a second hook.
http://oswaldperformance.com/IMPREZA...UMPERBEAM.aspx
The tow hooks are from a vendor he uses, Rennen Metal: http://www.rennenmetal.com/products.asp?cat=1
Also, if you are interested, Rennen metal makes a GD/GG specific rear tow hook. Very nice and very easy to install: http://www.rennenmetal.com/proddetail.asp?prod=1347
Old 01-23-2011, 11:27 AM   #37
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
To 'fix' having the high-beam indicator glowing while the DRL's are in operation, replace the bulb with an LED bulb. You'll want a miniature wedge-style bulb #74: http://www.superbrightleds.com/cgi-b...%2F74-xHP.html
Old 01-23-2011, 01:38 PM   #38
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I also give you a good thumbs up on the car Big-E. Nice job.
Cougar4 is online now   Reply With Quote
Old 01-23-2011, 07:50 PM   #39
Studmike02
Member#: 220095
'95 MX-5
Big-E, is your fogs and high beams on at the same time? or is it just the flash?
Studmike02 is offline   Reply With Quote
Old 01-24-2011, 04:40 PM   #40
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
That's just the flash from the camera.
Old 01-24-2011, 04:48 PM   #41
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
I thank you very kindly.
Old 01-29-2011, 12:24 PM   #42
moWagon
Member#: 268625
2006 Impreza Wagon
SGM
Hey Big-E, have you caught any heat from having yellows in your headlamps and not clears? I'm interested in doing this but not sure about drawing any unwanted attention.
moWagon is offline   Reply With Quote
Old 02-10-2011, 11:35 AM   #43
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
No, I have not.
One is that I don't go driving around with the high-beams on and the other is that DRL high-beams look yellow/orange anyway.
Old 02-11-2011, 12:28 PM   #44
Clin10
Member#: 150666
2007 2.5i SE 4EAT
I did this mod yesterday and picking up my 08+ resistor today! Pics when I get it done and log on at home. Best ever mod, very unique for our cars! I was going to do it last year but forgot. This day can't go any slower!
Clin10 is offline   Reply With Quote
Old 02-11-2011, 01:24 PM   #45
Big-E
Member#: 123843
2006 WRX Sedan SGM
2016 STI LTD CWP
Definitely post up some pics!
If you install the resistor using the original bracket and then back onto the strut-tower, I suggest that you get some various sized wire-loom that is rated for higher temperature areas and effectively cover the wires and vacuum hoses in that area. That resistor does get very hot when in use and so you don't want to cook anything, if you know what I mean.
Old 02-11-2011, 05:01 PM   #46
Clin10
Member#: 150666
2007 2.5i SE 4EAT
yeah, well I got a 2.5i, so there is onlyt the airbox in that area. I put it on at the dealer and drove home with it. it looks so up-to-date now! I love it. this is my initial first pic. I'll wait until dawn to take a more showing shot like yours is:
Old 02-11-2011, 05:53 PM   #47
Clin10
Member#: 150666
2007 2.5i SE 4EAT
some night time cellphone shots:
DRL with parking lights on:
5000k Low Beams [not fully warmed up]
DRLs on back of a car:
lowbeams:
Old 02-12-2011, 03:48 PM   #48
Clin10
Member#: 150666
2007 2.5i SE 4EAT
daytime shot with a real camera:
Old 06-15-2011, 07:42 PM   #49
waynlewis
Member#: 219948
07 Sti
Ok, quick question, where is the 08 drl resistor located? And where is the 07 resistor that needs to be replaced? I know where the relays are and the drl module, both behind the glove box. I don't want to disable my drl but rather this mod.
Thanks
Old 07-31-2011, 12:20 PM   #50
waynlewis
Member#: 219948
07 Sti
Bump for an answer. Where is the resistor located on an 07?? I know where it is on an pre-07 and 08+. I checked both wheel wells and the engine bay and behind the glove box but no luck, or maybe I just missed it. Also, what color wires do I need to swap on an 07? I checked for the colors listed here, but those colors don't apply on an 07. Thanks for the help.
Switching DRL from low beam to high beam bulb ringe Electrical & Lighting 2 09-11-2007 03:57 PM
half-power high-beam as DRL? Naito Electrical & Lighting 4 07-06-2007 02:32 PM
HIgh beams are ok but one of the DRLs is not working? CyberVlad Electrical & Lighting 1 02-25-2006 02:48 PM
DRL, High Beam & Morette problem Impreza2003 Electrical & Lighting 2 03-18-2005 12:18 AM
how to re-wire DRL to power high beam instead? MrZone Electrical & Lighting 11 05-15-2004 03:47 PM
