Old 05-29-2002, 06:28 PM   #1
pehavens
Member#: 11821
Question question on stock WRX turbo guage
Can someone give me an explanation ...
I have the optional turbo guage installed by the dealer and I am not sure how to read it. Often I have seen posts describing the boost level in number between 12 to 16 or more (I am assuming this is PSI). The guage I have ranges from -.1 to .15. The highest I have seen it is about .9. Everything else is stock on my WRX. Can someone tell me how to convert this? And why is it negative at times?
Another question I have. I am not sure why the turbo only spools up for a second when the throttle is pressed and the transmission is not engaged. Does this mean that the turbo fan only spins if the car is in gear. What exactly is being messured by the guage? Is it the pressue inside the cylinder?
If you know of a good place me to learn about all this I would greatly appreciate it. Thanks.
-Pete
pehavens is offline   Reply With Quote
Old 05-29-2002, 06:52 PM   #2
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Do a search before you post
MPa Bar psi
0.01 0.1 1.45
0.02 0.2 2.9
0.03 0.3 4.35
0.04 0.4 5.8
0.05 0.5 7.25
0.06 0.6 8.7
0.07 0.7 10.15
0.08 0.8 11.6
0.09 0.9 13.05
0.10 1.0 14.5
0.11 1.1 15.95
0.12 1.2 17.4
0.13 1.3 18.85
0.14 1.4 20.3
0.15 1.5 21.75
MAD REX is offline   Reply With Quote
Old 05-29-2002, 07:13 PM   #3
pehavens
Member#: 11821
Default thanks
Thanks for the numbers MAD REX. I did search several times but came up empty.
Anybody able to explain the spool up blip when out of gear or the negative numbers on the guage.
Thanks,
-Pete
Old 05-29-2002, 10:01 PM   #4
peczenij
Member#: 16791
2004 WRX STi
WRBlue
A boost gauge is actually a dual gauge.
The negative numbers are vacuum (suction) and the positive numbers are turbo boost (pressure).
A vacuum condition is caused by the throttle only being partially open, making the engine “suck” for air.
A normally aspirated engine (no turbo) will go from negative to zero vacuum at wide open throttle.
A turbo actually pressurizes the incoming air creating boost.
Most cars use the vacuum provided from the engine to provide power to accessories such as power brakes.
Enjoy…
.080=11.6 PSI
.085=12.3
.090=13.1
.095=13.8
.100=14.5
.105=15.2
.110=16.0
.115=16.7
.120=17.4
.125=18.1
.130=18.9
.135=19.6
.140=20.3
.145=21.0
.150=21.8
peczenij is offline   Reply With Quote
question on driving WRX/ turbo cars Cata Vancouver Impreza Club Forum -- VIC 13 01-02-2005 04:26 AM
Max WHP on stock WRX turbo wRxbeater11 Proven Power Bragging 35 02-28-2004 01:48 AM
Max Boost & HP on Stock WRX Turbo noob Newbies & FAQs 4 12-21-2002 06:19 PM
Fastest Spool-Up on Stock WRX Turbo? WRacerX Factory 2.0L Turbo Powertrain 33 07-05-2002 06:38 PM
Question for those running stock WRX turbos on RS's STiTuner Normally Aspirated with bolt-on Forced Induction Powertrain 13 04-26-2002 08:43 PM
Message Board Statistics All times are GMT -4. The time now is 08:51 AM.
