Notices
Old 05-29-2002, 07:16 PM   #1
jhoffmann
Member#: 1407
2000 2.5 RS-T
BRP
Question Cooler Temp Spark Plug for 2000 RST
I did a search and didn't find anything concrete for the 2000 RST. I am waiting the arrival of my FAT Stage II turbo kit and was wondering if it is necessary/recommended to run cooler plugs. If so could any of you RST guys out there that have a 2000 let me know what you are using. Thanks,
Jim
jhoffmann is offline   Reply With Quote
Old 05-29-2002, 07:33 PM   #2
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
NGK Spark Plugs -- BKR7EVX-11
They are 1 heat range cooler and are the plugs that Shiv recommends.
kastle is offline   Reply With Quote
Old 05-29-2002, 08:06 PM   #3
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
I'm running NGK BKR7E-11
I guess they're the same as the ones above
Impreza Rider is offline   Reply With Quote
Old 05-29-2002, 08:43 PM   #4
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Stock plugs here. They seem to work fine for me, though I am sure colder plugs would work BETTER. Quite a bit of backfiring though.
Graham
Graham is offline   Reply With Quote
Old 05-29-2002, 10:15 PM   #5
jhoffmann
Member#: 1407
2000 2.5 RS-T
BRP
Thumbs up
Guys, Thanks for the information, I just want to make sure I have everything ready for when I get the kit, can't wait to be under boost!!!
Old 05-30-2002, 01:22 AM   #6
adamsrs
Member#: 3768
Im running Denso Iridium IK22 plugs. BUT i would rather get the NGKs because they last WAY longer and dont cost $12.50 each!
adamsrs
adamsrs is offline   Reply With Quote
Old 05-30-2002, 01:22 AM   #7
Hojai
Member#: 2190
i just changed to NGK BKR8E
Hojai is offline   Reply With Quote
Old 05-30-2002, 02:29 AM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Brk8e-11, these are 2 stages cooler, you'll need to regap them to around .036" to prevent the spark from "blowing out" under boost.
jeremy
Old 05-30-2002, 11:21 AM   #9
Hojai
Member#: 2190
HndaTch627:
Can you tell me how to do so? and is this necessary? and why is that?
Old 05-30-2002, 12:47 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Originally posted by Hojai
HndaTch627:
get a feller guage for gapping spark plugs from a parts store, bend the tip down and use the feeler guages to gap it to the proper setting.
yes it is necessary if you are running these plugs, at least to get the optimal spark out of them.
why?? becuase you combustion chamber pressures are so high that the stock iginiton can't make the spark jump the gap(remember it's firing 2 cylinders at a time).
jeremy
Old 05-30-2002, 03:59 PM   #11
Hojai
Member#: 2190
HndaTch627:
what is the original distance of the gap on NGK spark plugs?
so it doesn't matter what i've done to the car, the ignition can't be changed, right? like a stand alone computer or even MSD?
Old 05-31-2002, 01:55 AM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
HndaTch627:
i think on the 11's it's .044" or .046" no matter what you do you still run the risk of blowing out the spark.
jeremy
Old 05-31-2002, 09:06 AM   #13
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
Sure it can... a Tec-2/ Tec-3 uses a high output coil where you dont' have to worry about blowing out the spark. I'm gapped at 0.045 whether I run a heat range of 7 or 8 with no issues.
Fitz
Fitz is offline   Reply With Quote
Old 05-31-2002, 10:17 AM   #14
RallyNavvie
Member#: 7113
2008 Spec B
Just to let you know the BKR7E-11s are copper plugs. The Subaru guru that did my Haltech suggested not using plain platinum or iridium plugs on our engines. He said use copper or some special type of platinum plug. Has something to do with the wasted spark ignition system (on spark return I think).
May want to keep that in mind. I didn't really get a detailed explanation that I recall. Can someone elaborate?
~Garrett
RallyNavvie is offline   Reply With Quote
Old 05-31-2002, 01:12 PM   #15
Hojai
Member#: 2190
because i am using a Tec 2, does this mean i don't have to recap the gap to 0.036"?
by the way i think i am using iridium plugs, is that fine?
Cooler Spark Plugs for Track Use . . . How to Change ??? george3 Motorsports 6 02-07-2008 04:09 PM
WTB: Stage 2 clutch for 2000 RST UpTown I-TS Vancouver Impreza Club Forum -- VIC 1 12-05-2005 11:22 PM
Where to get NGK spark plugs for RST in SD cRayZee Southern California Impreza Club Forum -- SCIC 13 01-28-2004 02:23 PM
any instructions for changing spark plugs for a WRX? db97 Service & Maintenance 2 05-02-2003 02:29 PM
spark plug gap 2000 RS ?? munkis Normally Aspirated Powertrain 25 03-29-2002 01:10 PM
