Old 03-04-2010, 12:48 PM   #1
NorthVanWRXOwner2be
Member#: 220761
2015 WRX
Default Data Logging not working
APV2
Latest Firmware 1.3. something
Dongle rev is 6.0...BAsically not the one they say you CAN'T have with latest FW rev
Problem
Everything else seems to work ok....I can view live data for anything, it can tell me currently loaded map, etc......
As soon as I say OK to start Data Logging it goes into Communicating with ECU for roughly 2-3 seconds and then reverts back to the live data but says NOT LOGGING at the bottom.
Anyone ever experience this?
NorthVanWRXOwner2be is offline   Reply With Quote
Old 03-04-2010, 01:28 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Press button again to actually start the data logging...
wrxdrvr is offline   Reply With Quote
Old 03-04-2010, 01:48 PM   #3
NorthVanWRXOwner2be
Member#: 220761
2015 WRX
Press button again when? Once I'm in the monitoring area and it shows all the different items you can select to monitor live?
Old 03-04-2010, 02:17 PM   #4
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
When screen says not logging...or after picking what parameter you want the AP to show live...
Old 03-04-2010, 02:58 PM   #5
NorthVanWRXOwner2be
Member#: 220761
2015 WRX
OK...Will give it a shot...Thanks!
Old 03-22-2010, 04:32 PM   #6
bikepoet
Member#: 201878
2008 STI
With my AP-SUB-003 and 08 STI, I tried adding the AF learning ranges 1-4 to the logged parameters and the logging would not work with those added. I unselected them and logging worked as it did before.
Has your logging ever worked?
bikepoet is offline   Reply With Quote
Please Check My Data Log (New logs added) Xsile STI Engine Management & Tuning 6 04-30-2010 04:17 PM
Data logging gurus, need your help reading log. vortectoy AccessPort 5 05-22-2006 01:19 AM
air/fuel ratio ?s. Finally got data logging to work kaisersouse General Community 12 01-30-2006 12:36 PM
Data Logging for the track StormShadow Motorsports 6 04-16-2002 05:33 PM
rehash obd 2 / unichip data logging question Tex-WReX2 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-20-2001 10:22 AM
