Old 03-04-2010, 08:37 PM   #1
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Default ID2000's holding a rock solid 900RPM idle!
I thought you guys might be interested in this. I've been working on one of the cars here with some ID2000's and AEM EMS controlling them. For reference, this is an 04 STI with built engine and heads with BC cams. Currently its also running on straight 91 Octane. It took some work and a slightly different approach, but I managed to get a ridiculously stable idle out of these things. Check out the video:
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-04-2010, 08:42 PM   #2
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Nice Ed!! You have to love those ID's. My ID1000's literally idle like stock, just great products!
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 03-04-2010, 08:42 PM   #3
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Those are badass injectors. I wish I had a car that needed a set that size!
eastcoastbumps is offline   Reply With Quote
Old 03-04-2010, 09:20 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Just got back from doing some initial drivability tuning. These things flat out ROCK! Super smooth drivability, great transitions, and I still can't believe the idle. 2000cc injectors in a car with cams and a standalone idling like this is just insane. And this is still on 91 Octane which is calling for a pretty tiny injector on time at idle. Next we dump the 91 and put in some E85
-- Ed
Old 03-04-2010, 09:48 PM   #5
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
You beat me to it. I was going to post the same exact video. I havent gotten mine yet though.
Are you using 2000cc as the scalar? Others have reported having to use 900cc and 1800cc....
Do they come with flow sheets like the DW's?
Is this the ATP35 car?
Thanks
Ron
Old 03-04-2010, 09:54 PM   #6
SubieFiesta
Member#: 149426
2002 Subaru WRX
2005 Subaru STi & 2000 RS
I have been doing alot of reading up on these injectors. Do you need to run a resistor box with them?
SubieFiesta is offline   Reply With Quote
Old 03-04-2010, 09:56 PM   #7
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
I'm tuning this with an AEM, so there's no actual scalar like in the OEM ECU. From the scaling I had to do, I would say they definitely act like at least 2000cc injectors .
They do come with a data sheet including latencies which was very useful.
This is one of the ATP35r cars. We should also be firing up another one soon with the same injectors and our own twin-scroll rotated kit
-- Ed
Old 03-04-2010, 09:57 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
No resistor box. We just had to de-pin and re-pin the clips and they were good to go.
-- Ed
Old 03-04-2010, 09:58 PM   #9
SubieFiesta
Member#: 149426
2002 Subaru WRX
-- Ed
even with the stock ecu? no resistor box?
Old 03-04-2010, 10:00 PM   #10
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
no they are high impedence just like the stock injectors so they are just a drop in but upgraded rails are recommended
john 1badSTI is offline   Reply With Quote
Old 03-04-2010, 10:05 PM   #11
SubieFiesta
Member#: 149426
2002 Subaru WRX
thanks john
Old 03-04-2010, 10:28 PM   #12
modaddict
Member#: 95840
sold to a good bud
awaiting next car
wow those bc cams are sure getting popular
modaddict is offline   Reply With Quote
Old 03-05-2010, 12:25 AM   #13
WAYGONE1
Member#: 139073
Now lets see if these will idle the same on an OEM ecu.
WAYGONE1 is offline   Reply With Quote
Old 03-05-2010, 02:11 AM   #14
BUILTSTI
Member#: 204644
2005 STi 10.7 @ 125
FPRED PUMPGAS 93oct
Only 900? I got mine idling at 800...
Don't these injectors just rock?
Keep up the good work
BUILTSTI is offline   Reply With Quote
Old 03-05-2010, 11:30 AM   #15
nosmo
Member#: 53142
06' STI,02WRX,982.5
www.Flat4lv.com
What brand injectors are these?
nosmo is offline   Reply With Quote
Old 03-05-2010, 11:52 AM   #16
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Old 03-05-2010, 01:46 PM   #17
sean18337
Member#: 135588
2007 STI *SOLD*
On E85 I made 597whp and 566tq on these babies at 30psi and duty cycle was only 64% with a base fuel pressure of 42psi and twin bosch 044 fuel pumps
Car idles and drive sooo smoooth!!
http://forums.nasioc.com/forums/show....php?t=1945159
sean18337 is offline   Reply With Quote
Old 03-05-2010, 06:41 PM   #18
frontside50-50
Member#: 240306
quality gear right here
frontside50-50 is offline   Reply With Quote
Old 03-05-2010, 07:48 PM   #19
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
How about this... same car, but we just switched it over to E85. Now I managed to get it to hold a smooth, solid STOCK idle on 2200cc's!
Here's the video of just idle:
And here's idle and a free-rev to show the idle recovery:
Thanks
-- Ed
Old 03-14-2010, 10:22 AM   #20
jays05
Member#: 78165
05 STI 35r + e85
I got my car idling smoothly @ 900rpm with ID2000's and stock ECU + UTEC
Last night I went outside @ 1am and flashed some map changes. Forgot all about it until this morning when I went out for coffee and noticed the car was idling solidly @ 900rpm. The motor has a built bottom end, ported d25 heads, cosworth 278/274 cams, supertech +0.5mm valves, and ferrea springs. video incoming.
jays05 is offline   Reply With Quote
Old 03-14-2010, 10:30 AM   #21
jays05
Member#: 78165
05 STI 35r + e85
Old 03-14-2010, 10:46 AM   #22
25rsti
Member#: 166324
i've heard NOTHING but great things about these injectors. thats i why i ordered some 1000cc. cant wait to get them installed and running.
Old 03-14-2010, 12:12 PM   #23
derkahn
Member#: 123160
05 obxt
gtx3071r e-85 wagon
my E85 , ID1000cc tune rocks my car idles smoother and quieter than before not to mention the ID fuel rails make thing blingy
derkahn is offline   Reply With Quote
Old 03-14-2010, 12:23 PM   #24
CatfaceType-R
Member#: 81102
Thanks
-- Ed
very nice, I hate that crap.
CatfaceType-R is offline   Reply With Quote
Old 03-14-2010, 12:34 PM   #25
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
i am ordering the 1000cc injectors. my 830cc do NOT recover like that at all. Man I can't wait....
medamullet is offline   Reply With Quote
Crap Idle Problem, Can't hold idle, sometimes dies when I push clutch in TROLL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 91 09-02-2008 09:40 PM
Tree sap rock solid on my hood :( hipnotik978 Car Care & Detailing 19 12-17-2007 09:26 PM
Rock Solid Pick Up Truck? bwco Vancouver Impreza Club Forum -- VIC 19 02-05-2005 01:34 AM
The Goddamn Rock Solid Ghetto Shiznit Name Generator TBOD Off-Topic 17 07-22-2004 12:42 AM
The Rock Solid Ghetto Shiznit Name Generator CandyO Off-Topic 67 09-29-2003 10:51 PM
