Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 03-05-2010, 04:53 PM   #1
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Default Need Help with Tuner Pro.
Hi
I got Tuner Pro (still brand new) from a friend and I will use it as stand alone (not connected to utec)
I have some questions:
- How to make tuner pro as stand alone to read the rpm signal, Boost pressure and timing?
- Do I need additional wiring harness? if so what kind of wiring harness I should look for? or maybe do you have it?
- Do you have wiring diagram to shows where to connect the rpm signal cable, boost press and timing?
Tried to search about it but no luck.
Thank you for your kind attention
WRX-Blue-Mica is offline   Reply With Quote
Old 03-06-2010, 01:48 PM   #2
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Anybody?
Old 03-12-2010, 09:45 AM   #3
pjm
Member#: 73755
05 STI
It should all be explained in the manual. It should be up at the TurboXS web site. If you can't find it, I have a copy I can send.
pjm is offline   Reply With Quote
Old 03-12-2010, 02:10 PM   #4
WRX-Blue-Mica
Member#: 37938
02 WRX
Blue Mica
Hi PJM .. Thank for your reply ... and yes I already see the Tuner Pro manual to be use as stand alone and there is a table that for Analog + Digital 1 port need to be use with accessories option. I already contacted turboxs and they said that they stop produce the accessories option for that.
Do you know how to make it work, to make this Tuner Pro to be able to read rpm pulse and maybe boost pressure? Is there any way to modify it or maybe add something to make it work?
Or is it going to work if I just connect the rpm pulse cable to the tuner pro directly?
Thanks for your attention PJM
Old 03-12-2010, 06:37 PM   #5
pjm
Member#: 73755
05 STI
Not sure on those connections. I have a UTEC to go with my Tuner Pro and they connect together. I've not had to try anything but the most basic of connections with it. Sorry.
Need help with VAGCOM, "Not trying to flash, just log" realitycheck3907 Open Source Reflashes 7 06-05-2010 10:12 PM
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 06:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 09:53 AM
need help with tuner (pioneer avh-p6000dvd) boost_it_wrx Car Audio, Video & Security 4 04-10-2010 12:34 PM
Need help finding a pro-tuner Cao Southern California Impreza Club Forum -- SCIC 13 11-05-2009 06:02 PM
