03-05-2010, 10:31 PM | #1 |
Member#: 217146
Vehicle:2004 Forester XT Aspen White |
Injector and piston/cylinder wall clean up question?
I'm doing the head gaskets on my 98RS and needless to say after I took the heads off I discovered a mess...
How should I go about cleaning the cylinder walls and the top of the pistons safely? (I won't be tearing down the block any further) Also as long as my intake manifold is out will it benefit me at all to put wrx injectors in? I could get them practically free but will I see any gains? Possibly with a tune? Thanks
03-06-2010, 02:53 AM | #2 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
Rotate the pistons to the outside, and just carefully wire bruss/pick the carbon off. Carefully scrape the block face clean. Use that copper spray stuff on the block, heads, and gaskets when reassembling. Should be fine.
03-06-2010, 10:54 AM | #3 |
Member#: 232940
brake cleaner
03-06-2010, 03:13 PM | #4 |
Member#: 217146
03-06-2010, 03:15 PM | #5 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
make sure to oil the cylinder with a *slight* coat before you go back together
03-06-2010, 05:44 PM | #6 | |
Member#: 64673
NWIC
Yeah, after cleaning, rotate piston back, clean cylinder out with CLEAN rag and solvent, then oil cylinder walls. Once all 4 are done, rotate, rotate, rotate.... You might want to then wipe out the cylinders again and repeat if you see ANY crap materialize.... |
03-06-2010, 07:53 PM | #7 |
Member#: 217146
Thanks, what type of solvent should I use? I hear brake cleaner can be used
03-06-2010, 10:24 PM | #8 |
Member#: 184505
E. Canada
Vehicle:2003 WRX Sonic yellow |
when the head gaskets fail on these things does the coolant leak into the cylinder, or does the coolant get into the oil?
03-06-2010, 10:33 PM | #9 | |
Member#: 232940
sure. you're not going to hurt it. just make sure everything is clean before re assembly. |
03-07-2010, 10:45 AM | #10 | |
Member#: 95840
NWIC
what does cleaning the cylinder walls have to do with oil pressure prior to startup? |
03-07-2010, 01:23 PM | #11 |
Member#: 159315
South East
Vehicle:2009 Cadillac CTS-V |
Oil pressure prior to startup has to do with getting that oil film back that he just wiped off.
03-07-2010, 02:38 PM | #12 |
Member#: 217146
[quote=arghx7;29980189]while it certainly couldn't hurt to go through that regimen, that's not necessary as long as you crank the motor over to build oil pressure before actually starting it
So what you're saying is once the heads are back on I should crank over the motor by a hand so it lubricates the cylinders before I actually start it up? |
03-07-2010, 02:56 PM | #13 |
Member#: 71092
Vehicle:2005 2.5RS Wagon Regal Blue Pearl |
We beat this to death a couple of months ago. Due to how slowly the starter spins the motor and how long it takes to pull up a prime on the oil pump at starter-speed (you can't get the oil pump to pump at all by hand), it's easier on the engine to just start it. The total number of revolutions before full pressure is achieved is MUCH less if you just start it.
03-07-2010, 03:16 PM | #14 |
Member#: 159315
South East
I guess I missed that conversation willaty. Thanks for correcting me.
03-07-2010, 03:20 PM | #15 |
Member#: 71092
NP. I had been among those who thought that spinning the engine on the starter until you get oil pressure, then firing it was the most gentle way to do it. When someone posted the math to calculate the revolutions, and then I timed priming it with the starter vs just starting it, it takes sooooooo long to prime it with the starter that you spin it many more revolutions.
03-07-2010, 08:30 PM | #16 | |
Member#: 217146
03-07-2010, 08:35 PM | #17 |
Member#: 71092
Yes. Even though the oil pump is positive displacement, when it's full of air (and even if you "pack" it with oil after install, it'll all just run into the sump in a minute or two), you can't spin it fast enough by hand to get it to pull oil out of the pan. So your only other two options are to spin it on the starter without letting the engine fire or just start the engine. It turns out that the engine revolves fewer times if you just start it than if you just spin it on the starter due to how much faster it'll idle than the starter motor turns it.
03-07-2010, 09:37 PM | #18 |
Member#: 159315
South East
But doesn't force come into play if you just start it on assembly lube only, or in this case very very minimal residual oil? Cobb's startup instruction that came with their blocks back in the day said to turn it over with the plugs removed and fuel pump disconnected until oil pressure builds.
EDIT: I understand the total piston travel with no oil is less if you just start it up, but the force on the bearings and the heat generated will be much lower turning it over on just the starter. |
03-07-2010, 10:34 PM | #19 |
Member#: 71092
The majority of the forces on the bearing at part throttle are the g-loads from reversing the direction of the piston. That's the same no matter what's powering the engine.
Piston to cylinder wall clearance? | biknman | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 130 | 12-03-2021 07:39 PM |
Piston to wall clearence measurement question | Bad Noodle | Built Motor Discussion | 32 | 02-15-2011 03:16 PM |
Blown head gaskets, warped heads and a piston melted to the cylinder wall | Borjaq | Warranty Issues & SOA Problems | 13 | 05-22-2010 10:16 PM |
Cracked ringlands and scored cylinder walls! 07 WRX | ronzogonzo | Built Motor Discussion | 9 | 02-23-2008 11:42 PM |
WRX Injectors and Fuel pump installed have 2 questions | 99SubRs | Normally Aspirated with bolt-on Forced Induction Powertrain | 1 | 10-04-2002 10:59 AM |
