Old 01-07-2011, 11:24 AM   #226
SilverFleet
Member#: 91941
2012 Mazda3, 87 CSX,
79 Trans Am WS6
Got those DWS's mounted today. They are worlds better than the Kumho ASX's that I had before. I need an alignment badly though. Here's a question about just that:
When I go for an alignment, should I deviate from the stock specs? Just looking at the car, it looks like the fronts have a ridiculous amount of positive camber. I haven't touched it since I bought it, and all the suspension components (save for a STI rear sway bar, which shouldn't matter) are stock. Again, I have 17x8 wheels with 245/40/17s on there. I'm thinking it needs a bit more negative camber in the front. FWIW, I did notice that the old tires had a lot of uneven wear on the inside of the tire. What do you guys think?
SilverFleet is offline   Reply With Quote
Old 01-07-2011, 12:11 PM   #227
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
If your alignment specs are close to factory specs and you're STILL wearing out the inside of the tires, then your toe settings must have been off. Correct me if I'm wrong, but there are only two ways you can wear the inside of a tire prematurely: toe settings and excessive camber.
If you deviate from stock settings, it may result in better handling, but you'll most likely get more uneven tire wear. Also, if you do deviate, its a good idea to rotate the tires front to back, and diagonally more often than usual.
When you look at your car without precise measuring instruments, its very difficult to tell if you have positive camber even if it does look positive. You can never be sure until the car is on an alignment rack. But if the car had a ridiculous amount of positive camber, the outside of the tires should've worn faster than the inside.
DutchOven is offline   Reply With Quote
Old 01-07-2011, 12:17 PM   #228
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
For DDing, max out front negative camber (stock is -10 minutes which is -0.166 deg) which should be around -1* and 0 toe at all 4 corners and zero thrust angle.
Some front and rear toe out will make the car turn a lot better but you'll get some accelerated tire wear.
Dutch Oven, in general toe will kill tires much faster than camber. However, people with a lot of camber who don't drive aggressively (ie their suspension doesn't compress much) and therefore their tire always rides with most weight on the inner part of the tire, can eat the inside....this is generally the case on the herra flushers.
Most autocrossers run with as much negative camber as they can get and still eat up the OUTside of the tires .
09rexwagon is offline   Reply With Quote
Old 01-07-2011, 12:55 PM   #229
SilverFleet
Member#: 91941
79 Trans Am WS6
This is along the lines of what I was thinking. I had similar settings on my old Bugeye wagon, and it worked out great. I didn't want to start messing with it before asking, as this is a completely different chassis. And you guys are right about measuring with the naked eye. You really can't tell without the proper shop equipment. The car seems to pull to the right after getting the new tires, which is new, so who knows what the settings are right now.
Old 01-11-2011, 04:11 PM   #230
icetc
Member#: 180156
2009 WRX 5-Door
Originally Posted by Breezio View Post
I beleive you will rub without some camber and alot of fender work with a setup like that.
Cheap doesn't matter if it doesn't do what you need.
true that, then i was also considering a different tire size say a 235/40 or 235/35 (if they make them in that size)
icetc is offline   Reply With Quote
Old 01-18-2011, 07:08 PM   #231
FightingFalcon
Member#: 223299
2009 WRX WRB 4dr
2007 Kawasaki ZX6R
Got my wheels on yesterday!
Yea, yea....center caps I know >_<
I love the looks 9000 times more.
edit: O yea, the info. Enkei RPF1s 17x8, wheels are 235s and springs are Epic Engineering lowering springs (1 inch). No rolling of fenders or anything needed. Lugs are Works extended/open.
If anyone needs more technical info, lemme know.
FightingFalcon is offline   Reply With Quote
Old 01-20-2011, 10:18 PM   #232
tonyturbo13
Member#: 226525
2016 Impreza WRX STi
Originally Posted by roadtrip1098 View Post
Wheel Specs: XXR 518 Gold 18 x 8.5 / 48 offset
Tire and Specs: Falken Ze-502 225/40/18
Suspension: dropped about 1.25" w/ Megan Racing coilovers
Fender Modification: rolling/pulling necessary? NOPE
Wheel Spacers: how thick in mm, if applicable? NONE
** The 225's are stretched a bit and I just got a flat last night. Never came close to rubbing, so switching up to 235's. **
Looks good! Looking to do the Blue on Gold on my 09 WRX sedan as well. I've been considering your wheels or the XXR 522's for a while now. A few questions, are these wheels compatible with the TMPS? I have about the same amount of drop, how did the ride feel with the 18x8.5? Any fitment issues? Thanks in advance...
tonyturbo13 is offline   Reply With Quote
Old 01-21-2011, 02:01 AM   #233
G_REX
Member#: 266384
2011 WRX Limited
Spark Silver Metalic
Why do you guys buy 17s?
G_REX is offline   Reply With Quote
Old 01-21-2011, 03:38 AM   #234
LRN2WRX
Member#: 180152
2016 08 sold - 16WRX
CBS
Wheel Specs: Drag DR-31 18X8 5x100/114 35mm
Tire and Specs: BFGoodrich 235/40/18
Suspension: dropped about ? w/ Megan Racing coilovers
Fender Modification: Front and Rear by Tony.
LRN2WRX is offline   Reply With Quote
Old 01-21-2011, 05:40 AM   #235
FightingFalcon
Member#: 223299
2009 WRX WRB 4dr
2007 Kawasaki ZX6R
1) 18s look bad on stock calipers
2) Cost
Old 01-21-2011, 05:43 AM   #236
DutchOven
Member#: 220629
I track my car. it makes more sense going through sets of cheaper 17" tires than to keep buying 18" tires over and over again.
I just picked up a set of 235/40 17 racing tires for 400 brand new. can't be beat in 18s.
Old 01-21-2011, 10:47 AM   #237
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Weight also for some.
Breezio is offline   Reply With Quote
Old 01-21-2011, 12:21 PM   #238
FightingFalcon
Member#: 223299
2009 WRX WRB 4dr
2007 Kawasaki ZX6R
That too.
Why would I want an extra 3 lbs per wheel?
Old 01-21-2011, 02:36 PM   #239
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Originally Posted by LRN2WRX View Post
Looks awesome. got any more pics? (preferably some showing off how much they poke.)
QwaktastiK is offline   Reply With Quote
Old 01-22-2011, 03:00 PM   #240
G_REX
Member#: 266384
2011 WRX Limited
2) Cost
In my opinion 17s look bad on the car... wouldn't you rather have something that looks good on the car overall than look good on the calipers?
I mean, at least you'll look forward getting a BBK
If you track your car and to keep cost down can I understand...but why not just get 17s track specific wheels/tires and drive around in 18s which would be more aesthetically appealing...
I just picked up some 235/40-R18 for $500... $100 more for something that will last say 1-2 years is not a bad trade off.
There are some affordable 18 inch light weight wheels...
That too.
I just picked this up.... wheels + tires + TPMS = 44lb
I think I just saved just about 2lb to 3lb per corner...
TR Motorsport MT1 18x8.5 et48 5x100
Sumitomo HTR ZIII 235/40-R18
Thank You Tire Rack!
[img]
DSC_1279 by critical_gp, on Flickr[/img]
Old 01-22-2011, 03:19 PM   #241
FightingFalcon
Member#: 223299
2009 WRX WRB 4dr
2007 Kawasaki ZX6R
44lb wheels? Like...per wheel?
Hot damn....mine are 15.4 per wheel.
Old 01-22-2011, 03:32 PM   #242
G_REX
Member#: 266384
2011 WRX Limited
44lb total... (compared to almost 47lb stock 2011 WRX wheels/tires)
Wheels are 18.5lb which is very good for the size. Wheels are manufactured by Enkei in Japan specifically for Tire Rack and sold under TR Motorsport brand...
Old 01-23-2011, 07:25 AM   #243
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
what car did you search for to find these? when i sort by WRX, they dont show up as an option. only the C2's
gsrcrxsi is offline   Reply With Quote
Old 01-23-2011, 07:31 AM   #244
DutchOven
Member#: 220629
Volks CE28N 17x9 +44 5x100
15 lbs
Hankook Ventus V12 255/40 17
25 lbs
40lbs total
Old 01-23-2011, 12:04 PM   #245
G_REX
Member#: 266384
2011 WRX Limited
04 STi they are on sale at the moment
Old 01-23-2011, 01:53 PM   #246
Breezio
Member#: 234357
2009 WRX
15 lbs
25 lbs
40lbs total
Got a picture? How is the inside/outside clearance and all that..?
Old 01-25-2011, 06:42 PM   #247
RavSpec
NASIOC Storefront Vendor
Member#: 26854
2002 Impreza
WRX
WORK Emotion XT7 - 18x9.5 +38mm 5x100 / 235/40 tire
RavSpec is offline   Reply With Quote
Old 01-25-2011, 07:13 PM   #248
tonyturbo13
Member#: 226525
^^ Nice!!!! Any fender modification to fit those 18x9.5?
Old 01-25-2011, 07:23 PM   #249
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Also what suspension?
SWP n Gold is offline   Reply With Quote
Old 01-25-2011, 07:53 PM   #250
tonyturbo13
Member#: 226525
Originally Posted by BLkdubRX View Post
Im glad the first mod on my 09 was springs.. does anyone else have some with ~1.4-5 inch drop other than CMiller219?? (looks good by the way) especially for the sedan
Dropped 1.5" on Tein S Tech...going with an 18" wheel, debating on either XXR 522 or ROTA Grid...still debating on tire dimensions, any recommendations? Not looking to do any fender modifications...
