Welcome to the North American Subaru Impreza Owners Club Friday May 22, 2015
Old 04-04-2011, 12:35 PM   #351
JTraction
Member#: 206864
'11 E90 M3
'10 WRX (sold!)
Originally Posted by james2010wrx View Post
what offset would u reccomend
Look ^^ 32 posts.
JTraction is offline   Reply With Quote
Old 04-04-2011, 08:42 PM   #352
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
iPhone pics:
Wheel Specs: Drag DR-31 18x9 +38
Tire and Specs: Falken Azenis RT-615, 245/40/18
Suspension: GTWORX/Bilstein Impreza Cup Sport Kit
Fenders Modifications: rears rolled, fronts pulled
Wheel Spacers: 3mm spacers
QwaktastiK is online now   Reply With Quote
Old 04-05-2011, 01:52 AM   #353
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
very nice looking car.
were the spacers necessary? or did you do it for a more flush look?
gsrcrxsi is online now   Reply With Quote
Old 04-05-2011, 03:19 AM   #354
Wrx_FoSho
Member#: 277108
09 Wrx Hatch
Grey
Asked around but got different answers...
Drag DR 31's 18x9 +38
Stock suspension.
What kind of tires should i go for?
Dont want to roll or pull fenders if its not necessary.
Getting BC coilovers Soon.
Wrx_FoSho is offline   Reply With Quote
Old 04-05-2011, 08:05 AM   #355
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Stock suspension.
You could probably do 255/35/18 tires on stock suspension with no roll, but once you get the coilovers you'll need a roll. You could always go narrower, but then you'll have stretched tires since you're on 9" wheels.
SWP n Gold is offline   Reply With Quote
Old 04-05-2011, 10:38 AM   #356
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Umm... everything I've seen says no chance at all of fitting that without rolling on a narrow body...
30mm farther out? That's alot. Certainly alot more then I have clearance for on my 09'...
I wanted to do 255/35R18's on mine also, but was looking at +48mm wheels and I think that might still need a sight roll...
If I'm wrong, I'd certainly like to know, I'd much rather run some +44mm with 255's...
Breezio is offline   Reply With Quote
Old 04-05-2011, 11:07 AM   #357
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
And what is your suspension setup?
Old 04-05-2011, 06:56 PM   #358
Primary Visions
Member#: 261698
2008 WRX Hatchback
Just picked up some tenzo cusco wheels 18x9 +37
just saving up for some BC BR's and fender rolls and then they will be on
Primary Visions is offline   Reply With Quote
Old 04-05-2011, 09:29 PM   #359
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
Spacers definitely weren't necessary. Trying for flush without rubbing. I'm still tweaking everything. I created a thread about my car tramlining after putting my summers back on and I think my alignment is off in the front. Without going into a huge long rant, let's just say I'm eagerly awaiting the RCE camber plates to come out so I won't have to run the aftermarket camber bolts upfront anymore.
Stock suspension.
You want too much my friend. Pick one. Either you don't want to roll or you don't want stretch. On the wheels you have right now you're gonna get either or, not both. If you run a 225 you won't have to roll (i don't think) but you're gonna have crazy stretch. Even on a 235 you'll have stretch and need to probably roll the rears. My 245's are just barely not stretched and I had to roll. Maybe ask thatkhmer. He runs 235's on Drag DR-31 18x9 +38. It really all depends on the tire. 255's, and you'll definitely need to roll.
No, I found out the hard way on stock suspension. You need to roll the rears for these wheels.
Not positive, but you're gonna run into suspension clearance issues when running 255's on a 48 offset. I think you'll need those 44 offset wheels to clear the suspension with that wide of a tire.
I think Breezio runs The GTWORX/Bilstein Impeza Cup Sport Kit. Correct me if I'm wrong.
Old 04-05-2011, 10:01 PM   #360
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
I didn't think it would scrape TOO bad on the stock suspension since it's the same diameter as the stock wheels/tires and there's tons of wheel gap when it's not lowered, but then again it is an 18x9 +38 so it pokes out a good amount more than stock.
Old 04-05-2011, 10:41 PM   #361
Breezio
Member#: 234357
2009 WRX
RCE/Bilstein/Yellows.
I totally agree, that's why I'm not shooting the direction anymore.
I understand, I just figure that since the stock suspension is so soft, those wheels are going to get all the way up to the fender under any heavy cornering or large bumps.
Old 04-06-2011, 10:11 AM   #362
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
Yeah, one good change in elevations on a freeway and you'll rub those fenders at that width and offset. Keep in mind you can adjust the dampening on coilovers so you could essential lessen the wheel travel even though you're lower to keep rubbing to a minimum.
The stock suspension is just way too soft and has too much suspension travel to run an aggressive setup and not rub. Roll the rear fenders for peace of mind.
I also have my camber set to -2.4 in the rear to avoid rubbing my rolled rear fenders.
Old 04-06-2011, 04:47 PM   #363
Vanderkitten
Member#: 218648
2009 WRX
Spark Silver
+44 with 8.5 width and a 235 (18") clears. Maybe you could fit a 245 with this set-up.
Vanderkitten is offline   Reply With Quote
Old 04-06-2011, 04:50 PM   #364
Vanderkitten
Member#: 218648
2009 WRX
Spark Silver
I have stock struts with tanabe GF210 springs.
Old 04-07-2011, 01:11 PM   #365
ryan788h
Member#: 256402
Originally Posted by casey oc View Post
Wheel Specs: Work emotion cr Kai's 17x9 +44
Tire and Specs: Hankook sport k104 245/40
Suspension: stock for now. rce/bilstein combo soon. 20mm front, 15mm rear.
Fender Modification: will be rolling rear soon but atm no, no rubbing.
Wheel Spacers: none.
about a 15mm clearance between inner rim/tire and front strut. next tire will probably be 255/40 depending on if clearance changes with rce/bilstein kit. in the second pic the front wheel seems to stick out pretty far, looking at the car now it doesnt seem as much.
-Casey
How much do those wheels weight?
ryan788h is offline   Reply With Quote
Old 04-07-2011, 01:13 PM   #366
ryan788h
Member#: 256402
Originally Posted by Epic_Beck View Post
Love my new wheels, gold RPF1's 17x8 +45 w/ 235/45 Continental Extreme DWS on stock suspension.
I love those wheels. What lugs are you using?
Old 04-07-2011, 01:16 PM   #367
ryan788h
Member#: 256402
Originally Posted by DutchOven View Post
Here's a cross-post:
Volk CE28N
17x9 +44 (w/ 3mm spacer)
Therefore effective offset: +41
Tire: Hankook V12 255/40 17
Front and rear fenders are rolled; no rub at all; no vibrations. Tire barely clears inside.
Suspension: BC Racing type-BR, lowered to "two finger" gaps all around.
Camber specs: 2.7F / 2.3R
Rear:
Front:
How do you like the Hancook V12 im thinking about either getting those or star specs in 255/40/17
Old 04-14-2011, 12:38 PM   #368
Wrx_FoSho
Member#: 277108
09 Wrx Hatch
Grey
What kind of camber bolts/kit do you use for the front and rear?
Old 04-14-2011, 02:35 PM   #369
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
Hankook V12's are two completely different classes of tires. The Hankook V12's I use as a tire for daily driving, and star specs for track days only.
DutchOven is offline   Reply With Quote
Old 04-14-2011, 04:33 PM   #370
johnnyb
Member#: 57593
2015 Crosstrek XV
Looking at picking up a used set of 18x8 +35 offset 5x100 OZ Superleggera.
I am running stock suspension right now, but plan on getting STI Pinks and keeping the stock struts.
Would I clear my brakes and suspension and am I going to run into problems with rubbing?
johnnyb is offline   Reply With Quote
Old 04-15-2011, 01:11 AM   #371
MrLewayne
Member#: 279937
1999 Subaru Legacy
Dark Green
siiick lookin wheels here
MrLewayne is offline   Reply With Quote
Old 04-17-2011, 01:28 PM   #372
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
just got new wheels and tires. rota tarmac3 18x8 +48 offset. tires are bridgestone potenza re11 235/40/18. these tires are worlds better than my old kuhmo asx allseasons.
424wrx is online now   Reply With Quote
Old 04-17-2011, 02:12 PM   #373
johnnyb
Member#: 57593
2015 Crosstrek XV
Nice wrb gold. Can't wait for my gold Prodrive GT1's.
Old 04-17-2011, 02:51 PM   #374
424wrx
Member#: 171948
08 wrx vf52 swap
best et,12.6@108.7
thanks. i had hyperblack g-forces before. they are gonna be winter wheels now. i always wanted gold wheels.
Old 04-17-2011, 11:46 PM   #375
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
Wheels: 18x9.5 +30 Linea Corse Lemans in Hyper Silver with Polished Lip
Tires: 235/40/18 Bridgestone Adrenalin RE001
Suspension: Bc Racing Coilovers
Camber: -2.4F/-2.6R
suby_dude is offline   Reply With Quote
