Old 05-22-2012, 09:47 PM   #751
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Finally!!
TSW Nurburgring
18x8 +45mm
Continental ExtremeContact DW, 235/40ZR18
No fender mods, no where near rubbing anywhere
RCE/GTworx Bilstein setup with RCE Yellow springs
Front camber -1.2, Rear -1.8 (factory)
Slighty inside front fenders
Wheels themselves, Just down from the lift, not settled yet.
Breezio is offline   Reply With Quote
Old 05-23-2012, 01:13 AM   #752
johnnyb
Member#: 57593
2015 Crosstrek XV
Nice looking WRX Brezio! I have the same tires and suspension.
johnnyb is offline   Reply With Quote
Old 05-23-2012, 02:10 AM   #753
BC_WRX
Member#: 320510
2010 WRX Sedan
Cool
Originally Posted by Breezio View Post
that setup (with the 235's and +44 grids) will fit just fine with no modifications.
Very similar to what I'm about to do, and I'm slightly lowered and shouldn't have to adjust anything.
http://forums.nasioc.com/forums/show...&postcount=138
This guy said he was rubbing with 18x8 +45 with 235/40/18s on stock suspension. Does His 09 WRX Hatch has very similar or exacty same fenders as my 2010 WRX Sedan? His are poking out a little. If I put 8.5" at the same offset wide rims on, they'll poke out more...
Now this is a different story. Rubbing i can solve with a fender finisher roll tool for 50 bucks from Eastwood and a heatgun, but now Im concerned about Pokage! Poking out to me means more chance of rock chipping the side of my car on gravel roads. Im going to call it a night and search for 18x 8.5 side view pics on 3G Wrxs tomorrow, Please post if you have some examples handy.
BC_WRX is offline   Reply With Quote
Old 05-23-2012, 02:27 AM   #754
Breezio
Member#: 234357
2009 WRX
Unless your camber is out of wack, you shouldn't poke with 8.5 width and +44.
About that WRB hatch with the same wheels as me.... his 'poke' way more then mine do. So I'm betting either his front camber isn't good, AND/OR he actually has the +35mm offset version of the 18x8 nurburgring. Plus they also have the 'run wider' star specs.
Old 05-23-2012, 02:32 AM   #755
Breezio
Member#: 234357
2009 WRX
And if you look at his front picture
http://forums.nasioc.com/forums/show...&postcount=147
And compare it to mine posted above, his is a fair amount farther out.
Would be nice to figure out exactly why.
Old 05-24-2012, 01:10 AM   #756
NineBreaker
Member#: 237756
2011 2.5i Sedan
Breezio - once again, I love your car! I'm planing on the 17x8+45 TSW's because 2.slow haha
NineBreaker is offline   Reply With Quote
Old 05-24-2012, 08:39 PM   #757
Breezio
Member#: 234357
2009 WRX
Originally Posted by sc00by4life View Post
subaru most certainly doesn't have a 0.0 factory setting. It is at least a few tenths of a degree negative.
0 camber is DANGEROUS.
Since I got the alignment done, just thought I'd revisit this real quick.
So I don't know how they ship out from Subaru, HOWEVER, front camber on a 3g WRX is considered 'in spec' by Subaru if it's anywhere from -.8 to .6 positive! holy smokes... who would have thought..
Old 05-26-2012, 08:07 PM   #758
WinterSubie
Member#: 243234
2009 Hatch
Might as well post up my new setup
18x7.5+44(or 40 lol) Maxxim maze w/ 235/45/18 hankooks
WinterSubie is offline   Reply With Quote
Old 05-26-2012, 08:16 PM   #759
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Finally!!
TSW Nurburgring
18x8 +45mm
So those don't stick out... I read in several threads that the Dunlop Direzza's are a bit wider than the rest, no matter the size. Looks nice!
cianuro is offline   Reply With Quote
Old 05-28-2012, 09:32 PM   #760
Coldcat83
Member#: 223799
2009 WRX
Anyone running the Mach V Awesomes on their car? I am contemplating getting these but I am not sure if they will fit on my car. My suspension mods are Tein Springs, Whiteline F/R Sways and I forget the name of my rear camber kit some European brand I found on one of threads here. I am worried they will rub on my front struts. not so worried about having to roll my fenders.
Coldcat83 is offline   Reply With Quote
Old 05-28-2012, 10:05 PM   #761
cianuro
Member#: 235475
2008 WRX
I just googled images for mach v awesome and most of the images are from Subies, so I guess it's just a matter of deciding which size you want.
Old 05-28-2012, 10:35 PM   #762
Coldcat83
Member#: 223799
2009 WRX
I guess I should have been more specific they only come in one size 17x9 +42 it was just me being wishful that someone on here would have them and what they had to do to make them fit i.e. rolling fenders and or coilovers required.
Old 05-28-2012, 10:40 PM   #763
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg "2+" 300hp/360trq
youd probably need a little roll. not much else. will depend on the tires.
i run a 17x9 +44 with 245/40/17 with no fender mods
gsrcrxsi is offline   Reply With Quote
Old 05-28-2012, 10:59 PM   #764
cianuro
Member#: 235475
2008 WRX
My bad. I didn't know that. But still, google images, find a pic of them in your car and that should help.
Old 05-29-2012, 12:29 AM   #765
Coldcat83
Member#: 223799
2009 WRX
Correct me if I'm wrong but your offset puts your rim close to the strut spring support and you clear just fine huh.
Old 05-29-2012, 12:57 AM   #766
Breezio
Member#: 234357
2009 WRX
+44 shouldn't have any strut clearance issues unless you are putting some pretty wide tires on there.
Old 05-29-2012, 09:18 PM   #767
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Yup. I clear just fine.
Old 05-29-2012, 09:38 PM   #768
NineBreaker
Member#: 237756
2011 2.5i Sedan
Pictures? Suspension?
Old 05-30-2012, 08:39 AM   #769
phr3ak
Member#: 208073
2009 wrx
here you go: http://forums.nasioc.com/forums/show....php?t=2344784
phr3ak is offline   Reply With Quote
Old 05-30-2012, 09:22 AM   #770
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
scroll back through the thread. ive already posted it.
Old 05-30-2012, 09:27 AM   #771
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
eh ill post it again, just because i DID just change some things in the suspension from what i previously posted. I used to have Epic Engineering springs, but the drop is about the same, the RCEs are just a little stiffer.
RCE black springs
Koni Sport/Yellow dampers
22mm whiteline rear sway bar (doesnt really matter for wheel fitment)
17x9 +44 Work Emotion CR Kai
245/40/17 Continental ExtremeContact DW
no fender work at all.
Old 05-30-2012, 10:07 AM   #772
Breezio
Member#: 234357
2009 WRX
Looks great, most everything I read said that fitment would work without fender mods.
I had at one time contemplated doing a 255/35r18 on a +44 or +45 wheel, though It seemed that would need some roll in the rear.
Old 05-30-2012, 02:26 PM   #773
Coldcat83
Member#: 223799
2009 WRX
Originally Posted by phr3ak
Thanks they look good on your car i wish i had the widebody as well. Probably be ordering mine in the next few months as long as nothing crazy pops up.
Old 06-02-2012, 11:27 PM   #774
BC_WRX
Member#: 320510
2010 WRX Sedan
Got 18x8.5 +44 Rota Grids in Hyper Black on PreOrder from WheelDude! Stoked, getting Bridgestone Potenza RE11s in a 235/40/18. I expect no rubbing with stock suspension. Should be here by Canada Day!
Old 06-09-2012, 07:58 AM   #775
cianuro
Member#: 235475
2008 WRX
Originally Posted by brownhelmet1 View Post
i havent gotten a chance to post up my setup but i will now
18x8.5 +40
225/40/18
Megan coilovers
no fender rolled and no issues
putting the megans up for sale soon if anyones interested let me know im getting some BC BR
Offset 40? Is that right? There are offset 44's that stick out a bit more than that, and seeing no fenders rolled makes me wonder if it's really offset 40.
