Old 12-12-2012, 05:18 PM   #1051
sreggie101
Member#: 337458
2012 WRX Hatch
PBP
Originally Posted by QwaktastiK View Post
clean setup. im guessing you rolled fenders? and are you running spacers or is the wider wheel stance resulting from offset?
sry if noob question..
sreggie101 is offline   Reply With Quote
Old 12-12-2012, 10:58 PM   #1052
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
Originally Posted by Julio Bro! View Post
Apparently it's a fairly new wheel and there aren't pics around, that's the first I see installed. But they come in 37 offset, maybe that looks deeper. They also come in charcoal and in black, maybe those look better.
I just put Tenzo TZ7 into google and came up with a bunch of pictures. Most on Volvo's interestingly enough.
I checked into the thread, these are 18x8 +37... so there you go.
I'd argue less concave then Nurburgring and Raijin's in +45 (which doesn't really say anything)... but possibly better brake clearance.
Breezio is offline   Reply With Quote
Old 12-13-2012, 11:03 AM   #1053
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Fenders rolled. Front fenders slightly pulled. No spacers, just a super aggressive offset.
QwaktastiK is online now   Reply With Quote
Old 12-13-2012, 11:04 AM   #1054
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
Originally Posted by SWP n Gold View Post
Yeah there's two types of "meaty" in my opinion. Wide meaty and lots-of-sidewall meaty.
Agreed. I hate the rubber band look. Sidewall looks so much better IMO.
Old 12-13-2012, 12:27 PM   #1055
Julio Bro!
Member#: 192923
Huh, not what I expected. I would like "concaver" wheels available for our specs, like the wheels for BMW (king of concaves). Some brands, like Avant Garde make 5x100, but the hubs don't fit; shame.
Julio Bro! is offline   Reply With Quote
Old 12-13-2012, 03:44 PM   #1056
sprostonsWRX
Member#: 338385
2008 WRX Hatch
lightning red
08 lightning red WRX
Rota DPT 17x9 42 offset
Nexen 245/40/17
Tein S-tech springs
Fender roll- not yet but the back is a definant must, rubs over bumps and heavy cornering.
Fronts do not need rolled.
Post pics asap
sprostonsWRX is offline   Reply With Quote
Old 12-13-2012, 10:15 PM   #1057
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
just a question. i found that ichiba makes subaru specific wheels spacers. what could i run with 18x8 +48 offset wheels? i have 235/40/18 tires. the vendor is telling me 17mm bolt on spacers would work. would +31 offset be too much? im on bilstein cup kit suspension. its not really that low. heres a picture.
424wrx is offline   Reply With Quote
Old 12-16-2012, 01:36 AM   #1058
Gregor91
Member#: 259434
2012 wrx sedan
SOLD :/
Unless your fenders are rolled you're going to rub. And you will have to get longer studs also. 17mm is a good but of difference. Get a measure tool and measure the distance to giv you an idea of how far out the tire will come. Rhys what I did
Gregor91 is offline   Reply With Quote
Old 12-17-2012, 03:04 AM   #1059
BC_WRX
Member#: 320510
2010 WRX Sedan
Default Contis
Originally Posted by gsrcrxsi View Post
Work Emotion CR Kai
17x9 +44
no spacers
still no fender work
same tires as before, 245/40/17 Conti Extreme DW
i loved my gold wheels, and they were a lot lighter than these, but i think these look a little better and the size is more what i wanted in the long run. being a non-lip wheel, they look larger and have that nice concave look because of the width/offset. and still doesnt rub (that ive noticed).
How do you like those Thats pretty sick that you have such a fat tire on with no rub. What suspension are you running? how do u like the 9 inch width for turning with the Continentals? I have some 7 inch DWS, noticeably less aggressive on cornering than my 8.5 inch Bridge Potenza RE11.
Cheers
BC_WRX is offline   Reply With Quote
Old 12-17-2012, 03:13 AM   #1060
BC_WRX
Member#: 320510
2010 WRX Sedan
Default More pics
18x 8.5 +44 Rota Grid Hyper Black - 235 /40 / 18s
rears rolled, fronts occasionally bump wheel wells and push out bumper piece with snow buildup or hard corner and bump
Old 12-17-2012, 11:22 AM   #1061
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
Stg 2+ 310/370, 6sp R180
Cheers
well right NOW im running my winter setup, 15" TD Pro Rally One with General Altimax Arctic 215/65/15 and King lift springs on Koni Yellows.
when i made that post i was running RCE Blacks with Koni Yellows. i didnt rub at all but it was very close. shortly after that post i installed the Whiteline rear subframe bushings (not the inserts). after the alignment, i started to rub very slightly on the rear drivers side. the fender lip was just barely scuffing the tire. my theory is that the stiffer bushings keep the subframe more in place during corning and keeps the tire closer to the fender during compression. so i ended up having to have the rears rolled.
245 isnt really that wide. and they stretch a tad on the 9" wheel. next set i will probably go with a 255/40
gsrcrxsi is offline   Reply With Quote
Old 12-17-2012, 07:27 PM   #1062
Sky1
Member#: 336639
Here's a couple of pictures of my wheel set up, planning for wider tires next year. Enjoy! =)
Wheel brand/Specs: Volk Racing TE37 SL Black Edition 18x9.5 +35
Tire Size: 225/40/18
Suspension Type: BC Coilovers, about half a finger gap left
Alignment: Front camber -3.0, Rear camber -2.5, F&R Toe in 1mm
Fenders: Rear Fenders slightly rolled and front fender was never touched
Sky1 is offline   Reply With Quote
Old 12-17-2012, 07:40 PM   #1063
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
I like those wheels. But I hate that you're using a stupid stretched tire. 255/35 would look MUCH better, fit better, and perform better. IMO
Old 12-17-2012, 07:55 PM   #1064
Sky1
Member#: 336639
I think for next year i will be using either 235 or 245 but 255 will be too wide and rubbing will be a issues.
Old 12-17-2012, 08:18 PM   #1065
thenick
Member#: 199580
i been hatin'
Hellas since 2012
Anyone have 17x8 +35 offset wheels? I'm considering trading for a set and I'd love to see what they look like
thenick is offline   Reply With Quote
Old 12-17-2012, 08:20 PM   #1066
gsrcrxsi
Member#: 236952
2010 WRX (SSM)
With 3.0 deg camber. You should be able to fit 255. Just roll the front. Maybe pull.
I'm running 245/40/17 on mine, rolled in the rear and it fits fine. I realize you have 9mm less in the way of offset though. But I really don't think you'll have THAT big of an issue. Just sort the fenders out
Old 12-17-2012, 11:33 PM   #1067
orijinalx
Member#: 253355
2013 VW Golf R
these came in couple weeks ago, but wont go on till spring. love how light these rims are!
17x9 +35 sbc
orijinalx is offline   Reply With Quote
Old 12-17-2012, 11:51 PM   #1068
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
I'm on 245/40/18 x 9 +38.
Fenders are rolled. Fronts are pulled.
Camber -2.0
I'm on RCE Blacks & Bilsteins.
255 is wider but shorter, so depending on suspension travel, you might not rub. I would do 245's if I were you.
Old 12-18-2012, 10:52 AM   #1069
Sky1
Member#: 336639
Will definitely consider 255 but i did wanna go a bit lower so 245 would work better for me i think.
Old 12-18-2012, 10:55 AM   #1070
Sky1
Member#: 336639
Camber -2.0
I don;t have my coilovers on the stiffest setting yet and not planning too but might consider 245. The reason why I was planning for 235 is because i was planning to go a bit lower but i definitely do want wider tire look!
Old 12-18-2012, 12:01 PM   #1071
Breezio
Member#: 234357
2009 WRX
9mm offset is nearly the same as 20mm tire width... It's a fair size difference.
Old 02-06-2013, 07:33 PM   #1072
live2rally
Member#: 325821
2009 WRX hatch
stage 2
WRX_Airman09; 18x9.5 et35 Rota G-Forces 225/40/18..rolled fenders stretched and poked
without a doubt the sexiest swp wrx hatch I've seen. My car wants to be just like yours when it grows up..minus the stretch
live2rally is offline   Reply With Quote
Old 02-12-2013, 02:38 AM   #1073
Ride1226
Member#: 201483
2010 WRX
WRBM
Reading through this a lot and having a hard time wrapping my head around all the fitments and sizes and offsets. Looking to go with something like a 17*9 with some re11s but don't want to have to pull fenders. Roll at the most. I have a one inch gap with the coilovers on on currently and not looking to dump my car. Just want wide rubber for added grip since I do track my car. What would you all advise? Thanks.
Ride1226 is offline   Reply With Quote
Old 02-12-2013, 11:05 AM   #1074
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
On 17x9s and coilovers, I would probably run a 245/40/17 tire. Offset between +40 and +44 most likely.
SWP n Gold is offline   Reply With Quote
Old 02-12-2013, 11:31 AM   #1075
QwaktastiK
Member#: 219100
2014 STI hatchback
Satin White Pearl
If I was running coilovers and tracking the car, I'd run shorter tires 255/40/17 instead of 245/45/17 (equal to my 245/40/18). Since you can adjust the height and dampening, you can keep the gap and if there's any rubbing, you can adjust your dampening. But I agree with SWP n Gold, offset between +40 and +44.
