Old 02-21-2013, 02:18 PM   #1126
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
I thought the same thing, but they are in fact the +18's.
His Instagram Username is subiedude09.
QwaktastiK is offline   Reply With Quote
Old 02-21-2013, 02:23 PM   #1127
sc00by4life
Member#: 97135
Unless the picture is misleading, and is not showing how much camber is actually being used, because that is more aggressive than has been run on a GD (in terms of tire size) - on a car that has less fender clearance.
With people in the "stance" scene, you really can't believe everything they say even though "its not a competition".
I recently fit 18x10 +38 xd9's on a friends 04 wagon, and the fitment looks pretty damn identical.
I could also very well be wrong. Who knows.
sc00by4life is online now   Reply With Quote
Old 02-21-2013, 02:35 PM   #1128
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
It's just the picture. He doesn't have a whole lot of pics that show the camber. Most of his pics are at a slight angle. Here's one more:
I'm venturing to guess he's close to -4.0 in the rear.
Old 02-21-2013, 02:36 PM   #1129
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Is it a fact that the GD has more clearance than the GE/GH? I thought the 2008-2010 WRX had similar clearance as the GD STi and the GR obviously has the most clearance.
SWP n Gold is offline   Reply With Quote
Old 02-21-2013, 02:50 PM   #1130
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
Old 02-21-2013, 03:03 PM   #1131
sc00by4life
Member#: 97135
still nothing that states offset. the +18 and +38 have the same face, and same amount of lip.
Old 02-21-2013, 03:10 PM   #1132
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
^I know they do. I've asked him on Instagram if they were +38. He said no, they are +18. Seems like he gets the offset question a lot. He quotes the offset in almost every pic of his wheels on Instagram. Weather he's telling the truth or not, well I guess that's up to you to decide. I'll give him the benefit of the doubt.
Old 02-21-2013, 03:12 PM   #1133
sc00by4life
Member#: 97135
just genuinely curious. this changes a lot of things about what is possible with GH fitment.
Old 02-21-2013, 06:29 PM   #1134
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
Originally Posted by SWP n Gold View Post
What type of suspension will you be running with the 18x8.5 +44 wheels? I have 235/40 Federals (run close to 245) mounted on my 18x8.5 +44 Grids waiting to go on in another month. I'm lowered on Epic springs/Koni shocks which makes the drop about 1.5f/1.0r and I don't expect to rub since I had plenty of space with my previous 225/40s and I'm still on stock fenders (not rolled or pulled).
The 2008s have the same amount of fender clearance as the 2009-2010 WRXs so no worries there. I was originally going to go with 245/40/18s, but then I read that Federals run a little wider than normal so I just got those in 235/40/18. They fit the 18x8.5 wheels really well and I have a feeling they're going to look really good when I get them mounted on the car.
A 245/40 Federal is going to run close to what a 255/40 "normal" tire runs in terms of width. If you want a 245/xx/18 Federal on our cars, I would opt for the 35 sidewall so it will run close to a 255/35/18 "normal" tire which is the same diameter as stock (225/45/17).
For some reason i cant see pictures on my computer. I was going to try to get my hands on some swift springs or SPT springs and put them on the stock shocks. Once those shocks go out i was going to go with the rce yellow/bilstein shock combo. Im not really sure wat the drop is going to one the rce yellow/bilstein shocks. But for now i was going to go with either the swift or SPT? What do you think?
Btw i really dont like the SLAMMED look but i also dont like the wheel gap. So maybe a drop like urs would be perfect. What do you think?
John1john is offline   Reply With Quote
Old 02-22-2013, 09:46 AM   #1135
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
So I'm assuming you have a 2008-2010 WRX since you're posting in this particular thread? Swift and SPT springs don't lower the car much, I believe the Swifts are .75" for the sedan and 1" for the hatch. Honestly, if you don't like wheel gap and you plan on getting aftermarket shocks eventually, I would look into either Epic Engineering, Eibach or H&R springs; they're all respectable companies and provide a larger drop than Swift or SPT without being slammed.
Old 02-22-2013, 10:21 AM   #1136
MRAU
Member#: 343045
Would +38 for the 18x10 xd9 be a better option or will that knock onto suspension/coilovers
MRAU is offline   Reply With Quote
Old 02-22-2013, 11:18 AM   #1137
nhat
Member#: 140163
03 STi
hellaflunctional
Inner clearance isn't an issue. "Better" depends on what you want.
Old 02-22-2013, 04:22 PM   #1138
MRAU
Member#: 343045
I know either way +18 or +38 guards would need to be rolled but if i get +38 would i need a massive amount of camber or guard work if i lower my car like +18. Planning on getting these wheels but havnt seen anyone with +38 on a 09 wrx. Thanks
Old 02-22-2013, 05:04 PM   #1139
sc00by4life
Member#: 97135
+38 will be easier. you'll still need to stretch tires and be in the -2 to -3* camber range.
you'll need at least a roll all around regardless.
Old 02-22-2013, 05:35 PM   #1140
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
Oh dang srry. I actually have an 08 wrx hatch. Well i just contacted a guy with an 08 wrx hatch and he said that he fit 17x9 +42 wrapped in 245/35. So i think i should be good with 18x8.5 +44 wrapped in 235/40. Ok thanks for your input. What kind of springs are you running??
Old 02-22-2013, 05:57 PM   #1141
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Epic Engineering. 1.2f/1.0r the Konis dropped the front another quarter inch or so, so I'm at about 1.5f/1.0r now.
Old 02-22-2013, 07:35 PM   #1142
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
And you say for you there is no wheel gap but it doesnt have that slammed look?
Old 02-25-2013, 04:38 PM   #1143
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
bump plz
Old 02-25-2013, 07:40 PM   #1144
jayslee07
Member#: 347562
wanted to get opinions on the following for 2009 silver wrx sedan
1) http://www.wheelfire.com/scontent/Wh...ption=Standard
2) http://www.tirerack.com/wheels/Wheel...All&sort=Price
3) http://www.wheelfire.com/scontent/Wh...ption=Standard
4) http://www.wheelfire.com/scontent/Wh...ption=Standard
I haven't seen anything like 3 and 4 looking through these pics. Debating one of these, or trying to find some 2011 stock wrx rims (obviously would be 17's opposed to these 18's though)
thoughts everyone?
jayslee07 is offline   Reply With Quote
Old 02-25-2013, 07:43 PM   #1145
nhat
Member#: 140163
03 STi
hellaflunctional
I would go with none of the above.
Old 02-25-2013, 11:05 PM   #1146
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
You know those are all fine rims (i wouldnt go for any of them IMO) but i would say that the Enkei EV5 would look pretty sick on an 09.
Old 02-26-2013, 07:09 PM   #1147
I Luv my Wrx8
Member#: 255128
2008 WRX
2004 Rx8
Any one here running rota grids 17x9 +35 ?
I Luv my Wrx8 is offline   Reply With Quote
Old 02-26-2013, 07:57 PM   #1148
John1john
Member#: 347613
2008 WRB WRX Hatch
AVO450-421whp e85
Im about to order some either rota grids 18x8.5 +44 or 17x9 +42. Have a friend thats running the 17x9 +42 on an 08 with 245/40 and says it just rubs in the back.
Old 03-11-2013, 11:29 AM   #1149
Frostybeverage
Member#: 266862
2011 Impreza WRX
WR Blue
Originally Posted by DutchOven View Post
one of the few favourite pics of recent. needs a photoshoot soon
What wheels are those .... Look like STI?
Frostybeverage is offline   Reply With Quote
Old 03-11-2013, 03:25 PM   #1150
DutchOven
Member#: 220629
2010 White WRX Hatch
2015 White WRX Limited
Nope. Rays 57Motorsport G07WT
17x9 +45 with 3mm spacers all around
255/40 17 Hankook V12's
DutchOven is offline   Reply With Quote
