Old 06-27-2013, 09:33 AM   #1226
SWP n Gold
Member#: 110783
2010 WRX
Satin White Pearl
Originally Posted by Mikey S. View Post
2009 wrx on eibach pro kit
Wanting to know if anyone has 18x8.5 +48 and 235 40 tires? On a similar set up if they had any clearance issues?
I have a very similar drop with very similar wheel/tire sizes and you'll be fine.
SWP n Gold is offline   Reply With Quote
Old 06-27-2013, 09:48 AM   #1227
Mikey S.
Member#: 284661
2009 Subaru WRX
Simmer down. Was just making sure the bit of difference in offset wasnt enough to cause any issues. Thanks guys. Wheels and tires are ordered. Pics next week when it all arrives
Mikey S. is offline   Reply With Quote
Old 06-29-2013, 10:27 PM   #1228
RedRumbleWagon
Member#: 352018
2010 GH7
top: stock 225/45/17
Bottom: Rota Grid IK-R 17x9+42 with 225/45/17 stock tires Going to 255/40/17s soon. http://instagram.com/p/bKTKyBh5Qr/
RedRumbleWagon is offline   Reply With Quote
Old 06-29-2013, 10:29 PM   #1229
RedRumbleWagon
Member#: 352018
2010 GH7
Old 06-30-2013, 08:28 AM   #1230
jaxwrxguy
Member#: 347857
2010 WRX Sedan
Grey
Originally Posted by Breezio View Post
I can't imagine any reason you'd need to roll the rears with that setup. Mine is very similar and I have plenty of room.
Looks great by the way!
Rear has very little room, a very slight roll would just ease my mind a little bit in the event i hit a pretty nasty bump. roads around here are generally pretty good though. I cant get a finger btwn the tire and fender.
You should be fine with that as the others have said, especially since you've got slightly less silly springs. I'm looking to upgrade to some coilovers potentially really just wanted to see how it looked lowered. Love it.
jaxwrxguy is offline   Reply With Quote
Old 07-03-2013, 11:55 AM   #1231
Mikey S.
Member#: 284661
2009 Subaru WRX
2009 WRX
Lowered on Eibach Pro kit and 2011 wrx struts (not like that matters but just in case)
Fast Wheels Komodo
18x8.5 +48 offset
235/40 18 Cooper Zeon HPT Tires
Only had em on for the morning but don't appear to have any rubbing issues driving them around town. Anyway on with the pics.
Old 07-03-2013, 12:52 PM   #1232
Mikey S.
Member#: 284661
2009 Subaru WRX
Double post. My bad.
Old 07-03-2013, 01:56 PM   #1233
medicsteve
Member#: 237760
2008 WRX Hatch
^ the '11 wrx struts bolted up okay? I thought they were a bit different than the '09+ struts.
medicsteve is offline   Reply With Quote
Old 07-03-2013, 02:30 PM   #1234
Mikey S.
Member#: 284661
2009 Subaru WRX
Nope. Bolted right in my friend.
Old 07-03-2013, 03:41 PM   #1235
Vanderkitten
Member#: 218648
2009 WRX
Spark Silver
Why did you use the 2011's? Are they improved over the 2009's, which improved over the 2008's?
Vanderkitten is offline   Reply With Quote
Old 07-03-2013, 03:46 PM   #1236
Mikey S.
Member#: 284661
2009 Subaru WRX
Nope. Bought them from a forum member with the eibachs already mounted on them. It's was purely a matter of convenience. Plus they were low mileage and basically brand new.
Old 07-03-2013, 03:55 PM   #1237
Vanderkitten
Member#: 218648
2009 WRX
Spark Silver
Good deal. Thanks!
Old 07-03-2013, 06:08 PM   #1238
Mikey S.
Member#: 284661
2009 Subaru WRX
you're welcome
Old 07-03-2013, 10:20 PM   #1239
Breezio
Member#: 234357
2009 WRX
Sportwagen zum einbauen!
If you put 08-10 designed struts on an 11+ it'll add in some camber because of slight design change.
So I'd assume that if you put 11+ struts on a 08-10 it's going to naturally take away some camber.
Have you had it aligned yet?
Breezio is offline   Reply With Quote
Old 07-03-2013, 10:27 PM   #1240
Mikey S.
Member#: 284661
2009 Subaru WRX
Sure have. Front was way the **** out back was nearly dead on. All good now though.
Old 07-03-2013, 10:28 PM   #1241
Breezio
Member#: 234357
2009 WRX
As expected.
Good to know.
Old 07-05-2013, 05:05 PM   #1242
_adam17_
Member#: 361471
i have a 2010 subaru impreza sedan, and i want to change the rims, i found a set of rims i want to get but not sure if it will fit, just want some input from others
the rims are 17x7.5+ 42 5x100, will that wheel size rub against the fenders with stock suspention with 225 45 17 tires?
please let me know
_adam17_ is offline   Reply With Quote
Old 07-05-2013, 05:54 PM   #1243
Let's Spool
Member#: 253231
2009 WRX Sedan SWP
1999 Legacy WarWag
^^ you'll be fine...
Let's Spool is offline   Reply With Quote
Old 07-06-2013, 01:19 PM   #1244
matthewilliams83
Member#: 354857
08 wrx prem sedan
black
Question Has anyone given these a shot?
XXR 530
18x8.75
Color
Chromium Black
Bolt Pattern 5-100/5-114.3
Offset +33
Backspacing 6.17
Centerbore 73.1
TPMS Compatible Yes
Approx. Weight 21.2
JWL/VIA Certified Yes
Required Lug Nuts Tuner Style
I really like these but haven't come across anyone with over an 8.5 wide wheel with less than +38... Have an 08 sedan. I'm on stock suspension right now but am planning on ordering either epic springs, or H&M (1-1.3ish rear, 1.2-1.5ish front)
matthewilliams83 is offline   Reply With Quote
Old 07-06-2013, 04:26 PM   #1245
isotopesope
Member#: 265783
2008 wrx
Niner ROS 9
they ARE different, to accomodate for the wider track.
http://forums.nasioc.com/forums/show...7&postcount=56
they "bolt right in", but to put 11+ in a 08-10, you have less available negative camber and perhaps a slightly higher ride height in the front. to go 08-10 struts in a 11+, you have more available negative camber, and probably will lower the front.
look at the photo comparision between the RCE blacks on stock 11+ struts:
http://forums.nasioc.com/forums/show...54&postcount=1
vs koni's in 09 donor struts:
http://forums.nasioc.com/forums/show...3&postcount=25
the front is a bit lower with the 09 strut bodies.
08's springs and dampers are camry soft, 09-10 have stiffer springs (same as 08-10 STi) and stiffer dampers, 11+ have the same springs, but slightly stiffer damping.
isotopesope is offline   Reply With Quote
Old 07-21-2013, 10:57 AM   #1246
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
not a Wrx, but i am a narrow body tucking some serious meat now
255/45/17 Yokohama Avid
17x9 +42 xxr 522's in gold
dropped on DGR street series coilovers
rolled and pulled
IMG_5057 by duderotomy12, on Flickr
IMG_5051 by duderotomy12, on Flickr
IMG_5067 by duderotomy12, on Flickr
IMG_5071 by duderotomy12, on Flickr
IMG_5096 by duderotomy12, on Flickr
IMG_5116 by duderotomy12, on Flickr
IMG_5120 by duderotomy12, on Flickr
Duvanator is offline   Reply With Quote
Old 07-21-2013, 04:53 PM   #1247
Spinningharmony
Member#: 309756
2009 WRX Hatch
Awesome set up Duv. What lip is that?
Spinningharmony is offline   Reply With Quote
Old 07-21-2013, 06:30 PM   #1248
Duvanator
Member#: 217257
2008 2.5i hatch
Satin White Wrap
Thanks! I am not 100% sure on the lip as I got it for free in exchange for helping someone. I've been told it is either from a 06/07 sti or 05-08 lgt lol. there is not brand stamp on it either so I dont even know who makes it. it took some extra bending to get it to fit, but can't argue with the price
Old 07-25-2013, 12:26 AM   #1249
Paul_Illest
Member#: 335368
2010 WRX
Ok heres my 2010 WRX:
Fortune Auto 500 Coilovers, 10k front/8k rear - set to full stiff (rides amazing)
Cusco rear lower control arms
Rota Grid Chameleon 18x9.5 +38 (225/40/18 Achilles ATR Sport Tires)
Front camber is -1.8, Rear camber is -2.6, 0 toe all around, 6.5 caster
I rolled the Rears flat, but i could probably get away without doing that with a 225 tire. Front lips are rolled about halfway. I still have the fender liners in all around, with minor rubbing only in the fronts on really harsh bumps!
Paul_Illest is offline   Reply With Quote
Old 07-27-2013, 02:53 AM   #1250
xxbodkinxx
Member#: 155502
xxbodkinxx is offline   Reply With Quote
