![]() Tire & Wheel Forum sponsored by The Tire Rack |
#201 |
Member#: 254097
Vehicle:2010 WRX Hatch |
^check the first page, there's one with 245s on 17s (which is pretty damn close!)
#202 |
Member#: 220629
SCIC
Vehicle:2010 WRX Hatchback Satin White Pearl |
damn, saw that, looks pretty good. anyone with 255's lowered?
#203 | |
Member#: 236952
Vehicle:2010 WRX Spark Silver |
Thanks ![]() |
#204 |
Member#: 260624
TXIC
#205 | |
Member#: 220629
SCIC
lol, I didn't list enough information for an accurate response, and I apologise for that. My two sets of wheel specs: 17x8.5 +44 for daily duties 17x9 +45 for track purposes I'm thinking about running a 255 on both, and want to know if it will clear the inside. I wanted to see if anyone is running a 255 tire on any 17's, because most people I see here have 18's with 255 or 265/30 tires. my last option would be to get rota DPT 17x9 +35's. |
#206 |
Member#: 234357
Vehicle:2009 WRX Sportwagen zum einbauen! |
I'm planning to run 18x8.5 +48 with 255/35's on my 3g.
It's supposed to clear on the inside. so I don't see why yours wouldn't with the extra 4mm or so on the inside because of the offset. |
#207 |
Member#: 97135
NWIC
The narrow bodies have trouble fitting any 255 with an offset under 40.
A 255 can go on as low as an 8" wheel, though it will have a fairly soft sidewall feel. Last edited by sc00by4life; 12-30-2010 at 09:00 PM. |
#208 |
Member#: 234357
I beleive he was worried about strut clearance.
but yes , in the 40's with a 255 on a narrow body, you are going to need fender work. |
#209 |
Member#: 220629
SCIC
yeah i figured. my front and rear fenders are already rolled flat. we'll see.
#210 |
Member#: 234357
I think you'll be just fine.
#211 |
Member#: 267224
AKIC
Vehicle:2009 WRX OBP |
I just got these a few weeks ago but I'm waiting til the winter tires come off in April to put them on. I have an '09 OBP Black 5-door
#212 |
Member#: 191290
Vehicle:09 OPB SM WRXsedan 85 BMW E30 M2 Rallycrossr |
No rubbing or issues with either setup...
Wheel Specs: Rota SDR 17x7.5 Tire and Specs: Bridgestone RE01R 225/45/17 Suspension: RCE Yellows/Bilsteins Fender Modification: None Wheel Spacers: None ![]() Wheel Specs: Rota SDR 17x7.5 Tire and Specs: Dunlop SP Sport01 235/45/17 (takeoffs from an '11 wrx) Suspension: RCE Yellows/Bilsteins Fender Modification: None Wheel Spacers: None ![]() |
#213 |
Member#: 234357
You forgot your offset numbers irish!
Aren't those like a +45mm or something? |
#214 |
Member#: 91941
NESIC
Vehicle:2012 Mazda3, 87 CSX, 79 Trans Am WS6 |
Ok, here's a question for you guys:
I need new tires really bad. I have Rota Torques that are 17x8 with a 48mm offset on the car now with 225/45/17's. I'm running stock suspension, and I probably will forever, as it's my daily driver. This time around, I'm thinking of going wider on the tires. I see that 245/40/17's seem to be a popular size for a 17x8 wheel. Would I run into any issues running that size tire, or should I go with a 235/45 or 235/40? I want to maintain stock overall diameter so the speedometer reads correct and all that stuff. |
#215 |
Member#: 220629
SCIC
you'll be fine with a 245 for sure, since you're on stock suspension.
#216 | |
Member#: 110783
Vehicle:2010 WRX Satin White Pearl |
#217 |
Member#: 234357
What they said!
However, if you decided on the 235 width, I believe 235/45r17 is the closer to stock diameter then 235/40r17. |
#218 |
Member#: 91941
NESIC
Thanks guys! I'm gonna go with the 245/40's then. I just didn't know if they would rub anywhere or balloon out off the wheel on a 17x8 and adversely affect handling.
#219 |
Member#: 110783
#220 |
Member#: 169443
VIC
Vehicle:2008 WRX Sedan VF52 WRB - 314whp 337wtq |
Do you think I would have to do any fender modifications or use wheel spacers if I ran this suspension and tire set up with with 17X8 wheels?
#221 |
Member#: 260965
TXIC
Vehicle:2010 WRX Silver |
If you ain't rubbin you ain't dubbin.
Oh snap this isn't a vw forum. I must say a lot of y'alls rides look really good. I'm just waiting until I can afford some brewer rims on my '10 wrx and a nice little drop . Downtown Houston roads suck tho so not that much of a drop . |
#222 |
Member#: 180156
Vehicle:2009 WRX 5-Door OBP |
cars look great i can't wait to get my wheels i have a few questions though
i may be buying a set of 18x8.5 +30 offset, i'm going to continue running stock suspension on my car 09 wrx, jw if anyone has any idea if it will rub, i personally don't want that aggressive of an offset but the wheels are a steal i was planning on running a 245/35 sized tire on it, prob the hankook ventus v12's thanks for any advice |
#223 |
Member#: 110783
#224 | |
Member#: 234357
Cheap doesn't matter if it doesn't do what you need. |
#225 |
Member#: 169443
VIC
