Old 03-06-2010, 02:45 PM   #1
STi-MAN
Member#: 70252
05 STI
blue
Default 4 point roll bar, need padding?
is there a need for FIA, or SFI padding on a 4 point roll bar?
STi-MAN is offline   Reply With Quote
Old 03-06-2010, 03:44 PM   #2
MasterKwan
Member#: 98961
2003 WRX
You need to pad anything your body might hit in a big crash. I'd probably pad the upper portion of the main hoop where there's a chance it might contact your helmet.
Old 03-06-2010, 03:56 PM   #3
RichardM
Member#: 39915
2007 Legacy GT
And use SFI rated padding, not pipe insulation.
RichardM is offline   Reply With Quote
Old 03-06-2010, 04:02 PM   #4
Sp00L
Member#: 169701
2006 WRX
1997 240SX
or pool noodles...
Sp00L is offline   Reply With Quote
Old 03-06-2010, 05:16 PM   #5
RichardM
Member#: 39915
2007 Legacy GT
But pool noodles come in such pretty colors.
Old 03-06-2010, 06:26 PM   #6
MasterKwan
Member#: 98961
2003 WRX
I see people with pipe insulation and pool noodle like pads at the track all the time. I don't know how they pass tech.
Old 03-06-2010, 08:46 PM   #7
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
I've seen the SFI stuff in different colors.
Patrick L is offline   Reply With Quote
Old 03-06-2010, 10:03 PM   #8
RichardM
Member#: 39915
2007 Legacy GT
Pink?
Old 03-06-2010, 10:26 PM   #9
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Pink?
Paint it.
Wintershredder is offline   Reply With Quote
Old 03-06-2010, 10:38 PM   #10
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Pink?
Get it right, it's Cherry Blossom Red.
and well probably not.
Old 03-06-2010, 11:45 PM   #11
STi-MAN
Member#: 70252
05 STI
blue
SFI is overrated!
I believe this is a picture of your cherry blossom red.
thanks guys getting some dual density sfi rated padding.
Old 03-06-2010, 11:48 PM   #12
generalee69
Member#: 106470
2004 GT-1 ICSCC #9
www.ClintonRacing.com
Originally Posted by STi-MAN View Post
SFI is overrated!
Oooo the yellow star shaped pad would be AWESOME!
generalee69 is offline   Reply With Quote
Old 03-07-2010, 10:07 AM   #13
neilschelly
Member#: 94902
1988 911 Carrera 3.2
I've got a 3' section for sale that would be perfect just to go over the top bar, if you're interested. It's brand new - I just bought too much for my roll bar. http://forums.nasioc.com/forums/show....php?t=1735431
For what it's worth, I think the foam padding is often seen on race cars in addition to proper FIA padding. FIA padding is not soft. If you hit your head on it without a helmet, it may still cause some pretty serious injury. I'm guessing that putting softer foam over that would be more of a comfort thing in many cars, especially when it comes to getting in and out of the car, where you're bound to hit the bars anyway.
neilschelly is offline   Reply With Quote
Old 03-07-2010, 12:47 PM   #14
STi-MAN
Member#: 70252
05 STI
blue
^yeah.. thats why i was thinking of going to the dual density padding.. soft on the outside hard on the inside. But if not maybe i'll take you up on your sale.
Old 03-07-2010, 04:00 PM   #15
Web Foot STi
Member#: 39086
2004 STi
My Old BMW has a 4 point roll bar, and I didn't hesitate to install padding. Real weak B pliers...
Web Foot STi is offline   Reply With Quote
Old 03-07-2010, 04:17 PM   #16
MasterKwan
Member#: 98961
2003 WRX
I used SFI/FIA (which ever it is) padding in my Civic and WRX and never had a problem with bumping my head on it. It's not like it's concrete.
Pillars? I've got a BMW now too and if you mention how weak the chassis is in a BMW forum, you get attacked. They've all been trained to think that it's normal for the strut towers to tear or for the rear suspension to tear loose from the chassis. "It's expensive, it must be good". I almost got booted for talking about how my M3 isn't as well built as my civic. It doesn't compare to a subaru chassis in any way.
Old 03-07-2010, 04:20 PM   #17
Web Foot STi
Member#: 39086
2004 STi
Originally Posted by MasterKwan View Post
I used SFI padding in my Civic and WRX and never had a problem with bumping my head on it. It's not like it's concrete.
Pillars? I've got a BMW now too and if you mention how weak the chassis is in a BMW forum, you get attacked. They've all been trained to think that it's normal for the strut towers to tear or for the rear suspension to tear loose from the chassis. "It's expensive, it must be good". I almost got booted to talking about how my M3 isn't as well built as my civic. It doesn't compare to a subaru chassis in any way.
1971 2002. I said OLD.
Edit: I still run with the local BMWACA club, and was a club officer years ago.
Old 03-07-2010, 04:31 PM   #18
STi-MAN
Member#: 70252
05 STI
blue
Yeah i mean i already have some FIA padding from the previous owner.. but its red.. and i dont want my car looking fast and furious on the street.
Strut tower tear?? wow.
Old 03-07-2010, 05:59 PM   #19
MasterKwan
Member#: 98961
2003 WRX
Yeah, that's not the 1/2 of it. They're pretty damn light though. Imagine a 3.2 liter 6 driving a car that weights about what an S2000 does. You can also fit 245's pretty easily too. I felt safe driving my suby on track with just a bolt in bar. Not the M3. It's getting a weld in cage right now. Should be picking it back up Tuesday.
I'd walk around the car and see if you can even see the red padding. It should be pretty high in the roofline.
Old 03-08-2010, 07:51 PM   #20
STi-MAN
Member#: 70252
05 STI
blue
Question.
for those using the fia.. did it dent up the roof liner? yes i like to try and keep some parts of my car as clean as possible.
Old 03-08-2010, 08:54 PM   #21
neilschelly
Member#: 94902
Question.
It doesn't touch the roofliner in my car, though I imagine it depends exactly what bar you have, whether you removed the carpet under it or not. Realistically, the padding I have is U-shaped - it won't go all the way around the bar - just on the front toward the person.
-N
Wanted: Autopower 4 Point roll bar. Sp00L Private 'Wanted' Classifieds 0 04-06-2010 04:58 PM
OH: Recaro seats for sale, Autopower 4 point roll bar tundra Private 'For Sale' Classifieds 22 11-14-2005 05:47 PM
Central FL: Miata 4 point roll bar, local pickup only S-K Private 'For Sale' Classifieds 0 08-12-2005 12:13 PM
GC - 8 point Roll Bar kits $164.95, 10 point Roll Cage Kits $244.95. Sold in threes. Safe Drives Vendor 'Group Buy' Classifieds 81 03-31-2005 09:01 PM
Harnesses ok with 4 point roll bar? (street/track) subyguy2 Motorsports 1 12-10-2002 11:22 PM
