Old 03-06-2010, 05:10 PM   #1
Liquidr1
Member#: 205015
2009 Impreza WRX
Default Data logging newb: Knock learning vs. Correction
I just did a quick 3rd gear pull and data logged it with my accessport just out of curiosity.
What is the difference between knock learning vs. knock correction.
I logged from 4K rpms up to 6200 rpms in a quick 3rd gear pull.
In the Knock correction column i see anywhere from -.35 to -1.75. In the Knock learning column its all 0's.
Also what should i be seeing in the ignition advanced column? all positive #'s?.
Liquidr1 is offline   Reply With Quote
Old 03-06-2010, 05:50 PM   #2
ohm
Member#: 178468
2007 UGM STI
IAG Built
Personally, I get negative knock correction values on occasion, but never saw knock learning. I believe knock learning is the ECU learning knock at certain RPMs, and retaining that information from what it perceives as knock. In the lower RPM range, negative knock correction values are considered acceptable. I have noticed that I can trigger negative knock correction depending on the gear I am in relative to my RPMs (ie: higher gear with more load triggers -KC on occasion).
Negative knock correction is the ECU pulling timing from what is perceives as knock, or other factors. From reading up on what Cobb defines as knock correction, I believe it can be from any number of factors based on calculations the ECU makes, not necessarily real knock events.
What does your DAM look like?
Post up your log.
ohm is offline   Reply With Quote
Old 03-06-2010, 06:07 PM   #3
Liquidr1
Member#: 205015
2009 Impreza WRX
honestly dont know how to post up a excel file. how do i do it
Old 03-06-2010, 06:10 PM   #4
ohm
Member#: 178468
2007 UGM STI
IAG Built
Copy and paste the data around the [code] tag.
Old 03-06-2010, 06:48 PM   #5
Liquidr1
Member#: 205015
2009 Impreza WRX
Ok.
I just went out and did a better log of 3rd and 4th gear. Starting in 3rd at 3k rpm to 6300 rpm in 3rd and a little more in 4th. Both my Knock learning and knock corrections read all 0.
not sure about what you mean by "Copy and paste the data around the [code] tag."
Old 03-06-2010, 06:58 PM   #6
Liquidr1
Member#: 205015
2009 Impreza WRX
ok that didnt work
Old 03-06-2010, 07:05 PM   #7
Liquidr1
Member#: 205015
2009 Impreza WRX
i give up. dont know how to post the log.
Old 03-06-2010, 07:36 PM   #8
ohm
Member#: 178468
2007 UGM STI
IAG Built
Well after getting out my magnifying glass....
You want to do a 3rd gear WOT log. It appears that you were cruising around for a bit, then went WOT at like 5700 to 6300. Try to hold your RPMs steady while in 3rd, start the log, then just mash it.
Old 03-06-2010, 07:40 PM   #9
Liquidr1
Member#: 205015
2009 Impreza WRX
yea i gradually went full throttle. But isnt a good sign that all the knock values are 0.
Old 03-06-2010, 07:46 PM   #10
ohm
Member#: 178468
2007 UGM STI
IAG Built
It is a good sign, I wouldn't worry that much. You didn't log DAM, but I am going to go out on a limb and say it is probably OK.
Btw, appears you are having some nice weather too.
Old 03-06-2010, 08:55 PM   #11
Liquidr1
Member#: 205015
2009 Impreza WRX
yea it hit 60 degrees today.
Old 03-09-2010, 01:13 AM   #12
arghx7
Member#: 232940
Is your knock learning table populated with any values? post a screenshot
arghx7 is offline   Reply With Quote
Old 03-09-2010, 07:01 AM   #13
Liquidr1
Member#: 205015
2009 Impreza WRX
^no it was all zeros
Old 03-10-2010, 01:42 AM   #14
arghx7
Member#: 232940
Sounds like your motor is doing fine.
HELP: I want to learn data logging whipito Other Engine Management 0 03-26-2008 11:53 PM
Need help w/ data log and AFR / Knock question Tronner AccessPort 1 11-09-2007 02:07 PM
How to learn to data log?? BBBsti LTD Engine Management & Tuning 19 03-18-2007 04:52 PM
Help dissect log please... knock and some negative correction root Engine Management & Tuning 10 07-18-2005 10:18 PM
A UTEC question - flashing CEL, no knock seen on data log..what gives? LargeOrangeFont Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-03-2003 03:33 PM
