Old 03-06-2010, 06:31 PM   #1
Boxer4h
Member#: 199019
2002 Wrx
Default Wrx misfire on all cylinders and more...
I have a 02 wrx and im having cel codes pop up only after the car is warmed up and i sit at a stop light for 10 seconds or more and then get going... I throw cylinder misfire on 1 or more cylinders.. It has a slight low/rough idle and slight hesitation... If I let the car sit for a couple minutes idling it will throw misfires on all cylinders.. I pulled out the intercooler and there quite a bit of oil in it... The turbo has slight shaft play... The oil starts to appear from where the pcv pipe runs into the intake.. I replaced the pcv valve and it helped some... Im guessing it might be a bad turbo seal, but would that cause a misfire on all four cylinders? Please help.. Id hate to buy parts that I dont need..
Boxer4h is offline   Reply With Quote
Old 03-06-2010, 06:40 PM   #2
JoTech Performance
Member#: 190436
2006 STi
Have you changed your spark plugs lately? Bad spark plugs or coil packs can cause misfires.
JoTech Performance is offline   Reply With Quote
Old 03-06-2010, 07:01 PM   #3
Boxer4h
Member#: 199019
2002 Wrx
Yea just did a tune up in january... new plugs and fuel filter...
Aftermarket parts
TBE
Headers
Stock up pipe
Aps intake
Perrin charge pipe
Accessport stage 2
Old 03-06-2010, 07:07 PM   #4
Boxer4h
Member#: 199019
2002 Wrx
No i havent fully tuned it yet was going to do it on thursday at ams but not after all these misfires have been happening.. I havent had a misfire ever since last week.. Ive had all the parts on the car for about 8 months...Now its every time I drive...
Update on aftermarket parts...
TBE
Headers
Stock up pipe
Aps intake
Perrin charge pipe
Act streetlite flywheel
Exedy Stage 2 clutch
Perrin LCP
Accessport stage 2
Old 03-07-2010, 02:59 AM   #5
Got Groceries?
Member#: 25323
2003 WRX Wagon
Do a compression/leakdown test to rule out valves. Sounds suspiciously similar to what my 03 was doing before I burnt a valve. Or it could be the flywheel, I've heard that even the ACT is a bit too light.
Got Groceries? is offline   Reply With Quote
Old 03-07-2010, 12:19 PM   #6
Boxer4h
Member#: 199019
2002 Wrx
Yea i read up on that to... that it might throw a misfire code... but i had it installed over 8 months ago and never had a cel code for a misfire until a week ago.. Now its everytime I drive the car to work.. which is 4 miles away.. im goin try the compression test and see what that brings up... if not the only thing that i can think is wrong with it is the turbo spittin oil into the engine...
Old 03-07-2010, 09:45 PM   #7
quazimoto
Member#: 70395
quazimoto is offline   Reply With Quote
Old 03-08-2010, 10:25 AM   #8
subie.cora
Member#: 150894
That is some good common sens info. Like the whole spark plug gaping, that is a hug factor if you think about it.
subie.cora is offline   Reply With Quote
Old 03-08-2010, 10:34 AM   #9
quazimoto
Member#: 70395
Also if the valve clearances are too tight I belive you will start to get missfires. The bugeyes ECU's were plagued with misfire sensitivity. There were like 6 ECU revisions for the 02.
Old 03-08-2010, 11:20 AM   #10
subie.cora
Member#: 150894
What do you mean by 6 ECU revisions, share your info.
Old 03-08-2010, 01:07 PM   #11
quazimoto
Member#: 70395
Think of it as updating firmware for a device. Obviously if there were problems or better setting were found then a company comes up with an "update". The AF426 was the last revision for the 02 WRX.
http://www.scoobypedia.co.uk/index.p...ilityList#toc2
Old 03-11-2010, 05:13 PM   #12
Boxer4h
Member#: 199019
2002 Wrx
So bad news.... Cylinder 2 is bad.. Anyone know a good place to get a 2.0 ej20 that will work with my 2002 wrx? I found a few, but anyone know a dependable dealer? or place to buy a motor...
Old 03-11-2010, 05:30 PM   #13
Got Groceries?
Member#: 25323
2003 WRX Wagon
Bummer. I had a bad valve on mine, and had it rebuilt at RAW Performance www.raw1performance.com but I think there's a shop in Chicago, P&L maybe?
Old 03-11-2010, 05:39 PM   #14
Big_DeWeY
Member#: 37078
95 L
Blue-ish
DS1. Dylan is a solid guy and will be more than happy to help you out.
Big_DeWeY is offline   Reply With Quote
Old 03-12-2010, 04:47 AM   #15
eurospek
Member#: 96944
2005 SAAB 9-2X AERO
4eat Stage 2 Protuned
+1111 for Dylan & DS1
eurospek is offline   Reply With Quote
CEL - misfire on all cylinders Cannonbolt Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 15 12-29-2013 01:18 AM
misfire on all cylinders armandscbinwrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 03-28-2012 06:59 PM
MisFire on ALL cylinders crazycanasian Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 08-14-2009 03:54 PM
Misfire On All Cylinders scoobysti05 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 08-17-2006 07:40 PM
Misfiring on all cylinders? Subaruski Service & Maintenance 10 07-05-2005 11:59 AM
