Old 03-06-2010, 11:06 PM   #1
kh15
Member#: 132400
Default remove oil cap to perform boost leak test?
should i remove my oil filler cap to prevent blowing out my cam seals when doing a boost leak test? i only plan on pumping in 16-17psi
if i should take the cap off wont air constantly leak out during the test?
kh15 is offline   Reply With Quote
Old 03-07-2010, 04:09 PM   #2
kh15
Member#: 132400
nobody
Old 03-07-2010, 04:22 PM   #3
oncesir
Member#: 141793
02 WRB WRX Wagon
IIRC there is a FAQ about this very question. The writeup I recall reading mentions removing the oil cap to prevent the cam seals from popping out.
http://www.pandlmotorsports.com/misc...ehicle-1.2.pdf
This link refers to the procedure.
oncesir is offline   Reply With Quote
Old 03-07-2010, 04:52 PM   #4
guiltyone311
Member#: 189401
2004 sti built!!
jbp w/fp red&meth
your not really suppose to run that much pressure through the inlet side i do 5 to 7 psi through inlet side and 25 psi off the coupling to the turbo outlet
guiltyone311 is offline   Reply With Quote
Old 03-07-2010, 10:46 PM   #5
kh15
Member#: 132400
25psi! im only going to pump in about 15 or 16psi!
Old 03-07-2010, 10:57 PM   #6
boogieboogz
Member#: 147838
2007 WRX Limited
CGM
you don't need to take off the oil cap, just make sure to disconnect the PCV line from the turbo inlet. honestly, I don't even think you need 15psi. I didn't even reach 10psi before found my leak.
boogieboogz is offline   Reply With Quote
Old 03-07-2010, 10:59 PM   #7
Want_To_Buy
Member#: 238843
1997 Honda
Accord
If you know how to weld then I suggest these!
Adel Wiggins Flexible Tube Connectors
http://www.importtuner.com/tech/impp.../photo_10.html
With the amount of boost needed to make 750 whp on a four-cylinder engine, intercooler pipes pulling apart was a concern. Rather than using standard silicone hoses and clamps, Naoto chose to use Adel Wiggins Flexible Tube Connectors (Wiggins clamps) on both the intercooler system, as well as the radiator pipes. Utilized by race teams, aerospace and the military, Wiggins clamps can withhold compressed air or fluids, and are tested to seal at greater than 125 psi, up to 450F and flex 3.5.
Want_To_Buy is offline   Reply With Quote
Old 03-07-2010, 11:04 PM   #8
Want_To_Buy
Member#: 238843
1997 Honda
Accord
Yea you know this next picture doesn't make much sense to me but it has the clamps on it so lol....
Old 03-07-2010, 11:07 PM   #9
SubiSam
Member#: 156401
'03 WRB WAGON
2.1 stroker GTX3071R
Don't even put that much pressure on the inlet pipe. Guiltyone311 is right. If you're only checking for boost leaks and not vacuum, I would connect the pressure to the y pipe, or cap off the y pipe and connect to a vacuum port on the manifold. But if you insist on pressurizing the inlet, take the oil cap off.
SubiSam is offline   Reply With Quote
Old 03-08-2010, 12:18 AM   #10
kh15
Member#: 132400
do you need to vacuum test a turbo car? I would assume if its leaking under boost its leaking under vacuum
Old 03-08-2010, 12:50 AM   #11
SubiSam
Member#: 156401
'03 WRB WAGON
Not necessarily, but I don't mean put a vacuum on it. I mean pressurize the system by using a vacuum port. You would use the same method to find a vacuum leak. If you suspect a leak at the inlet pipe, you can pressurize it too, but I would not apply too much pressure there.
And yes air will leak out of the oil filler if you pressurize the inlet. The pressure will go from the inlet into the breather lines to the crank case and out of the oil filler, so if you are pressure testing the inlet, it wouldn't really do any good to just remove the oil cap. I would cap off the breather connections on the inlet if you are looking for a leak there. It will also leak past the rings into the crank case, but with the breather lines disconnected it will just vent there. My point is, you do not want to pressurize the crankcase and you do not want to over pressurize the inlet because they are usually especially weak around the turbo connection.
Anyone in SD know how to do boost leak test? somaguchi Southern California Impreza Club Forum -- SCIC 2 01-25-2010 03:29 PM
Boost leak tested car... no leak found, spool still slooooow!!! All4bSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 25 06-02-2008 01:59 AM
Tell me how to do a boost leak test? PLEASE!! ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 07-15-2006 12:00 AM
Boost leak test??Can't get the system to pressurize? ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 07-11-2006 10:05 AM
I did a boost leak test..and found some intresting leaks. BoostedAWD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 12-13-2004 08:56 PM
