Old 03-07-2010, 05:29 PM   #1
leonbmx
Member#: 82864
2005 MPS Wagon HTA35
Domtuned Stage $$$$$
Default Maxwell Power Tuned, 2.6L Twinscroll HTA-GT3582R, 562 AWHP
Event: Dyno Tune
Ambient Temp: 57F 51% Humidity
Elevation: 200ft
Weather: Seattle Weather (But the sunny version this time )
Car: 2005 STi wagon
Tuner: Dominic Acia of Maxwell Power Services (DomTune)
Dyno Info: DynoCom
Peak HP at RPM: 562.2 AWHP @ 7050 RPM SAE Corrected
Peak Torque at RPM: 503.6 AWTQ @ 5300 RPM SAE Corrected
Baseline hp/tq for a stock on same dyno: 245 WHP
Target Boost: 27.9psi
Target AFR: 11
Fuel: 92 octane + 50/50 meth
Engine/head specs:
Maxwell Power Services 2.6L Stroked Track Series block:
2.5L STI semi-closed deck case (8.5:1)
ACL race main & rod bearings
ARP head studs
Cometic head gaskets
Custom JE Billet Pistons (99.5mm)
Element Tuning Rods
Fully balanced & blue printed
JE Pro Seal Piston Rings
K1 Billet 83mm crankshaft
Maxwell Power Services shimmed STI oil pump
New STI water pump
STI Group-N Kevlar timing belt
Subaru Factory engine gasket kit
RAW Performance (Axis) Signature Series heads:
Kelford "C" 272 camshafts
Custom hand porting work
5-Angle intake valve job
3-Angle & radiused exhaust valve job
Ferrea oversized intake valves (+1mm)
Ferrea oversized Inconel exhaust valves (+1mm)
Ferrea dual valve springs
Valves lapped into head
Titanium retainers- new spring seats
Subaru valve stem seals
Shimless Subaru buckets
Flow bench tested
ACPT Carbonfiber Drive Shaft
ACT Extreme street clutch and Light weight flywheel
Accusump 2QT with 55-60 EPC Valve
AEM 1821 EMS
AEM 4 Channel Thermocouple Amplifier with 4 EGT probes (1 in each exhaust manifold runner)
APS DR525 FMIC with Custom Crawford and Maxwell Power Services FMIC Piping kit.
ARFAB Harmonic balancer Crankshaft Pulley
Braille racing battery and mount
Cobb oil cap
Covert Performance Twinscroll manifold, uppipe and downpipe, Swaintech coated
Crawford Performance Air oil separator and Fuel Surge tank combo
Cusco tranny mount
Deatschwerks 1100cc top feed injectors
Element Tuning Hydramist (Aquamist HFS-1) Water Injection System
Garrett GT3582R with Forced Performance HTA 82 upgrade and Swaintech coated twinscroll 1.06 hotside.
Grimmspeed Jet Hot coated top feed TGV's
Group N motor mounts
Kartboy pitch stop mount
Killer B Oil pan and pick up
KSTech 8mm Phenolic Spacers
KSTech 83mm mafless CAI with K&N Filter
Maddad Whisper 3" exhaust
Mocal Oil Filter Sandwich Plate
Perrin V2 top feed Fuel Rails
Setrab 6 row oil cooler with custom Top Mount Brackets.
Synapse Engineering Synchronic BOV VTA
Fuel Setup:
Aeromotive A1000 Fuel Pressure regulator
Aeroquip AN fittings
Bosch 044 Motorsport External Fuel pump
Crawford Performance Air Oil Separator Fuel Surge tank Combo
Golan Fuel filter
Startlite Fuel hose
Wallbro 255 In tank fuel pump
Full Car specs: http://forums.nasioc.com/forums/show...9#post32259689
Current Twinscroll Dyno plot:
Previous Singlescroll setup Dyno plots:
Most recent shot:
Engine bay:
Accusump setup:
leonbmx is offline   Reply With Quote
Old 03-07-2010, 05:41 PM   #2
guiltyone311
Member#: 189401
2004 sti built!!
jbp w/fp red&meth
nice id love to have a wagon like that
never seen a filter on the bov though pretty wild
guiltyone311 is offline   Reply With Quote
Old 03-07-2010, 05:44 PM   #3
just smurfy
Member#: 135893
2012 Smart Car
murdered out w/ stickers
Wow..that's just sick.
It's amazing how much power can be added by simply putting on a Cobb oil fill cap and pulley cover.
just smurfy is offline   Reply With Quote
Old 03-07-2010, 05:48 PM   #4
leonbmx
Member#: 82864
Don't forget the red hoses, they add about 2hp easy !
Old 03-07-2010, 06:24 PM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Nice setup! So the dyno sheet run was on 30psi?
alcoolaid is offline   Reply With Quote
Old 03-07-2010, 06:31 PM   #6
leonbmx
Member#: 82864
I believe Dom said it was on 27 PSi, that's also the setting on my EBoost2.
Old 03-07-2010, 07:28 PM   #7
CatfaceType-R
Member#: 81102
yah, why the filter on the bov?
CatfaceType-R is offline   Reply With Quote
Old 03-07-2010, 08:06 PM   #8
leonbmx
Member#: 82864
This is what Synchronic recommends when using the BOV in the VTA configuration.
Old 03-07-2010, 11:08 PM   #9
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
^^^Less of a chance of oil mist everywhere in the engine bay after some time if you have a bit of blowby etc.
rexworx is offline   Reply With Quote
Old 03-08-2010, 12:02 AM   #10
alcoolaid
Member#: 134949
'07 SWP STi
If you had that much blow by to have oil mist coming out of your BOV you'd have an intercooler full of oil and much more to deal with than a filter on your BOV.
Old 03-08-2010, 12:05 AM   #11
modaddict
Member#: 95840
sold to a good bud
awaiting next car
unpossible. too small of intercooler piping.
nice mod list. it looks eerily familiar.
modaddict is offline   Reply With Quote
Old 03-08-2010, 12:09 AM   #12
leonbmx
Member#: 82864
Yeah, it's about the same as what you have been running for a while now
So does your setup spool any faster? I have this sneaky suspicion that the 2" crawford pipes look cool and all, but hurt spool on my setup...
If you think about it, it's a 2.6l engine, it has ported heads and an HTA wheel, the latter is debatable, but the other two should help spool, but somehow this setup spools slower than my previous 2.5l setup...
Old 03-08-2010, 12:20 AM   #13
modaddict
Member#: 95840
sold to a good bud
awaiting next car
It's the combination of the heads, cams, and turbo. It's all shifted your curve to the right. No biggie.
The 2.6l is only marginally larger than the 2.5l. If you calculate the cubic inches out, it's not much.
You got power hungry and shifted your power to the right. Run it out to 8k and you still have a 3k-3500rpm powerband. (same as me, same as a stock sti). You just got a wicked area under the curve.
(I'd bet if you kept the head ports near stock but ran the cams.....you wouldn't have shifted the curve as much.....but you wouldn't have as much power either)
I want that crank. Hello Dom?
Old 03-08-2010, 12:22 AM   #14
leonbmx
Member#: 82864
Yeah i noticed the 8k thing too... looking for a VTEC Sticker to put on the back of the car, lol
Old 03-08-2010, 12:26 AM   #15
modaddict
Member#: 95840
sold to a good bud
awaiting next car
Throw some C16 or Q16 at it and get it retuned and make sure to post your face as you drive it for the first time.
Old 03-08-2010, 12:26 AM   #16
leonbmx
Member#: 82864
that face can already be posted
(I keep clean underwear in my car now, lol)
Old 03-08-2010, 04:41 AM   #17
07evok1lr
Member#: 230695
2007 STI
For comparison purposes...
http://www.iwsti.com/forums/gd-membe...ed-ftw-42.html
gsc stg2 cams, Topspeed head porting, Hta 3582R, 2.5L
That being said and not to be negative but it does look like your power comes on 300-500 rpms later and falls fairly hard up top for some reason, have you asked your tuner why the power falls like that on a car with cams and headwork???
07evok1lr is offline   Reply With Quote
Old 03-08-2010, 05:11 AM   #18
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
Too small IC piping.
You can only flow X amount of air through a 2" pipe at 27 psi. Doesn't matter how you shake it.
Krang is offline   Reply With Quote
Old 03-08-2010, 02:12 PM   #19
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
Wow! Awesome numbers. Any plans on getting a race gas tune? What do you think it could make on c16?
D Money is offline   Reply With Quote
Old 03-08-2010, 06:53 PM   #20
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That boost onset is about 1k RPM late. Check to make sure you have the valve seat installed in the EWG, then check for leaks.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 03-08-2010, 09:18 PM   #21
20wrx05
Member#: 177861
1999 Built! RSTI
FP Red, E85, IM FAST!
Question
Wait, Is this the same wrx wagon that had the stock 2.0 and the fpgreen on it that was up in seattle a while back? If not sorry, but man this seems like the same guy because last i saw that thing he was getting ready to build the piss out of it which is what this is lol. If not sorry for craping in your thread. Oh and nice freaking wagon! I dream about suby's like this
20wrx05 is offline   Reply With Quote
Old 03-08-2010, 09:33 PM   #22
leonbmx
Member#: 82864
that would be me Eh wait, stock 2.5...
Old 03-08-2010, 09:35 PM   #23
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
Wrong guy, Leon is way more humble that other dude parted his stuff out.
Token-Negro is offline   Reply With Quote
Old 03-08-2010, 09:36 PM   #24
leonbmx
Member#: 82864
"Blush"
Old 03-08-2010, 09:37 PM   #25
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
I think hes talking about the guy that was down in Tacoma area, Leon your stuff has always been Solid.
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 634 06-11-2016 02:34 AM
2.6l Track Motor build 2008 STi Maxwell Power Services EtoS Built Motor Discussion 33 06-05-2013 10:53 AM
Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP alcoolaid Proven Power Bragging 61 10-22-2010 08:49 PM
hta gt3582r vs gt3582 vs hta gt3076r. casper64 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-12-2009 03:42 AM
Dom at Maxwell Power Recommendations? If not who to have do a tune? Screwbal North West Impreza Club Forum -- NWIC 44 08-18-2009 09:12 PM
