Old 08-26-2013, 09:34 PM   #76
dan2510
Member#: 305615
2013 WRX Limited Sdn
Originally Posted by Nukem View Post
Sorry for not replying on here. My mirror caps are still for sale with the LEDs. They are WRB. I Can have them painted for cheap, too. LET ME KNOW just trying to help out some fellow enthusiasts. Don't mean to promote too much of my for sale stuff.
I might be interested in these. Since I have a 2013 limited wrx with heated mirror all I'll need are the mirror caps and signal LED's right?
dan2510 is offline   Reply With Quote
Old 08-26-2013, 10:54 PM   #77
rkjunior
Member#: 112220
2011 WRX 5DR Premium
You'll have to add the two LED wires into their respective plugs. It's not that hard to do. Just take apart the plug, add a couple metal clips to the wires, etc.
rkjunior is offline   Reply With Quote
Old 09-16-2013, 10:05 PM   #78
dan2510
Member#: 305615
From what I've read having a '13 Limited WRX, I should be pre-wired already since I have heated mirrors...this is confusing. I thought I'd get away with just buying mirror caps and turn signals.
Old 09-16-2013, 10:16 PM   #79
wadowrx
Member#: 343621
2012 Impreza WRX
Dark Metallic Gray
It's only pre wired up the the inside of the door. I just got done doing the led's/folding mirrors/defrosters on my base and the wiring is there for the signals, all pretty straight foward to do. You need caps, led's and then all you have to do is run the wire from the led through the mirror and tap it into the signal wires or use the metal clips as explained. Tapping in easier but not nearly as oem and pretty. I actually have some of these metal clips too left over from my install.....
wadowrx is offline   Reply With Quote
Old 09-17-2013, 10:30 AM   #80
LVChef
Member#: 317603
2012 WRX Limited
ISM
If you have a limited you're fine, it's plug and play. If you have a base or whatever the next model up is called you have to add the wires. I have a limited and it's easy like weasy. Took 15 minutes, well maybe a little longer but not by much. Thing that took the longest was getting them painted and clear coated back from the painter.
LVChef is offline   Reply With Quote
Old 09-18-2013, 11:48 AM   #81
wutdadilyo
Member#: 53967
2011 WRX Premium
Satin White Pearl
I have a 2011 wrx premium hatch. My premium model has the heated mirrors. Would this be as easy as the limited that it would be plug and play as well or would I need to do some wiring?
wutdadilyo is offline   Reply With Quote
Old 09-21-2013, 11:16 PM   #82
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Originally Posted by impreza_pnw View Post
These are the places I have been getting them to make up the harnesses I sold, either place is good same product, Easter Beaver includes all the stuff you need too.
Premium and Limited are the same as far as the mirrors. Keep in mind this is "plug and play" as far as if you were to buy a whole STI mirror and plug it in it would work. If you want to add the signal parts you will need to get the caps and paint them, take the mirror apart and add some wiring and the signal units.
Power6 is offline   Reply With Quote
Old 12-07-2013, 05:54 PM   #83
BLAZE2099
Member#: 271588
2011 WRX
Lightning red
Think I'll just be buying some STi mirrors in the future, than it looks to be plug and play for my 11' limited.
BLAZE2099 is offline   Reply With Quote
Old 01-03-2014, 03:13 PM   #84
mbui
Member#: 326274
2012 Impreza WRX
Hey I'm in the same boat I have a base wrx, I already wired the turn signals on the mirrors and ran wires for the heating option into the car but have no idea which wire to tap into for the heat, i'm assuming the rear defroster relay but I have no idea where that is located?
mbui is offline   Reply With Quote
Old 01-03-2014, 04:33 PM   #85
m71owner
Member#: 332321
1998 2.5rs
wrb
There is a thread on clubwrx that brings you thru the entire setup. Has the wiring diagram and everything. Its what I used to install my heated mirtors. its very usefull.
m71owner is offline   Reply With Quote
Old 01-04-2014, 02:49 AM   #86
Subie2011WRX
Member#: 295381
2011 Impreza WRX
I have a set of painted sti mirror caps and leds I will sell for cheap if anyone's interested.
Still for sale? i am interested if available.
Subie2011WRX is offline   Reply With Quote
Old 03-02-2014, 04:52 PM   #87
Natew2013
Member#: 357033
2012 WRX Limited
Dark Grey
Default 08 STi mirrors--> 2012 WRX Limited
Are the 2008 STi mirrors plug and play for my 2012 WRX limited? I've been reading through forums and have found mixed reviews. I know the STi mirrors for '11+ would be plug and play but I don't know what changes were made between '08 and '11.
I don't want to lose my heated mirrors in doing the mod and would like to avoid messing with the wiring if possible. Any insight would be appreciated! Thank you!
Natew2013 is offline   Reply With Quote
Old 03-03-2014, 05:31 PM   #88
byastremski
Member#: 373005
2014 wrx 5dr
white
I just got done reading through this whole thing and the 08-10' sti's had no heated mirror option in the US, sooooo... the answer is NO. Unless the Sti's was canadian! Just thought i'd save yah the trouble of reading through the whole thing.
byastremski is offline   Reply With Quote
Old 03-03-2014, 05:37 PM   #89
D-rock240
Member#: 284221
2011 WRX GV SSM
2001 Legacy BH 5MT DD
Won't work on yours for the heated seats needing extra wires. '11 and up STI will be fine though.
Mind pm-ing me the details behind the '08 mirrors though? I dont have heated seats and am looking for a set
D-rock240 is offline   Reply With Quote
Old 03-05-2014, 03:00 PM   #90
JAMM0N
Member#: 318736
2013 WRX Hatch
CBS (BLCK)
i have some questions to ask. but first i will list what i have. yes i have read the tutorial
so i bought two turn signal with covers. they both have connectors wired to the turn signal and the end wires still bare so i'm guessing i have to run those to my relays.
i recently brought a new mirror for my driver side cause the housing was recently smashed to bits.
it was an sti mirror without the back cover, luckily i had bought a pair above. so my driver side should be ready to plug and play? or do i have to still wire up the turn signal because the connector doesn't have lines to run into my blinkers.
dont think i have the option for heated mirror in my car also. how do i go about that since the replacement housing i bought was an sti mirror?
so for the passenger side i will follow the tutorial the best i can. not really good at hooking up wires but running them through the car shouldn't be that bad.
JAMM0N is offline   Reply With Quote
Old 03-26-2014, 12:42 AM   #91
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
correct. 8 pin vs. 10 pin
gunny11218 is offline   Reply With Quote
Old 03-28-2014, 06:00 PM   #92
Mapleleaf010
Member#: 370293
2012 wrx
how much force did you guys need to use take the mirror glass off the shell. ive been trying for 20 mins and it wont budge. i dont want to snap any of the plastic clips
Mapleleaf010 is offline   Reply With Quote
Old 04-30-2014, 08:31 PM   #93
Dova
Member#: 315989
2012 WRX hatchback
Satin White Pearl
Bump. Also doing this project. Ordered the mirrors and signals from Subaru Parts Warehouse , came in today. On my 2012 base WRX.
Dova is offline   Reply With Quote
Old 04-30-2014, 10:39 PM   #94
MikeMiranda
Member#: 355937
2010 Impreza OBS
Black on Black
I love the D9R from works id like to try it in 17x9.5
MikeMiranda is offline   Reply With Quote
Old 06-19-2014, 03:32 PM   #95
Ntmid8r
Member#: 371969
2016 WRX STi
So a 2013 Limited will only need the Caps and LEDS, correct? It's true plug and play?
Ntmid8r is offline   Reply With Quote
Old 06-22-2014, 11:59 AM   #96
jrsredline350z
Member#: 384069
I may have missed this, but what are the subaru oem part numbers? I really want to do this!
jrsredline350z is offline   Reply With Quote
Old 06-22-2014, 03:09 PM   #97
Ntmid8r
Member#: 371969
2016 WRX STi
Page 1 of this thread.
Old 07-02-2014, 04:23 PM   #98
D S WRX
Member#: 348060
2011 Sedan
Just did this swap today...easy install, took maybe 20 minutes total. I purchased the whole mirror assemblies off of a 2008 STi and mounted them to my 2011 Base WRX. Plug/play with the 8-pin connectors, and vastly improves the look of my car. It's always bothered me that the mirrors look incomplete until now. Also, for some reason mine always appeared a shade or two darker of SWP than the rest of my car. The new ones match perfectly!
D S WRX is offline   Reply With Quote
Old 08-02-2014, 11:39 AM   #99
Augstar
Member#: 354389
2013 WRX Limited
SWP Hatch
So if I have a 2013 wrx limited can I just order the lights and new mirror covers and plug and play?
Augstar is offline   Reply With Quote
Old 08-02-2014, 01:46 PM   #100
Dova
Member#: 315989
2012 WRX hatchback
Satin White Pearl
No. Plug n Play if you have the STi mirrors assembly.
08 sti sway bars on a 03 wrx??? cibon7 Brakes, Steering & Suspension 1 01-17-2010 02:17 PM
08+ STi mirrors on WRX and base model. No_Brakes23 Interior & Exterior Modification 2 08-07-2009 09:17 PM
08 STI suspension fit on 08 WRX? Caobay Brakes, Steering & Suspension 5 04-17-2009 08:08 AM
08 sti mirrors on 08 WRX??? digital-monk1 Impreza Forum 3 09-14-2008 07:34 AM
08 sti mirrors on 08 WRX??? digital-monk1 Interior & Exterior Modification 2 08-21-2008 05:24 PM
