Welcome to the North American Subaru Impreza Owners Club Monday January 26, 2015
Old 12-15-2012, 12:27 AM   #51
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Originally Posted by Pearldrummer7 View Post
I think that's everyone's agreed guess on it, thought I'm not sure if anyone has reported back saying they are/aren't.
If you find out, definitely let us know! I'm interested in doing this to my '12 Premium (even if I need to wire it myself; I'm a Electrical Engy so it shouldn't be much if an issue!)
The 08-10 cars were hit and miss, they all have the wiring into the door for the signal but the WRX 11-12 (and probably '13) have always had the signal wires "live" in my experience, you could just plug a signal mirror in or tap the wires.
Originally Posted by SGMSTI View Post
I see everyone is putting these on the premium wrx what about the base wrx will it be the same
Base should be the same yes, it has an 8-pin connector going to the mirror instead of the 10-pin, the missing wires are the heat wires, signal wires are still there.
Originally Posted by BoDacious View Post
Would it be plug and play for a 2011 wrx if i just purchased the harness for the mirrors? I want to avoid tapping into any other wires.
You can't buy the mirror wiring, the part is serviced (mostly) as a unit by Subaru and they don't sell wiring repair parts.
I certainly understand the pain of having to rig it up, I am actually trying to source the wiring to put together a "signal kit" the jury is still out on that.
Power6 is offline   Reply With Quote
Old 03-11-2013, 07:59 PM   #52
sdramsey24
Member#: 306076
Fantastic mod! I was thinking just yesterday that I'd really like signal indicators on my '11 WRX Limited. Sounds like it would literally be plug and play for me.
How difficult is it to take off the mirrors? Door panels have to come off? I'll do some searching /lazy
sdramsey24 is offline   Reply With Quote
Old 06-02-2013, 02:01 AM   #53
mattesonb
Member#: 139607
2011 WRX
DGM Wrapped Satin Black
i can confirm that the base model WRX does not have the compatible harness to be plug and play.
i installed 2011 sti heated mirrors today and the sti plug is wider than the harness in the door from the factory on the base WRX.
i ended up matching the wires in the harness for the mirror motors but i had to add the ground and run a wire through the door same as the first poster
mattesonb is offline   Reply With Quote
Old 06-03-2013, 11:25 AM   #54
08Legacy-GT
Member#: 325949
He said above you need to buy 08-10 STi as they are the 8pin that the base wrx has for 11-13. You bought the wrong mirrors.
08Legacy-GT is offline   Reply With Quote
Old 06-04-2013, 02:08 AM   #55
jinstwrx
Member#: 338623
2011 Subaru WRX
red
*bookmarking this for future use*
jinstwrx is offline   Reply With Quote
Old 06-04-2013, 02:51 PM   #56
08Legacy-GT
Member#: 325949
Judging by your two posts..a 08-10 STi parts will fit/work with 11+ WRX BASE? is this correct?
Old 06-04-2013, 05:38 PM   #57
sc00by4life
Member#: 97135
Typically, yes.
Old 06-05-2013, 11:01 AM   #58
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
Yeah you want to match your unheated mirror with an unheated mirror.
unheated=8-pin
heated=10-pin
All US STI 11+ have heated mirrors and all 08-10 STI have unheated mirrors (Canada all STI have heated mirrors)
Now it is not a big deal to pull the pins from a 10-pin connector and snap them in an 8-pin housing (leave the heat wires free) you take from your stock mirrors, so you can swap between easily if you aren't concerned with reselling your stock mirrors.
Old 06-05-2013, 11:07 AM   #59
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
As mentioned above the heated mirror car will have a 10-pin plug, your unheated WRX will use an 8-pin.
Did you test the signal wires before install? One will be grounded (its joined inside the door harness to a common ground) and one should be the signal (+). I haven't seen anyone with a 11+ WRX yet that doesn't have live signal wires. The 08-10 were spotty some did some didn't. Nothing wrong with running your own wires though.
WRBear wrote the DIY long before we figured out that the signal wires are already there in the harness.
Old 06-20-2013, 07:30 PM   #60
KillJoy25
Member#: 174741
2008 Impreza WRX
I'm having an issue with this. Currently none of my turn signals are working. Here's what I've got so far: both led signals are installed and side mirror covers on. Wire from the passenger side has stopped at the door for now and grounded. The driver side is grounded, ran through the grommet and is connected to the gray wire. I had nothing from the driver side led, so I sanded down the ground some more, checked all of the connections to make sure none fell off. After this had happened, none of my turn signals are working. I even changed out the fuse. Please help, my state inspection is due by the end of the month and won't pass if these signals aren't working.
KillJoy25 is offline   Reply With Quote
Old 06-26-2013, 04:23 PM   #61
08Legacy-GT
Member#: 325949
What year setup do you have
Old 06-26-2013, 08:23 PM   #62
KillJoy25
Member#: 174741
2008 Impreza WRX
2008 WRX. After I crimped into the gray wire, I turned on the car to test and I got nothing. None of my turn signals are working.
Old 06-26-2013, 08:30 PM   #63
WRBear
Member#: 207171
2009 WRX
Can you uncrimp and see if it works again?
WRBear is offline   Reply With Quote
Old 06-27-2013, 08:33 PM   #64
KillJoy25
Member#: 174741
2008 Impreza WRX
Yea, it's blowing the fuse. When I uncrimp and put in a new fuse the turn signals work.
Old 07-01-2013, 10:32 AM   #65
max6spd
Member#: 151670
2009 Forester
Satin White Pearl
Hey there. I was hoping you can address some questions I had in regards to installing heated and signaled STi side view mirrors on my Forester. The Forester and WRX share practically everything for the most part. The mirror may even mount up without having to swap bases, but I won't know that until I can get some time to take apart the doors after the holiday weekend. I've read all 25 pages on 3gwrx.com, but I still have some questions. I'm more of a visual person, so reading what people wrote is different than seeing pics for everything.
My Forester has the 8-pin plugs, but the mirrors have the 10-pin plugs. So, I know I have to remove the 8-pin plug from the mirrors ends of my Forester mirrors and swap them onto the STi mirrors. Right now, it appears to only use three wires which I guess is to control the mirrors. I'm assuming two wires for the signal and two wires for heat for a total of 7. I believe there are 5 wires on the door side harness. What would be the best way to wire these up and make use of all functionality? Wire the signals into the harness and run separate wires through the door grommets for heat? Or the other way around and wire the heated mirrors into the harness and run separate wires for the signals? Ideally, I'd like to plug everything into the harness, but I think I would need the correct terminals to plug into the harnesses on both ends and still have to run wires through the door, correct? Are the terminals the same for the stereo? Can I can buy a aftermarket stereo harness and pull the terminals from that?
Thanks.
max6spd is offline   Reply With Quote
Old 07-01-2013, 02:22 PM   #66
max6spd
Member#: 151670
2009 Forester
Satin White Pearl
Conceivably, since I have an extra two wires at the door harness, I can use them for the heat and signal + wires and just ground the heat and signal - wires using a ring terminal attached to one of the mounting bolts?
Old 07-01-2013, 10:40 PM   #67
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
max6spd, you can conceivably do what you are saying. There are a lot of variables but I can help you through. If you have 5 wires on the door side mirror plug can you post a pic or tell me which pins are populated? Use the "base" map below for pinout numbers, that is looking into the terminals of the mirror plug on the door harness.
That helps us figure out what those wires support. This is important because not every wire goes all the way through to the door, for example if it is the signal wires, the ground for that is tied inside the harness to other ground wires, it is not a wire that goes all the way through you can use for any function.
Based on your report of 5 wires the Forester is different from the Impreza which would have 7 wires to support JDM folding on a base (no heat) car.
Are you looking to put the smaller Impreza/STI mirrors on your Forester? I don't believe that is going to work, the "triangle" base mount is almost surely different, and the interface to the mirror is definitely not the same, you can't bolt the STI mirror unit to it. All you can use is the wiring and signal units from the STI mirror. You'd have to get new/used Forester mirror covers with the cutout for the signal.
Old 07-02-2013, 11:38 AM   #68
max6spd
Member#: 151670
2009 Forester
Satin White Pearl
Ugh, don't say that. I was hoping that wouldn't be the case. I had hoped they would bolt up, and if they didn't, I could swap the STi mirrors onto the Forester bases. I guess I can resell them and get signals and Forester specific covers.
In any case, I'll take pics just so we can document them.
Old 08-21-2013, 08:11 PM   #69
dan2510
Member#: 305615
2013 WRX Limited Sdn
I want to do this ASAP on my car. I have a 2013 WRX Limited with heated mirrors...so do I just need the mirror caps and signals as mentioned in post 1 of this thread? Or do I need to buy the entire mirror assy from subaru and the mirror caps?
dan2510 is offline   Reply With Quote
Old 08-22-2013, 06:28 PM   #70
Nukem
Member#: 303705
I have a set of painted sti mirror caps and leds I will sell for cheap if anyone's interested.
Nukem is offline   Reply With Quote
Old 08-22-2013, 06:37 PM   #71
KreparAZ
Member#: 326853
2012 WRX
Satin White Pearl
What color caps?
KreparAZ is offline   Reply With Quote
Old 08-22-2013, 11:32 PM   #72
GSXpress
Member#: 95825
2011 WRX Hatch
Originally Posted by KreparAZ View Post
What color caps?
He replied in a PM that they were WRB.
GSXpress is offline   Reply With Quote
Old 08-24-2013, 03:04 AM   #73
impreza_pnw
Member#: 333742
2010 Impreza 2.5i
Newport Blue Pearl
Default works for 2.5i premium too
I got around to installing turn signal lamps into my 2010 2.5i Premium mirrors a few weeks ago. Thanks for all the info, it made everything super easy. My door harnesses were pre-wired for turn signals so I only had to touch the mirrors. The cheapest quote I got to have the mirror caps painted was $100, but I paid $125 at a body shop in my neighborhood because they had better service. I took a quick picture, it was too dark though.
I also found two places to buy the sealed connectors that plug into the lamps (84401AG052, 84401AG042). Each came with the connector, two terminals, and two plugs to seal the connector. I bought mine from auc-hi-1000 because they also had terminals that worked in the door harness connectors. Shipping was really fast (less than a week from Japan to Seattle) and everything came individually bagged. I'm happy everything is basically OEM and I won't have to worry about loose connections or terminal corrosion.
Sumitomo MT at Eastern Beaver, second one down
Sumitomo MT at auc-hi-1000 shop on Rakuten
Door harness terminals at auc-hi-1000 shop on Rakuten
impreza_pnw is offline   Reply With Quote
Old 08-26-2013, 07:20 PM   #74
m71owner
Member#: 332321
1998 2.5rs
wrb
ok im thinking about doing this but if i do i want to switch my non heated wrx mirrors to a heated sti mirror with the turn signals. ive read through these post and got the jist of everything but i dont think any one has done this yet. what all would i have to do to make this happen aside from buying the equipment? thanks everyone.
m71owner is offline   Reply With Quote
Old 08-26-2013, 08:28 PM   #75
Nukem
Member#: 303705
Sorry for not replying on here. My mirror caps are still for sale with the LEDs. They are WRB. I Can have them painted for cheap, too. LET ME KNOW just trying to help out some fellow enthusiasts. Don't mean to promote too much of my for sale stuff.
08 sti sway bars on a 03 wrx??? cibon7 Brakes, Steering & Suspension 1 01-17-2010 03:17 PM
08+ STi mirrors on WRX and base model. No_Brakes23 Interior & Exterior Modification 2 08-07-2009 10:17 PM
08 STI suspension fit on 08 WRX? Caobay Brakes, Steering & Suspension 5 04-17-2009 09:08 AM
08 sti mirrors on 08 WRX??? digital-monk1 Impreza Forum 3 09-14-2008 08:34 AM
08 sti mirrors on 08 WRX??? digital-monk1 Interior & Exterior Modification 2 08-21-2008 06:24 PM
