Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 03-07-2010, 06:36 PM   #1
wrex19
Member#: 238811
2006 wrx wagon
Default access port v.1 trouble.. Help!
I am having a problem with the tune of my car. I put on an HKS intake, HKS bov and Hi power cat back. I also put on an invidia catless dp and an STi intercooler. I used the v.1 to tune my car today and put it on stage two, i figures with all the mods it would be best plus I read some posts that said the same. The car doesn't seem to run the same, there is a little smoke that comes through the air vents, and when i looked at the boost gauge it came up as 14.5 at full boost. I have a stock turbo so my questions are is that safe on my turbo?, and is the smoke burn off from the dp/intercooler install yesterday or should i go get it checked out? please help if you can
wrex19 is offline   Reply With Quote
Old 03-07-2010, 07:35 PM   #2
joec wrx
Member#: 112359
02 WRX VF39 - Sold
I don't think this has anything to do with the AP? Regarding the smoke/smell, it's because your running CATLESS! Did you use WD40 on the downpipe install? That could be the reason you're seeing smoke. You're not hitting target boost either because of the BOV and intake. I would put the stock intake box and bypass valve back on and give the ECU some time to learn.
joec wrx is offline   Reply With Quote
Old 03-07-2010, 10:18 PM   #3
wrex19
Member#: 238811
2006 wrx wagon
Default reply
Ya we used some wd-40. i hope that is it but im not sure. So I dont have any cats now? shoot I thought I still had one cat in the mid section. My turbo runs 12 normally from the factory, 14.5 isn't too much?? I dont want to blow it up.
Old 03-07-2010, 10:33 PM   #4
joec wrx
Member#: 112359
02 WRX VF39 - Sold
What year is your WRX?
Old 03-08-2010, 01:17 AM   #5
wrex19
Member#: 238811
2006 wrx wagon
2006 wagon
Old 03-08-2010, 04:18 PM   #6
joec wrx
Member#: 112359
02 WRX VF39 - Sold
Go here and read the map notes for Stage 2. You're welcome!
http://www.accessecu.com/accessport/...06WRXMaps.html
Old 03-11-2010, 10:28 PM   #7
jasontee1
Member#: 111428
2006 wrx vf43 swap
wrb
you said catless dp your prob looking at a resenator. and yes get rid of the bov makes it run rich may back fire between 2nd or 3rd gear
jasontee1 is offline   Reply With Quote
access port error i need help? js1justlovinmyWRX AccessPort 3 03-19-2008 11:37 PM
FS: Houston (Clear Lake) - Access Port v 1, TXS stealth back system jlevy TXIC Private Classifieds 9 05-28-2007 08:10 PM
FS: '06 WRX/STi Cobb Access Port v.1 f1vlad NESIC Private Classifieds 4 05-03-2007 10:58 PM
06 STi Access Port Version 1 Phatron Engine/Power/Exhaust 1 05-03-2007 02:58 PM
For Sale: Access Port Version 1 - 2004 WRX unwrittenlaw Engine/Power/Exhaust 4 02-07-2007 04:30 PM
Message Board Statistics All times are GMT -4. The time now is 12:21 AM.
