Old 05-30-2002, 11:29 AM   #1
crash
Member#: 1440
05 LGT Wgn; 04 FXT
BDSM -- Birmingham, AL
Default TEC-II not showing any injector info
I was running the monitoring screen this morning and I noticed that it was not giving any injector info. No duty cycle info or time on/off. I am pretty sure that I am having some kind of signal loss as my EGO is showing intermitant(sp?) failure. I played with the input connector and it seemed to fix the EGO problem.
Does anyone have any troubleshooting tips?
-Nathan
crash is offline   Reply With Quote
Old 05-30-2002, 11:31 AM   #2
MadMax
Member#: 1279
2000 MY00 SRP RS2.5
"Stock" kinda
Make sure to load the current map loaded in the tec on your laptop, or i believe the monitor screen will not show injector dty cycles, etc.
Hope this helps,
MadMax
MadMax is offline   Reply With Quote
Old 05-31-2002, 02:51 AM   #3
Ethan
Member#: 246
yep he's correct, you have to load a map first. Even if its already uploaded to the tec, you still have to load the map for it to show the injector info.
Ethan is offline   Reply With Quote
Old 05-31-2002, 09:03 AM   #4
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
It doesn't sound like an intermittent failure or else you'd see the error at the bottom right side of the screen. I'd have to agree with these two gentleman and double check that you have your current map loaded.
Fitz
Fitz is offline   Reply With Quote
Old 05-31-2002, 09:22 AM   #5
crash
Member#: 1440
05 LGT Wgn; 04 FXT
That was it!
I'm shocked that I never noticed that before.
I am having a problem with my EGO sensor, but that is not related.
Thanks,
Nate
EJ18 injector info, new (almost) drop option, not SR20's sick1.8t Normally Aspirated with bolt-on Forced Induction Powertrain 10 02-07-2005 05:02 PM
O2 Sensors, TEC II, TEC III kaos200 Private 'For Sale' Classifieds 7 04-28-2004 09:12 PM
It's TEC II not TECH II !!! (nt) skidplatez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-27-2001 02:31 PM
TEC II Update. Thoughts on NA TEC II Kit installation. Imprezer Technical Forum Archive 30 05-26-2000 08:37 PM
TEC-II / TEC-II Connection Port STi Sev Technical Forum Archive 10 05-25-2000 07:28 PM
