Old 03-08-2010, 07:17 PM   #1
aquaspeed
Member#: 104267
2002 S2 2.5, FP Red
BC 280's, WRX
Default drag slick and wheel combo issues... help?
So i'm spinning too much off the line on good street tires. I've ruled out drag radials as an option.
here's the issues. I was going to run some light 17x7's with motorcycle drag slicks on them but i think my running diameter will be to small. A 26" motorcycle slick mounted on a 7" wide wheel is no longer 26". My existing tire and wheels setup measures 25.4" in running dia. and i'm running through the trap at about 7200-7300 rpm in 4th. If my diameter gets smaller i'll run out of revs and shifting to 5th is not an option.
As far as I know 15" wheels won't fit over the front stock brakes on an 02. I can't find slicks for a 16" wheel that are narrower than 10.5. what are my options for a slick/wheel combo measuring 26"
aquaspeed is offline   Reply With Quote
Old 03-08-2010, 08:24 PM   #2
aquaspeed
Member#: 104267
2002 S2 2.5, FP Red
BC 280's, WRX
finally found it, dunno why it took me forever. Hoosier Quicktime Pro's 26x9.5-16.
Old 03-08-2010, 09:47 PM   #3
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
id say work on your launching b4 you go down this road! plenty of guys can cut good 60fts w/ more power than you on lesser tires... not to mention when you hook, stuff breaks! some wheel spin can be your friend
BTW what does your car run?
example: fp red car, low 1.6s all day....
wrxtremeWGN is offline   Reply With Quote
Old 03-08-2010, 10:17 PM   #4
ritky
Member#: 72285
2005 STi Wingless
FLA Turnpike > I-95
some 15" wheels do fit but I don't know of anywhere that list them all.
ritky is offline   Reply With Quote
Old 03-10-2010, 04:32 PM   #5
aquaspeed
Member#: 104267
2002 S2 2.5, FP Red
BC 280's, WRX
I'm cutting 1.85 60' on street tires. I've been trying all types of methods of clutching and can't get it lower. The car runs [email protected]!!! I should be in the upper mid 11's. I don't scrub the tires before staging like the guy in the video. I'll try that next.
Tire and wheel combo. Zatch15 Tire & Wheel 49 05-12-2009 01:45 PM
Wheel bearing issues. Help! summitwrx Brakes, Steering & Suspension 1 06-21-2008 07:28 AM
04 sti and downpipe fitment issue...help... subpreza Engine/Power/Exhaust 0 12-23-2006 11:25 PM
Subaru vehicles and Wheel Alignment issues wwso Tire & Wheel 28 02-26-2004 02:17 AM
2000 RS Clutch and Wheel bearing issues 3BadHabbits Tri-State Area Forum 8 10-24-2003 07:01 PM
